Rogue Offroad Poly Body Mount Kit Group Buy -- Closed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Apr 25, 2022.
  1. Aug 26, 2022 at 5:34 AM
    #201
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    Guess I'll be the first then. Did the install after work yesterday. It was kind of the bitch I thought it would be, but I do have a few extra things on my truck that complicates the process. It would be a bit faster on a stock truck.
    The 4 cab bushings were in perfect condition and likely would have lasted a long time, but the two front radiator ones were already shredding apart and my truck only has 50k in it. I'm glad I changed those. The good news is, if I ever did need to change them again those were by far the easiest to swap out.
    I took a picture of this weird foam block under the driver's side carpet that you'll need to remove. It just unscrews.
    I had to use a bunch of cut 2x4 pieces to be able to lift the body up. This would be so much nicer to do on a lift. Also, it's a really good idea to disconnect the abs sensors up front as they will stretch and break if you lift the body too high.
    If you have a seat delete platform it's gotta come out. I was able to unbolt mine and slide it forward a little bit. Those 2 bolts at the rear of the cab were a bitch to get to.
  2. Aug 26, 2022 at 6:36 AM
    #202
    Abject4x4
    Abject4x4 Just another idiot on the internet
    Marcus
    White SR5 Access Cab
    I have a steel front bumper, so changing the rad mounts is going to be a breeze. Not looking forward to pulling out the ones inside the cab though.
    I'll probably start with the fronts and do the others on a nice Fall day.
    MountainManGuy likes this.
  3. Aug 26, 2022 at 6:54 AM
    #203
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Yeah! Looking good!
    Thanks for jumping in and posting up pics. Please let us know how it drives and if things are quiter.
    :cheers:
  4. Aug 26, 2022 at 7:38 AM
    #204
    MountainManGuy
    Colorado
    Will do. I actually haven't driven it yet since I put them on last night so I'll go for a drive today and let you guys know
    tonered[QUOTED][OP] likes this.
  5. Aug 26, 2022 at 8:03 AM
    #205
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Installed the other night, pretty straight forward. Did one side all at one time, so I could jack the entire cab up a couple inches (to the limits of the abs wires, which actually have a pretty high tensile strength :rofl:)
    Huge improvement in my opinion, way less cab-bed movement. My truck already squeaked and growned, but a little increase in those noises. Going to drive it for another day or two and recheck/tighten everything. Probably should have put antisieze/grease on all the bushings, but I forgot to
    MountainManGuy and tonered[OP] like this.
  6. Aug 26, 2022 at 8:06 AM
    #206
    tonered
    tony
    Lynnwood, WA
    Great to hear.
    Yours saying that you are hearing more sounds now?
    I found the tensile limit of an ABS wire on a friend's 4Runner. :facepalm: The splice is holding though, thankfully.
  7. Aug 26, 2022 at 8:15 AM
    #207
    MountainManGuy
    Colorado
    To add to this, also a good idea to remove your fender liner splash guards or whatever they are called in the front wheel whells. Mine actually ripped off when doing the install. It's amazing the ABS wires didn't also break..
    ROGUE OFFROAD and tonered[OP] like this.
  8. Aug 26, 2022 at 4:29 PM
    #208
    ROGUE OFFROAD
    ROGUE OFFROAD Well-Known Member Vendor
    Shawn
    Yes definitely unplug the ABS wires at the frame and body connection . Thats a big tip that we have forgotten and has cost us a few times .
  9. Sep 1, 2022 at 9:00 AM
    #209
    jayrome
    jayrome Well-Known Member
    2020 Tacoma TRD Off Road - DCLB
    King 2.5 Front Ext Travel Coilovers with Adjusters and SPC UCAs King 2.5 Rear Ext Travel with Adjusters 17" Method NV Wheels BF Goodrich K02 275/70/17 RCI Steel 3 Pc. Skids and Diff Cover All Pro Rock Sliders Victory Strike Front Winch Bumper with Warn Evo 10K Twin ARB Compressor with Rago Mount Wifey Air System
    Would be interested if you guys do this again
    tonered[OP] likes this.
  10. Sep 1, 2022 at 2:54 PM
    #210
    the.shelbysaurus
    the.shelbysaurus Well-Known Member
    Colorado Springs, CO
    2019 Cavalry Blue SR5 4x4 ACLB
    Ironman 4x4 Foam Cell Pro, SPC UCAs, 285/70/17 KO2s, 1.25" Spidertrax spacers
    Saaame. I'm kicking myself for not just ordering it while the GB was happening :annoyed:
  11. Sep 1, 2022 at 3:36 PM
    #211
    tonered
    tony
    Lynnwood, WA
    i can add you folks to the 1st Post if @Despized wants to do another?
  12. Sep 1, 2022 at 3:48 PM
    #212
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  13. Sep 1, 2022 at 9:57 PM
    #213
    the.shelbysaurus
    Sure. Thanks!
  14. Sep 2, 2022 at 9:39 AM
    #214
    jayrome
    Sounds good
  15. Sep 8, 2022 at 1:31 PM
    #215
    ROGUE OFFROAD
    Shawn
    Im down to do another ROUND. Has to be a 15 unit minimum
    tonered[OP] and drizzoh like this.
  16. Sep 8, 2022 at 1:34 PM
    #216
    tonered
    tony
    Lynnwood, WA
    Thanks!
    I will add the folks to a new list in the 1st Post.
  17. Sep 8, 2022 at 2:33 PM
    #217
    Lateralus01
    Lateralus01 Well-Known Member
    2018 Cement Tacoma TRD OR DCSB 4x4
    Please add me for the next group buy also. Thanks in advance.
  18. Sep 8, 2022 at 2:37 PM
    #218
    tonered
    tony
    Lynnwood, WA
    Thanks!
    I added you.
    Lateralus01[QUOTED] likes this.
  19. Sep 9, 2022 at 11:49 AM
    #219
    tonered
    tony
    Lynnwood, WA
    Lateralus01 likes this.
  20. Sep 9, 2022 at 3:14 PM
    #220
    jayrome
    Guys, I'm going to need to drop out. I need to buy some bushings now and can't really wait for the group buy to stack up. Thanks
