Rockford Fosgate T400-4 amp
Discussion in 'Buy / Sell / Trade' started by Lurkin, Mar 2, 2012.
  1. Mar 2, 2012 at 12:05 PM
    Lurkin
    Lurkin [OP] Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    SOLD...
    I have a Rockford Fosgate T400-4 amp for sale for $170 shipped.
    The amp is in great shape and was used a bit over a year. I upgraded the amp to a Kenwood XR-5S for some more sub grunt. Works well as a 4 channel amp feeding your door speakers or with the front channels to door speakers and the rear channels to a sub. There is one small scratch on the heat sink in the lower left corner. The published specs are below, but please take a look at the pics for the actual power it produces.
    Actual power:
    RMS Output @ 4 ohm: 75W x 4
    RMS Output @ 2 ohm: 125W x 4
    RMS Output @ 4 ohm: 250W x 2
    Specs:
    • RMS Output @ 4 ohm: 60W x 4
    • RMS Output @ 2 ohm: 100W x 4
    • RMS Output @ 4 ohm: 200W x 2
    • CEA-2006 compliant
    • Dynamic Thermal Management cooling system
    • Differential Input circuitry eliminates hum
    • variable high- and low-pass filters (50-500 Hz, 24 dB/octave)
    • variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12k Hz)
    • Optional remote bass/treble boost
    • Class AB amplifier design
    • MOSFET power and output stages
    • Preamp inputs and outputs
    • 13-5/8"W x 2-1/4"H x 9-5/8"D
  2. Mar 3, 2012 at 5:05 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Bump
  3. Mar 5, 2012 at 5:21 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Nudder bump, come on now, someone needs a good amp. Could also be used to power a dual sub setup.
  4. Mar 5, 2012 at 9:18 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
  5. Mar 6, 2012 at 3:01 PM
    csjumper2003
    Savannah, GA
    Sold to me. Hehehehe.
