Rod knocking after pulling trailer up steep hill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by silverstr8p, Dec 21, 2023.
  1. Jan 5, 2024 at 12:26 PM
    #121
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Oops! Fixed.
  2. Jan 5, 2024 at 1:16 PM
    #122
    MGMDesertTaco
  3. Jan 5, 2024 at 3:09 PM
    #123
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    :boink:
  4. Jan 5, 2024 at 3:33 PM
    #124
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Ain't this just a pretty little thing?
  5. Jan 5, 2024 at 3:37 PM
    #125
    alwaysHI
    2017 MGM DCSB
    Very clean tho. Props
    Looks like even kept the a/c - such a must
    Mully[QUOTED] likes this.
  6. Jan 5, 2024 at 4:41 PM
    #126
    silverstr8p
    silverstr8p [OP] Well-Known Member
    I just put the tranny in auto going up the hill, maybe half throttle, then on downhill move to manual shift to compression brake.
    Got sidetracked, but going to pull the caps soon, get some pictures of the main/rod bearings. Mechanic said he thinks he saw some main/rod bearing material in the pan which makes sense.
    Talked to another mechanic friend who suggested doing a motor swap from a wrecked donor truck with 50K miles on it, freshen up the engine.
    What do you all think? If I get the sludge cleaned out and look at the valvetrain to look for issues, is it better to put bearings in it where I *know* the condition of the engine, or bet on what a donor rig engine has happen to it?
    What's a high mileage on these motors before I'm *supposed* to start having issues like blowby or smoked heads or something?
    japjoe7 and SR-71A like this.
  7. Jan 5, 2024 at 4:44 PM
    #127
    MGMDesertTaco
    After 177k on the old motor I'd swap for the one with 50k.
  8. Jan 5, 2024 at 5:03 PM
    #128
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Swap.
    Dbarffish likes this.
  9. Jan 5, 2024 at 5:11 PM
    #129
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Depends on how risky you're willing to live. If it were me and I had a warm shop to work and there was no catastrophic failure of the bottom end or damage to the crank and I had the time, then I would just change the bearings and carry on.
    If one of those conditions were not met and/or I wanted a quick and sure fix, I would drop in a low mileage engine and maybe keep the old one as a spare. Emphasis on maybe
    po35042 likes this.
  10. Jan 5, 2024 at 5:14 PM
    #130
    silverstr8p
    I rebuilt a smoked Jeep 4.0 motor that had around 150k on it, but then I *knew* what I had, fixed any issues, verified the crank and block were cool, put sealed power parts in it and the thing ran great for another 60K miles until I sold it.
    This motor is far more complicated, but cranks are cranks, etc.
    Yossarian and koditten like this.
  11. Jan 5, 2024 at 5:14 PM
    #131
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i would spring for the low mileage given the build up inside that engine.
    PoolFixer, Yossarian and Mully like this.
  12. Jan 5, 2024 at 5:40 PM
    #132
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    These engine blocks have almost no room for overboring if there is liner damage. And judging by the pictures, you might not know what this engine has been through and you have owned it since day 1. I would consider a low mileage swap engine. But I would still want to know where the failure point was and how bad the old engine was to see if I could not repeat it.
    I am curious, what did the oil look like when you drained it? What did the filter look like?
    TacoSR523 and Junkhead like this.
  13. Jan 5, 2024 at 5:46 PM
    #133
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    There are a lot of factors to consider.
    In favor of a replacement engine with a warranty: People crash these trucks every day so they are out there, a low mile engine should offer good service.
    The job would be done quickly but at a high up front price.
    On the other hand if your current engine didn't have blow by or excessive oil consumption one could *assume* that it wouldn't have those issues when the bearing clearances were corrected.
    "Back in the old days" (after dinosaurs went extinct but we still had carburetors) ;) I freshened up old engines with:
    a timing set
    oil pump
    front & rear seals
    valve stem seals
    valve cover, base pan & timing cover gaskets
    water pump
    I would Plastigage the bearings and replace if needed, maybe "polish" the crank surfaces with some fine sand cloth. The pistons were never disturbed.
    These weren't beat, knocking, oil burner engines, just "tired" ones with some leaks and lower than desired oil pressure.
    Cleaning, new seals and gaskets fixed the leaks and improved engine vacuum which makes the engine run cleaner & smoother.
    Replacing the oil pump and maybe some bearings got the oil pressure back up.
    The timing set made them run smoother because the cam and distributor was now back in sync with the crank.
    It wasn't a rebuilt engine, just a smoother, better running, not leaking old engine - ready for several more years of getting you to work every day for not a lot of money.
    These were low revving domestic, cast iron inline 6 and V8 engines from another time, I'm not sure if it applies any more. If you are up for a project maybe give it a try. :notsure:
    Man, do I feel old...
  14. Jan 5, 2024 at 5:54 PM
    #134
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    Well, short drives where the engine doesn’t fully warm up are not good. I question your math. If you only drove a few miles a day, how long did it take to get it to 160k?
    Junkhead likes this.
  15. Jan 5, 2024 at 5:55 PM
    #135
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d go with a low mileage swap.
    I wasn’t big on your idea of replacing just the bearings to begin with.
    Just replacing bearings is a “cheap” way out. And it usually doesn’t work.
    Not in a modern day car/truck engine.
    You can do what ever you like, but you’ve already taken the engine out
    At this point, do a full rebuild or low mileage swap. I’d go swap.
    jerrybear likes this.
  16. Jan 5, 2024 at 6:23 PM
    #136
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    No need to feel old. I did the same refresh on several engines of the older domestic V8 variety. It was easy and cheap. The engines lasted well into the 300,000kms range. I even pulled the pistons, ran a hone through the cylinder and put in new rings.
    One of these engines even ran as a drag engine in a Mustang. Engines were a lot simpler then.
    Junkhead, khax and RustyGreen[QUOTED] like this.
  17. Jan 5, 2024 at 6:26 PM
    #137
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :fistbump:
    Life was a lot simpler then...
  18. Jan 5, 2024 at 6:44 PM
    #138
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    It seems like you have the resources and knowledge to go through this engine and get it back on the road. Assuming time is not a huge issue for you AND more importantly assuming you find out exactly what went wrong, Id keep this one. Just me and my tendencies
    Don't necessarily think a swap is a bad route to take, but you'll want to verify the new engine. This thread has kind of proved that service records aren't always a good barometer
  19. Jan 5, 2024 at 6:50 PM
    #139
    Bill0351
    Bill0351 Well-Known Member
    Bill
    2023 SR V6 4x4
    Tires/Cap
    Do the swap! I think the existing engine has too many unknowns. The engine swap is too complex to want to do it over after possibly finding out the current engine has deeper unknown issues.
  20. Jan 5, 2024 at 8:27 PM
    #140
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    In case you are thinking about sending the oil to Blackstone, they just told me that they currently have an 18-20 day lead time.
