Rod knocking after pulling trailer up steep hill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by silverstr8p, Dec 21, 2023.
  1. Feb 23, 2024 at 2:22 PM
    #621
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    What year is your truck, and what year model did the motor come from? The ones on RockAuto (called a Camshaft adjuster magnet) all look like the one on the left up through 2021, same part. Nothing showing for 2022 up, but that could just be they haven't verified fitment.
  2. Feb 23, 2024 at 3:51 PM
    #622
    silverstr8p
    silverstr8p [OP] Well-Known Member
    Those are two connections for the oil pressure sensor covered in goo.
    the truck is a '17, I *think* the donor motor came out of a 19. I have no clue why they're different, but it seems important and seems to be making my truck run like an old two-cylinder John Deere tractor.
  3. Feb 23, 2024 at 4:21 PM
    #623
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Hmm, shouldn't matter really, but that's just based on my own feeble noodling. The ones on RockAuto spec the same part for every year. It appears that those parts are actually the camshaft adjuster magnet -- the position sensor looks different, and RockAuto doesn't even list those. But, the Google says:
    What are the symptoms of a bad camshaft adjuster?
    If the camshaft adjuster fails, the car will have trouble starting the engine, lack of power, and engine shaking.
    It seems you are getting readings, so the position sensors seem to be working, maybe. Maybe these adjusters are bad or not getting the signals they need?
    The VVT actuator/solenoid apparently looks like this:
    TACOTU3 likes this.
  4. Feb 23, 2024 at 5:00 PM
    #624
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I know there's a lot of pages, but the pics you are referencing are from the old motor. OP is trying to get a replacement motor to work now.
    Canadian Caber and koditten like this.
  5. Feb 24, 2024 at 12:01 AM
    #625
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    It’s like an aortic branch of wires coming out of the passenger firewall.
    koditten likes this.
  6. Feb 24, 2024 at 6:52 PM
    #626
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Those round thingies you posted are solenoids.
    @TeenBeeer posted a pic of the timing control oil valve (gear bolt). In the center of that bolt is a plunger. Check if plunger is moving.
    I would check the timing marks. If marks are spot on, replace intake gear bolts and solenoids from your blown engine. But you need to take a timing chain cover off.
  7. Feb 25, 2024 at 8:44 AM
    #627
    silverstr8p
    The solenoids you can see through the hole when you take the external cam sensors off have a different part number, so they must be different. We're going to remove the valve covers to see if anything else on the end of the cams are different. The pins on the center of the cam sensors do move in and out pretty smoothly.
  8. Feb 25, 2024 at 9:19 AM
    #628
    Vlady
    Issy, WA
    To clarify a few things.
    Those round things are not sensors, these are solenoids.
    Cam position sensors are on the top of the valve cover, where coils are.
    What you see through the hole is the timing control oil valve.
    The pin on the solenoid is pushing the plunger on the valve when ECM applys 12V.
    TACOTU3 likes this.
  9. Feb 25, 2024 at 12:29 PM
    #629
    Vlady
    Issy, WA
    Test the plunger movement. The plunger is opening/closing oil passages for retard/advance.
    There is the oil filter, but you need to remove the bearing cap to access it
  10. Feb 25, 2024 at 12:39 PM
    #630
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    This is pretty cool stuff: Especially the stuff in section b: VVT-i "Controller" and in section 3a. "When the engine stops": what happens with the timing for the next time.
    Borders on "Rocket Science" (IMO)
  11. Feb 27, 2024 at 8:46 PM
    #631
    silverstr8p
    ok, passenger side valve cover removed, here's what I have.
    It seems to me that I need to swap everything to the right of both cam chains from off the old motor, which I think means those are the things that actually vary the valve timing by moving the cams less than a tooth retarded and advanced as the computer dictates? We tried just swapping the hydraulic bolt thing in the center, but it didn't make much difference.
    We looked closely at the timing marks, and think the chain might be off by one tooth, though I can't really explain how that would've happened, since we haven't touched the timing chain, maybe the other guy did, or maybe it was in a wreck and jumped a tooth on impact? Not sure, but here's a closer look. It was hard to get the exact angle to show the timing marks.
    If we have to move the timing chains a tooth, is there a way to do it without pulling the whole front cover, which is painful? Maybe slacking up the adjuster system and seeing if it'll slip a tooth then tighten? I guess if we change the VVT adjuster things anyway I think we'd have to pull the cover?
    I think the cam sensors that actually tell the computer what position each cam is at are these little guys (which were from the original motor):
    They go in the two holes toward the left side of the valve cover (that aren't the spark plug holes):
    Marshall Man likes this.
  12. Feb 27, 2024 at 9:09 PM
    #632
    Vlady
    Issy, WA
    One tooth will do it.
    Do you have service manual reference for the timing marks? You need to check if the yellow links line up with notches on the cam gears. Note those small bumps on the bearing caps and long groves On the vvt gears. You may need to turn the engine for a few dozens of turns to confirm marks. You may need to pull the cover to see the crankshaft timing mark and how it is lining up with the red link on the chain and the 0° tick mark on the plate.
    I would stick a long screw driver into #1 cylinder and slowly rotate the crankshaft And keep checking 1st cylinder TDC and yellow marks. If dont line up after ~50 + turns, need to pull the front cover off and set the timing.
    @silverstr8p , here are marks
  13. Feb 27, 2024 at 9:26 PM
    #633
    Vlady
    Issy, WA
    looks like a brand-new engine. Damn, you did not forget to pour some oil into it.
    PoolFixer and 02TRDXTRA like this.
  14. Feb 27, 2024 at 9:33 PM
    #634
    silverstr8p
    I know it's missing the molasses color coating everything, but hopefully, even though it has around 115K miles, it should still run for awhile :)
    AMMO461 likes this.
  15. Feb 27, 2024 at 9:37 PM
    #635
    Vlady
    Issy, WA
    theoretically it is doable. You have access to the tensioner via a small cover to disengage it. However, you need to see the crankshaft gear mark. Actually, marks don't matter as longer as the number of links are correct between cam marks and the crankshaft.
  16. Feb 27, 2024 at 9:39 PM
    #636
    Vlady
    Issy, WA
    I'm surprised no one suggested to check your battery...
  17. Feb 27, 2024 at 9:43 PM
    #637
    Vlady
    Issy, WA
    depends how you look at. But it is still air, fuel, spark..
  18. Feb 28, 2024 at 5:05 AM
    #638
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    :rofl:
  19. Feb 28, 2024 at 9:25 AM
    #639
    AMMO461
    AMMO461 TACO/FJ/FJ
    SoCal Hi-Desert
    2021 TRD Off Road DCSB OD
    It looks like you have one of your left cylinder head VVTI controllers installed on your right side head and vice versa. (ie single short hash timing marks on one head, double hash timing mark indicators on other head) NOT single hash/double hash on the same head.
  20. Feb 28, 2024 at 11:33 AM
    #640
    Vlady
    Issy, WA
    The marks are present on both banks. On bank 1- single line is used, bank 2 - double line.
    Here is a better visual
    https://youtu.be/-rrim2E_ox8?si=UtCF81ZN0D4-meV8
