Rodent chewed a hole in my vent hose. Dealership says only fix is new fuel tank?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by academeplanar5e, Mar 29, 2025.
  1. Mar 29, 2025 at 8:54 PM
    academeplanar5e
    academeplanar5e [OP] New Member
    2012 Toyota Tacoma 4WD TRD Off Road Double Cab V6 AT
    Advice/suggestions requested... So, I finally broke down and took my 2012 4L,V6/AT/4X4/TRD Off-Road to the dealership after a year of unsuccessful attempts to get rid of po455 & po4441 codes.
    Apparently, a rodent has chewed a hole in the vent hose and according to the dealership, the only fix is a fuel tank replacement ($2000 parts + labor), due to the fact that Toyota does not make a vent hose replacement part since, it is permanently attached to the fuel tank.
    I am not a mechanic by any stretch but, this seems a bit drastic.
    I've heard that homeowners insurance (Comprehensive) covers rodent damage-related repairs (After deductible), so that may be an option, as well. But, insurance companies have "Maximum Allowable" costs for parts & labor that are like 25% of what shops charge for this repair - With the customer being responsible for the difference + they require the use of a junkyard fuel tank. So, I would end up paying 75% of the repair and end up with a fuel tank of questionable quality, which I'm not really all that comfortable with, considering that my current fuel tank is oem & in perfect shape.
    Additionally, I've talked to a couple of local shops that don't seem to have a problem with just replacing the oem hose with an aftermarket hose for around $350 (Parts+labor). What am I missing, here?
  2. Mar 30, 2025 at 10:27 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I'd have the hose replaced rather than the tank. I think the Stealership is going overboard. Of course they may also have their hands tied by Toyota to replace only complete parts as supplied by Toyota.
    If you have space to DIY dropping the tank isn't that hard to do, plenty of instructions here on TW. Just pay attention to do it with a empty, or close, tank as gas weighs about 7 pounds a gallon.
  3. Mar 30, 2025 at 10:30 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Which hose? Got any Pics??
  4. Mar 30, 2025 at 10:32 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I had problems with the squirrels also, they chewed my wiring harness and the dealer wanted $1400 for repair. Dealer said policy calls for total replacement of harness. I chose independent shop for splicing and it was $150.00.
    academeplanar5e[OP] and wilcam47 like this.
  5. Mar 30, 2025 at 10:46 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Entirely depends on what part of the hose is chewed. Hard plastic hose molded to the top of the tank? Section of hose farther up the line somewhere?
    It may be repairable with some rubber hose, clamps and creativity. There isn't any fuel pressure in those lines, just fuel vapor and a bit of vacuum.
    I wouldn't necessarily have a problem with a used tank. As long the guy installing it knows how to recognize if it's damaged or not.
    The dealer isn't the end all for these types of things. They can't think outside the box (or aren't allowed to..). If a component is broken it gets a whole new replacement, no matter if it's $200 or $2,000.. We see this a lot with minor wiring harness damage. Couple damaged wires? It gets a whole new harness for $2k.
    They love to throw up big prices because they're hoping you'll trade it for a new 2015 Trailhunter. They don't have your best interests in mind..
    academeplanar5e[OP] and Dm93 like this.
  6. Mar 30, 2025 at 10:46 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Depends where the hole is, if it's in the middle of the hose you can fix it with a piece of fuel vapor rated rubber hose of the appropriate size but if it's the fitting on the tank that's chewed off then you will likely need a tank.
    I'd look for a used one first if that's the case.
    academeplanar5e[OP] likes this.
  7. Mar 30, 2025 at 10:49 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Cut the hose, and add a vacuum/smog connector. Cheap fix, you can pick up a package of them with different sizes for a few bucks. Good luck with your truck.
  8. Mar 30, 2025 at 3:09 PM
    academeplanar5e
    wilcam47 Thx for the suggestion! Edited my original post to include video.
    BKinzey likes this.
