Rockwall, Tx??
Discussion in 'Texas' started by TACORIDER, Oct 22, 2014.
  1. Jan 18, 2015 at 11:19 PM
    #41
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Can't help you there. I just got the adjustable shackles
  2. Jan 19, 2015 at 4:32 AM
    #42
    Luke01
    Luke01 Well-Known Member
    Luke
    Dallas, TX
    2012 Tacoma DCSB MGM lifted dented and armored
    Grillcraft Grill, Leer 100q top, 5100's on four corners, OME 885x up front, OME Dakars with add a leaf in rear, Lighting, a mix of Rigid and Chinese LED's, US Off Road hidden winch front bumper, SOS offroad conceprs skids, and rear bumper with swing out
    I did the full spring packs so I am no good to you either but I am sure if you diget around the other forums or you tube you will find all sorts of other information.
    You might even post another thread asking for help with an add a leaf and I am sure you will gets tons of help
  3. Jan 27, 2015 at 8:35 PM
    #43
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    Not that Blue Ribbon TRD Off-Roads are common or anything, but starting to add a few personal touches to make the truck mine. I'd put a fair wager down that I've got the only Tacoma in any color running around with a Campagnolo decal in the back window.
  4. Feb 11, 2015 at 11:18 AM
    #44
    cuda2k
    Jon
    Allen, TX
    You get your 885's installed yet? 5100's at 0?
  5. Feb 12, 2015 at 2:51 PM
    #45
    skb7527
    skb7527 Well-Known Member
    Scott
    McKinney, Texas
    2012 Pyrite Mica 4X4
    Goodyear Wrangler UltraTerrain AT tires with America Outlaw Sheriff wheels, Bilstein 5100s all the way around, OME coils, Toytech ICONS HD leafs, debadged, removed pin stipe, chopped tail pipe, weather tech floor mats, Leer color match topper, Toyota bed mat, homemade eight ball gear shifter and 4XInnovations weld on sliders
    Not yet. I plan on setting the billies at 1.75.
  6. Feb 15, 2015 at 11:33 PM
    #46
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    No bueno.
  7. Feb 16, 2015 at 6:37 AM
    #47
    cuda2k
    Jon
    Allen, TX
    885's + 5100's at 1.75 = 4-5+" of lift (and not a good idea from what I've read). Think I'm just going to want to level up the front even with the rear (3+1 pack so hopefully those won't sag for a while). Not sure what OME setup to go with, or just throw 5100's on at .85. Or just steal the suspension off my buddy's Baja while he's not looking. ;)
  8. Feb 26, 2015 at 3:02 PM
    #48
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    Any of you guys ever meet up? I'm back in the North Texas range now. Been in S Texas for 3 years.... I'm in Sherman if anyone ever needs some help with lift kits or what not..
  9. Feb 26, 2015 at 3:22 PM
    #49
    cuda2k
    Jon
    Allen, TX
    I'll certainly be looking for an experienced hand with some front coilovers probably later this spring when I finally decide what to do up front. And a meet is certainly always a good idea with me if for no other reason than to drink some beer and talk trucks and such.
  10. Feb 26, 2015 at 3:29 PM
    #50
    cuda2k
    Jon
    Allen, TX
    Not yet wipper-snapper. :p
  11. Feb 26, 2015 at 4:43 PM
    #51
    MatthewMay1
    Matthew
    Lone Star Republic
    Hahahaha
  12. Feb 26, 2015 at 4:59 PM
    #52
    Texasdynaryder
    Chance
    Paris, Tx
    Cool I should be in the Sherman area for the next few months I think!
    Edit: Actually trying out the 903 Brewers tonight... Good beer!!
  13. Jul 28, 2015 at 5:10 PM
    #53
    TxStVanWilder
    TxStVanWilder The Pale Horse
    Tx
    2013 TRD Sport
    I live in Rockwall
  14. Jul 29, 2015 at 7:45 PM
    #54
    TACORIDER
    TACORIDER [OP] Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Need a pic of the truck so I can spot you like a creeper
    MatthewMay1 likes this.
  15. Jul 30, 2015 at 8:57 AM
    #55
    TxStVanWilder
    Tx
    2013 TRD Sport
    Looks like this
  16. Jul 30, 2015 at 11:27 AM
    #56
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    You driving on 205?
  17. Jul 30, 2015 at 3:21 PM
    #57
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    Hey guys just checking in I'm visiting my friend here in Rockwall (Fate) will be doing some drinking while I'm down here hollar at me if yall do anything here's my truck image.jpg
    TxStVanWilder likes this.
  18. Jul 30, 2015 at 3:37 PM
    #58
    TxStVanWilder
    Tx
    2013 TRD Sport
    Shit.... You're good. But and I going north or south?
  19. Jul 31, 2015 at 8:37 PM
    #59
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
    image.jpg Anyone???
  20. Jul 31, 2015 at 8:57 PM
    #60
    Hilborn
    Michael
    Utah
    I would guess North bound.
