Rod knocking after pulling trailer up steep hill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by silverstr8p, Dec 21, 2023.
  1. Aug 13, 2024 at 5:51 PM
    #921
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Congrats and good job. Takes lots of patience and perseverance to go through all that for so long. It certainly went over the top when the new motor had its own fair share of issues to fix and I sure hope you got a fair price on it looking back at the trouble it was to deal with.
    I hope this doesn’t happen to me but eventually you have to expect to do at least an engine swap or something, since nothing lasts forever. I sure hope mine goes a lot smoother, but I wouldn’t be scared to attempt the swap. Clearly getting a good used one is paramount to finishing the job quickly. It’s a good thing you have multiple vehicles because how long this thing was down, could have been an even bigger headache.
    Glad to see this end positively. And maybe now more people will do their own oil changes.
    and definitely a huge kudos to @Vlady, impressive helpful input was shared by him continuously for sure.
    Canadian Caber and RustyGreen like this.
  2. Aug 13, 2024 at 6:07 PM
    #922
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    Bravo OP, absolutely epic!
    And @Vlady you the real MVP!
    Lawfarin and Superdave1.0 like this.
  3. Aug 13, 2024 at 6:13 PM
    #923
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Congrats!!
    I think the hardest part was to convince you to pull the engine for 2nd time.
    Also, it was a good insight on common trouble codes you pulled during the process.
    The thread should be a sticky for sure.
  4. Aug 13, 2024 at 6:14 PM
    #924
    YoshiMara
    YoshiMara I reject your reality and substitute my own
    2023 OR
    Amazing thread OP. Thanks for sharing and congratulations on being back on the road.
  5. Aug 13, 2024 at 6:24 PM
    #925
    Vlady
    Issy, WA
    Just tow to his place..
  6. Aug 13, 2024 at 6:58 PM
    #926
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I would have committed seppuku long ago..well done!!
  7. Aug 13, 2024 at 8:09 PM
    #927
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    To sum things up, the main issue was the crank shaft reluctor wheel?
  8. Aug 13, 2024 at 8:14 PM
    #928
    BLtheP
    Plano, TX
    Seemingly that and wiring issues in the harness that came on the used motor. And probably more.
    Superdave1.0[QUOTED] likes this.
  9. Aug 13, 2024 at 8:21 PM
    #929
    Vlady
    Issy, WA
    Someone butchered the reluctor wheel. The other were trying to "fix" by playing with CPS wiring and the sensor.
    Chew and Superdave1.0 like this.
  10. Aug 14, 2024 at 2:37 PM
    #930
    silverstr8p
    silverstr8p [OP] Well-Known Member
    Running a few days now with zero issues, have to get used to not driving a diesel again, hoping to refill gas tank with gas from this year, I imagine that will help.
    The guy I got the engine from had it in and out a couple times before the Toyota guy let him know he needed a non-vacuum motor, this one was a vacuum. So they tried to make it a non-vacuum motor by plugging the hole, which didn't work. I don't think they ever knew the crank reluctor was off, and I also don't know how they got it off by one, since there's an alignment pin. Then they screwed with the timing components to try to make it work, and one bank was off by a tooth. Also, the hollow bolt thing in the end of the cam sprocket controls advance, and it didn't match the solenoid on the outside of the engine. All that means it could've never run right, but it did sorta run. I think the guy that had it played with it for awhile and got tired of it.
    Interestingly, we didn't so anything to the tranny besides bolt it up and add fluid, the computer didn't complain.
    I still have no idea why the old torque converter was so hard to slide, suggesting the tranny oil pump bearing had issues, but I don't know why. The old tranny shifted fine, just leaked. New one only has 15K on it though, so should have some life left in it. New motor had around 115K, so I hope to get 150K or more out of the truck, drive it until the wheels fall off or get hit by some guy texting, that's how most wrecks happen these days.
    Dog: Sheepadoodle. And part freak. She runs a minimum of 1.5 miles per day on our driveway next to the taco, weekends she'll do 10+ miles beside truck doing 15-20mph. She's a good girl, with me 90% of the time :)
    Side rant: I get annoyed at those car build shows where they restore a classic Mustang from the ground with a new crate motor up in a 20 minute show and they're doing paint and then selling it for $75K. That's rubbish. The reality is lots of nights in the garage sweating it out. End of rant.
    YoshiMara, mlcc, bfonic and 10 others like this.
  11. Aug 14, 2024 at 10:42 PM
    #931
    Vlady
    Issy, WA
    Do you think you might damaged it while removing the engine and fixing the transmission connectors multiple times?
    SM does warn about it..
    I dig matching car colors dogs.
    Here is my doodle
    Chew, TACOTU3 and RustyGreen like this.
  12. Aug 15, 2024 at 7:06 AM
    #932
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    A miniature? This is Winnie - labradoodle
    RustyGreen, Chew and TACOTU3 like this.
  13. Aug 15, 2024 at 7:18 AM
    #933
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    As the 2023 TacomaWorld Trophy Points - Runner Up, with a collective 0 trophy points, I hereby declare that mods give you the most trophy points for the 2024 calendar year.
    Seriously, this thread has been for us truck-dudes what I can only assume a murder/mystery/romantic novel is for our lady friends - truly captivating, ups and downs, plot-twists, and a damn good happy ending. You deserve many truly heartfelt congrats :cheers:.
  14. Aug 15, 2024 at 8:24 AM
    #934
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Mini Goldendoodle postings is a fantastic way to wrap this incredible thread up with. Here's mine after a recent grooming. FB_IMG_1722864550816.jpg
    RustyGreen, Chew and Dbarffish like this.
  15. Aug 15, 2024 at 10:13 AM
    #935
    Vlady
    Issy, WA
    I think a hybrid. We were told he will be up to 40 lbs.
  16. Aug 15, 2024 at 10:18 AM
    #936
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Remarkable news! Congratulations on finally getting this very difficult project completed.
  17. Aug 15, 2024 at 10:31 AM
    #937
    Canadian Caber
    Les
    B.C. Canada, eh
    Hmmm..... In the end I wonder if @Buttskevin21 fully disclosed to you all the potential issues the used engine had due to his re-working of the Vacuum engine? He seemed to coincidently disappear from this site after that.
    Marshall Man likes this.
  18. Aug 15, 2024 at 10:54 AM
    #938
    silverstr8p
    I don't blame the engine seller, after all I got it for 1k, so I really can't complain, and also don't know who all worked on it. He probably doesn't know what all they did. He just realized he didn't get a non-vacuum engine.
    I think it's likely the transmission was damaged somewhere along the way, but it still had 177K miles, so getting one with 15K seemed like a good idea regardless.
    Love the doggies, we should be the people they think we are :)
  19. Aug 15, 2024 at 11:09 AM
    #939
    545
    545 Well-Known Member
    2015 Access Cab
    Yeah, I don’t think he really worked on it himself
    Bought it used, someone had done something, then Toyota dealership worked on it and then it went to you
    If he knew about the issue and disclosed it it would have still been worth $1000, so no real reason for him to hide it
    Canadian Caber likes this.
  20. Aug 15, 2024 at 11:16 AM
    #940
    ABA180
    East Bridgewater MA
    If people were half as genuine as animals....my 3 cats are my life
