Rod knocking after pulling trailer up steep hill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by silverstr8p, Dec 21, 2023.
  1. Dec 21, 2023 at 1:11 PM
    silverstr8p
    silverstr8p [OP] Well-Known Member
    Truck ran perfect, 177K miles, 3.5 2GR-FKS pulled few thousand pound trailer up hill, didn't over rev or anything but was pulling hard, now rod knocks and getting low oil pressure warning. Other than that, truck still runs great (engine light, haven't checked but probably related).
    Oil looks great, Toyota serviced, going to pull motor and swap oil pump and do main/rod bearings.
    Anything else I should look for when I'm in there? Not sure why this happened in the first place, but if something in the bottom end was weak I want to know about it and fix it now.
  2. Dec 21, 2023 at 1:29 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Please report back what you find. I can't offer anything, but love a good mystery.
    Maybe by the tech lunch so the results don't get lost in the paperwork?
    TacoSR523 and wilcam47 like this.
  3. Dec 21, 2023 at 1:31 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Yes keep us all posted. What year? 2016?
    TacoSR523 and shakerhood like this.
  4. Dec 21, 2023 at 1:32 PM
    silverstr8p
    We keep our mechanic busy working mostly on our vehicle fleet, in fact I might help him pull it. 2017, bought it new.
    TacoSR523 and TnShooter like this.
  5. Dec 21, 2023 at 1:53 PM
    Evan_P
    Evan_P Well-Known Member
    Evan
    Hillsboro OR
    2020 Voodoo Blue TRD Off-Road
    If it’s knocking expect to needs rods and a crankshaft as well.
  6. Dec 21, 2023 at 1:55 PM
    silverstr8p
    Maybe. It didn't knock very long, and only one rod seems to be knocking, and even then it goes away almost when you rev it up, so low oil pressure. Interesting to see if there's metal on the drain plug, oil looked totally clean on the dipstick, and it was only slightly at the lower end of the fill range.
    Looking at the factory manual there's a few options for oversize bearings, but unless they totally failed I don't see why it would damage rod/crank, engine still runs smooth. Will have to mic everything out, but unless there's galling on the crank or rods, I don't see why they'd be dead.
  7. Dec 21, 2023 at 1:57 PM
    MGMDesertTaco
    If I had to guess oil rushed to the back of the pan going up hill and the motor was starved for oil. How heavy was the trailer?
  8. Dec 21, 2023 at 1:59 PM
    silverstr8p
    probably 3K lbs. Lots of downhill compression braking using 3rd/4th to slow me down on the backside of the hilly highway. No more than 6% highway grade.
    SLeeper512 and TacoSR523 like this.
  9. Dec 21, 2023 at 2:01 PM
    MGMDesertTaco
    I'm picking up a car and towing it in January. I think I'm gonna rent a full-size truck/tahoe and a trailer. :bananadead:
  10. Dec 21, 2023 at 2:03 PM
    silverstr8p
    This truck has towed lots of things, but we always take it easy on the motor, never had a shred of an issue with the truck or the motor, except oil, filters, brakes, serpentine belt, spark plugs, just wear items. Toyota always did the oil with synthetic.
    TacoSR523 likes this.
  11. Dec 21, 2023 at 2:19 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Dealers did the oil changes? How long were the intervals, 10k? Would be curious if there's any sludge.
    Was the timing cover or oil pan resealed at any point?
  12. Dec 21, 2023 at 2:21 PM
    silverstr8p
    Don't remember intervals, whatever they told us to do. Never had anything done on the engine.
    SandyTaco4x4 and TacoSR523 like this.
  13. Dec 21, 2023 at 2:34 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Unless you insist, dealer will rotate tires every 5k but change the oil every 10k, which may be too long when you tow a lot. Anyway, just speculation until you open up the engine to inspect.
    PoolFixer, TacoSR523, 02Duck and 4 others like this.
  14. Dec 21, 2023 at 2:42 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    How steep you towing?? If its at proper oil level this isnt going to happen...
  15. Dec 21, 2023 at 3:19 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    That sucks. I’m curious to see what the light is on for. Would be a good idea to read it and see.
  16. Dec 21, 2023 at 3:32 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    It's my opinion that after 120k the tolerances are opened up enough that you may need to up the weight of oil. 177k it's a lot of miles and 0-20 is like water
  17. Dec 21, 2023 at 8:28 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Yes and when you are hauling a trailer up a grade, engine temperature climbs opening things up even more. A step up to 0W30 or 5w30 might be beneficial.
  18. Dec 21, 2023 at 8:45 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    "...now rod knocks and getting low oil pressure warning. Other than that, truck still runs great..."
    Sorry for your issues but I got a chuckle out of that! Hope your repairs are as expected and the truck gets back on the road soon.
  19. Dec 21, 2023 at 8:58 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    There’s been a few failed oil pumps reported on this engine, I bet it is more likely that than some issue with the oil itself.
    JohnnyTRD06 and TacoSR523 like this.
  20. Dec 21, 2023 at 9:15 PM
    TacoTuesday1
    FL
    would think it has to do with the motor not towing.The chassis is rated for towing.
    don't know about this motor, but other truck motors moving cross-country hauling thousands of pounds up hills repeatedly without issue is common.
    If it's not neglected, the bores are not wider. If they were, you'd be burning oil. There is not much difference between 30 and 40.
    Folks with maintained vehicles run whatever oil is recommended regardless of miles.
