Rod knocking after pulling trailer up steep hill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by silverstr8p, Dec 21, 2023.
  1. May 8, 2024 at 3:25 PM
    #721
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Since you already there , check oil control valve filter. It is in the cam bearing cap
  2. May 8, 2024 at 4:24 PM
    #722
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Make sure it has oil and a clean filter?
    silverstr8p[OP] and TACOTU3 like this.
  3. May 8, 2024 at 7:38 PM
    #723
    Vlady
    Issy, WA
    Make sure marks on cams and the crankshaft do lineup (cylinder1 TDC).
    Not sure if you have access to the crankshaft timing rotor. Check if it is aligned correctly. 2 missing teeth should face the sensor at TDC
  4. May 9, 2024 at 8:55 AM
    #724
    silverstr8p
    silverstr8p [OP] Well-Known Member
    Yeah, we got the motor out and the flywheel off, thanks, will check.
  5. May 9, 2024 at 11:42 AM
    #725
    silverstr8p
    The crank reluctors seem to be the same, will verify their position relative to the peg.
    Okay, here's the bank 1 intake and exhaust setup:
    Here's bank 2:
    Here's the crank end:
    The overall chain:
    koditten likes this.
  6. May 9, 2024 at 12:05 PM
    #726
    silverstr8p
    It looks like both the crank and cam marks align at TDC.
  7. May 9, 2024 at 12:27 PM
    #727
    Vlady
    Issy, WA
    What bothers me that I see 11 rollers on small chain between timing marks on exhaust and intake cams.
    Should be 12 (middle of yellow link to the middle of the other yellow link).
  8. May 9, 2024 at 12:50 PM
    #728
    silverstr8p
    Guy who's did it saying "Oh so it's possible the chain needs to be flipped over and then re-timed? I could see that. Very interesting observation"
    Seems important to get it right. We'll be double checking. I'd like to drive the truck sometime this year.
    TACOTU3 and koditten like this.
  9. May 9, 2024 at 1:03 PM
    #729
    silverstr8p
    Here's another view of the smaller chain:
    bank 1
    bank 2
  10. May 9, 2024 at 1:12 PM
    #730
    Vlady
    Issy, WA
    Looks like chain markings are in the correct position/number if roller, but I don't see if phasers marks match small chain marking.
    I would rotate the engine a few 1 cylinder TDC cycles to make sure all your marks match
  11. May 9, 2024 at 1:34 PM
    #731
    silverstr8p
    He says every turn the relationship between the marks on the big chain and the smaller chains change. It looks like when #1 is at TDC, the marks on the big chain align right with the intake phasers' marks. Initially, all 7 yellow marks lined up, but he said they change over a couple revolutions of the crank.
  12. May 9, 2024 at 1:35 PM
    #732
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yeah, they should eventually line back up after several turns.
  13. May 9, 2024 at 2:05 PM
    #733
    Vlady
    Issy, WA
    You pretty much troubleshot all items on the list. Hopefully it will run. Are you still on replaced ECM?
  14. May 9, 2024 at 2:50 PM
    #734
    silverstr8p
    We replaced the ECM, ran about the same.
    Might have found another problem, don't think whoever worked on new motor put the crank reluctor on right, looks like it pushed in the alignment pin, which would explain a lot:
  15. May 9, 2024 at 3:00 PM
    #735
    silverstr8p
    This would explain why the truck ran terrible AFTER we got the crank position sensor wire fixed, meaning then the ECM wouldn't be in limp mode anymore, but it also wouldn't THINK the crank is in the right position and try to adjust, making the motor clear one code and then go crazy.
    Maybe we have three problems really: The reluctor not being in the right position, the bolts in the end of the cam phasers not being the correct ones, and the timing chain being off by a half tooth?
    02TRDXTRA, eurowner and Lt. Dangle like this.
  16. May 9, 2024 at 3:25 PM
    #736
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    Been following since the start. Sounds like you are on the right track. Hope you get it on the road soon.
    This has been one of the more interesting technical threads I've followed on here since joining.
    ThisBen, wombatz, koditten and 3 others like this.
  17. May 9, 2024 at 3:26 PM
    #737
    silverstr8p
    Glad to have you all. Again, this isn't about blame fixing, it's about wrenching on your trucks or helping someone else out :)
    koditten, nDub, Bob1971 and 3 others like this.
  18. May 9, 2024 at 3:28 PM
    #738
    Vlady
    Issy, WA
    How is it installed on your damaged engine?
  19. May 9, 2024 at 3:28 PM
    #739
    silverstr8p
    On the damaged engine it was fine, on the newer motor it was off.
  20. May 9, 2024 at 3:34 PM
    #740
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Good luck OP, you are awesome btw!
    Also, I love when a poster says they can't be bothered to read the thread then spends days arguing in it about dumb stuff.
