Rockstars (18") with 285's and 3" toytech??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BIGDEZUL, Oct 18, 2009.
  1. Oct 18, 2009 at 8:12 AM
    BIGDEZUL
    BIGDEZUL [OP] Well-Known Member
    Baton Rouge
    6" Pro Comp, rockstars, nittos, black mods on interior, debadged, color matched chrome bumper and grille, dynamat inside doors and floor MORE TO COME
    Could I fit the 18" rockstars on 285's with the 3" OME coil lift from toytech without MAJOR rubbing? Anyone have this set up? KMC's website says that it is a 0 offset and 5" backspacing. :confused:
  2. Oct 18, 2009 at 8:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You might need some different UCA's.
  3. Oct 18, 2009 at 8:22 AM
    BIGDEZUL
    Baton Rouge
    so if i went with a wheel that was 4.5" backspacing i wouldn't necessarily have to get new UCA's?
  4. Oct 18, 2009 at 8:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That would be better
  5. Oct 18, 2009 at 8:27 AM
    jwhelan
    jwhelan Well-Known Member
    JW
    Dallas Texas
    05 TRD Silver
    TRD PreRunner, 5100's on all four fronts @ 1.75, AAL, SP performance rotors, hawk pads, 17" FJ Cruiser wheels P/C black, 265/65/17 BFGR Rugged Trails, BHLM , painted grill, blacked out emblems
    I am thinking on the same mod, I think you will have to also go with a lower aspect ratio on the tire, meaning a 60-75 on the sidewall size.
  6. Oct 18, 2009 at 8:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    At 3" lift, you still may want to consider aftermarket UCA's that will allow the alignment to be returned to spec.
  7. Oct 18, 2009 at 8:32 AM
    BIGDEZUL
    Baton Rouge
    I thought you would say that. I'm gonna get UCA's down the road....after I finish saving for all the other crap I wanna do :D...thanks fellas
  8. Oct 19, 2009 at 8:28 PM
    BIGDEZUL
    Baton Rouge
    I'm so back and forth, i want the rockstars but i don't like the ideas of runnin spacers to get them
  9. Oct 19, 2009 at 8:42 PM
    jwhelan
    JW
    Dallas Texas
    05 TRD Silver
    what do you need spacers for? curious?
  10. Oct 19, 2009 at 8:45 PM
    BIGDEZUL
    Baton Rouge
    do avoid rubbing....the rockstars are 0 offset and 5" backspacing. Heard bad things about spacers like being unsafe....etc
  11. Oct 19, 2009 at 8:49 PM
    jwhelan
    JW
    Dallas Texas
    05 TRD Silver
    Tire rub?
  12. Oct 19, 2009 at 9:00 PM
    BIGDEZUL
    Baton Rouge
    yea tire rub
  13. Oct 19, 2009 at 9:01 PM
    Faskev
    Faskev Well-Known Member
    I ran rockstars (20X8.5 with offset of 10 and backspacing of 5.14) with the oem UCA's without a problem with a 275/60R20 tire (33's) Toytec ULK at 3". The alignment was out a bit but the truck drove really good. I put in LR UCA's a few months later and got the alignment back in spec (because I'm picky and knowing the alignment was out ate at me..lol). I think with 285's you are going to have rubbing no matter what unless you are only using a 31" tire. If you really want the rims then compromise on the tire width, that would be my advice.
  14. Oct 19, 2009 at 9:05 PM
    jwhelan
    JW
    Dallas Texas
    05 TRD Silver
    Seems like smaller tires would be a quick fix?
  15. Oct 19, 2009 at 9:14 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    With the wider tire you'll be rubbing on the stock UCAs and your camber will be off a smidge on your allignment. I know cause my allignment is kinda goofy right now with my 3" lift...just get the proper offset and backspacing with your new wheels and you'll be okay temporarilly :thumbsup:
  16. Oct 20, 2009 at 4:37 AM
    BIGDEZUL
    Baton Rouge
    I don't care so much about the width of the tire, just want the 33" look. the tires i'm looking at are exactly 11" wide. Another tire i'm interested is 11.5" wide.
  17. Oct 20, 2009 at 4:50 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    IMO, just buy what you want and don't be in a hurry to make it work. Do the install when you have some free time... trim, cut, weld what you must... buy spacers, UCA's, etc... if needed. This way you get what you want and have a unique truck. I wouldn't have done it any other way!!!
  18. Oct 20, 2009 at 4:57 PM
    BIGDEZUL
    Baton Rouge
    That's what i'm talkin about! I hear all kind of negative things about spacers, that's why I haven't pulled the trigger on the rockstars....I want a little tire sticking out.
  19. Oct 20, 2009 at 6:19 PM
    BIGDEZUL
    Baton Rouge
    Ok not to beat a dead horse, the tire is 275/70/18 (which is 11" wide) the rockstar wheel is 5" back spacing with 0 offset. I should have a small amount sticking out from the fender and barely clear the UCA right?
  20. Oct 20, 2009 at 6:31 PM
    jwhelan
    JW
    Dallas Texas
    05 TRD Silver
