Rod knocking after pulling trailer up steep hill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by silverstr8p, Dec 21, 2023.
  1. Feb 1, 2024 at 5:37 PM
    #441
    silverstr8p
    silverstr8p [OP] Well-Known Member
    Driving the backup rig (Duramax, hardly ever drive it), our employees said it was making brake noise, they definitely weren't joking :) We're going to have a meeting about letting me know BEFORE they get to this point.
    Definitely better after fixing this. Weird thing is Napa pads only lasted 6 months or a year, so we picked the best grade they had to try as a replacement.
  2. Feb 1, 2024 at 5:53 PM
    #442
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    isn't it crazy how some can treat other's things? Just drive it til it explodes,,,, sad.
    More than likely can't find a replacement for dipshits, so we just have to deal with them for the time being.
    Junkhead, SR-71A, jmneill and 3 others like this.
  3. Feb 1, 2024 at 6:08 PM
    #443
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Seems like most people don't understand how a car works these days, so the best they can tell you is, "It's making a funny noise," or "It's not working quite right." And if they do try to figure stuff out, they listen to dipshits on TikTok or YouTube and get bad info.
    The same basic concepts apply today even with all the electronics.
    But AI and ChatGPT will fix all of it and we'll never have to figure things out on our own again. Wait, they get their info from the same shady sources.
    Where's my VCR.
    Junkhead, Barsoom, Scott B. and 3 others like this.
  4. Feb 1, 2024 at 6:29 PM
    #444
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    I agree 100%.
  5. Feb 1, 2024 at 6:37 PM
    #445
    MGMDesertTaco
  6. Feb 1, 2024 at 6:42 PM
    #446
    silverstr8p
    @Vlady Thanks, I guess we have to dissasemble something to get to THE OTHER tranny harness connector, going to try that tomorrow. He could get to one, but not the other. I think there was a weird clip that didn't get locked in.
    Another weird thing, brake pedal seems to have only moderate vacuum assist and the idle is a bit high, usually I would think that's a vacuum leak, but not sure. We're going to work on the tranny harness connector first.
  7. Feb 1, 2024 at 6:43 PM
    #447
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Make sure the brake booster hose is fully connected to that vacuum pump outlet.
    MGMDesertTaco likes this.
  8. Feb 1, 2024 at 6:52 PM
    #448
    MGMDesertTaco
    Maybe clean the IAC valve and make sure it's securely connected?
  9. Feb 1, 2024 at 6:56 PM
    #449
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    The limited information is one thing if told right when it first happens, that's the issue I think.
    I still have a VCR..and a VCR/DVD combo from GoVideo
    Chew likes this.
  10. Feb 1, 2024 at 7:03 PM
    #450
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I guess this wouldn't be a good time to admit I work in the AI space teaching the cloud how to have a conversation with people. :crapstorm:
    TartanEagle likes this.
  11. Feb 1, 2024 at 7:37 PM
    #451
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Lol, what?!?
    These trucks are drive by wire, haven’t had an idle air control valve since 2005.
    Junkhead likes this.
  12. Feb 1, 2024 at 7:56 PM
    #452
    MGMDesertTaco
    Sorry, long day; brain fart. I meant MAF. Might be a good idea to clean the PCV valve as well.
    If the high idle isn't a vacuum issue or related to the MAF/PCV I'd guess a loose connection with the 02 sensors or perhaps a loose connection somewhere else. :notsure:
  13. Feb 1, 2024 at 8:14 PM
    #453
    TireFire
    Olympic Peninsula
    What’s with the “correction”? Do you know what drive by wire means? Because these trucks ARE drive by wire, not cable.
  14. Feb 1, 2024 at 8:24 PM
    #454
    MGMDesertTaco
    Yes, I do. These trucks don't have a cable from the throttle body to the accelerator. Cable/wire same difference. And the horse you rode in on...
  15. Feb 2, 2024 at 5:04 AM
    #455
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    There's not going to be anything amiss with the PCV valve @ this mileage.
    Easy enough, but a waste of five minutes the OP could be spending on something else.
    I'm sure he knows this though..
  16. Feb 2, 2024 at 10:09 AM
    #456
    silverstr8p
    We used to just spray WD-40 around the motor until a vacuum leak sucked it into the intake manifold and the motor revved slightly, then we knew where the leak was. I think we need to fix the transmission connector issue first, maybe that will take care of a lot of the codes.
    I also grabbed the infrared temp tester so we can change the transmission fluid, you have to wait until it gets to a certain temp. Now we have to figure out how to get the tranny fluid (WS I think?) halfway up the side of the tranny to the fill hole, but one thing at a time.
    The duramax brake performance is seriously improving :)
  17. Feb 2, 2024 at 10:16 AM
    #457
    TireFire
    Olympic Peninsula
    Use a long hose snaked up into the engine bay and a funnel. Easiest way to fill the trans if you don’t have a car lift.
  18. Feb 2, 2024 at 10:18 AM
    #458
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Some ~3/4" OD hose fits nicely into the fill port of the trans. Snake it down from the engine bay, funnel ATF into the hose :thumbsup:
    The temp check procedure (jumping 2 pins on the OBD and shifting back and forth a few times) will be way more accurate than an infrared gun
    Best to read up on it here, it can take a few shots to get into temp check mode
    https://www.tacomaworld.com/threads/3rd-gen-automatic-transmission-fluid-level-check-diy.547455/
    jmneill likes this.
  19. Feb 2, 2024 at 10:20 AM
    #459
    jmneill
    SE
    Use a funnel connected to 5/8 OD vinyl tube to snake it down from under the hood and into the fill hole.
    Add 3° to what the IR temp gun reads when pointed at the bottom of the pan.
  20. Feb 2, 2024 at 10:21 AM
    #460
    jmneill
    SE
    ^^^ Damn you guys are quick
    SR-71A likes this.
