Rogue Offroad Poly Body Mount Kit Group Buy -- Closed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonered, Apr 25, 2022.
  1. Oct 13, 2022 at 1:41 PM
    #301
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Little review, been running these and poly motor/trans mount for the last month. Vibrations were moderate, but what the main problem was, is that my sliders were bent up into my pinchweld thus making the cab "solid mounted". Chopped sliders off last night, and truck is pretty dang quiet with no sqeaks or vibrations. Pretty good for all poly
    msgs350 and tonered[OP] like this.
  2. Oct 13, 2022 at 1:45 PM
    #302
    tonered
    tonered [OP] bartheloni
    tony
    Lynnwood, WA
    Oh wow.
    Yeah. On concrete highways, my Taco seems to be quieter, which was a surprise.
  3. Oct 13, 2022 at 6:08 PM
    #303
    Mindgame
    Mindgame Well-Known Member
    22' Offroad limited
    Decals removed
    Throw my name on there
    Lateralus01 and tonered[OP] like this.
  4. Oct 13, 2022 at 6:54 PM
    #304
    tonered
    tony
    Lynnwood, WA
    Thanks!
    Lateralus01 likes this.
  5. Oct 15, 2022 at 9:44 AM
    #305
    Metric Rider
    Metric Rider Well-Known Member
    Gar
    Valley Farms, AZ
    2017 Tacoma TRD Sport
    Body Armor Front Bumper, Smittybilt XRC 9.5 GEN2 Winch, Fab Fours rear bumper, 400 watt inverter anytime, Front camera, On-board ARB air compressor.
    Weekend bump, 3 more people needed :fingerscrossed:
    tonered[OP] likes this.
  6. Oct 15, 2022 at 11:19 AM
    #306
    tonered
    tony
    Lynnwood, WA
    Thanks!
    :cheers:
  7. Oct 16, 2022 at 11:06 PM
    #307
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Installed today with help from @jayrome . Took a little longer than expected and we had to float the cab a bit to get the bolts lined up but its done.
    gonna drive it tomorrow to see if I can notice the difference.
    tonered[OP] and daveeasa like this.
  8. Oct 17, 2022 at 5:22 AM
    #308
    tonered
    tony
    Lynnwood, WA
    Great to hear!
  9. Oct 17, 2022 at 6:23 AM
    #309
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Yeah, lemme know how it drives. I’m curious if I ever do mine.
  10. Oct 17, 2022 at 7:54 AM
    #310
    jayrome
    jayrome Well-Known Member
    2020 Tacoma TRD Off Road - DCLB
    King 2.5 Front Ext Travel Coilovers with Adjusters and SPC UCAs King 2.5 Rear Ext Travel with Adjusters 17" Method NV Wheels BF Goodrich K02 275/70/17 RCI Steel 3 Pc. Skids and Diff Cover All Pro Rock Sliders Victory Strike Front Winch Bumper with Warn Evo 10K Twin ARB Compressor with Rago Mount Wifey Air System
    UPDATE: Ultimately what took care of the issue was removing the bolt, bottom washer, bottom bushing and the sleeve, making sure everything was clean and greased, then reinstalling. The top washer between the body and the top bushing was misaligned a bit, so we did lift just a smidge to align that. After torquing it back down, so far no noise in the one that was creaking
  11. Oct 17, 2022 at 7:59 AM
    #311
    jayrome
    Good times!
    It's interesting that the install went pretty much how mine did. The driver's side front-most bushing location was the main issue. The bolt hole on the cab was out of alignment on both trucks when trying to install the bolt and sleeve through the bushing. Not surprising that the OEM bushing in that location was the one with the side wear issue. The entire problem with the OEM bushings (besides the fact that they are shitty to begin with) is that this misalignment causes the wear on the side of the bushing that causes the dreaded sound that brought us all here. Passenger side front-most bushing had no side wear and the holes were fairly aligned.
  12. Oct 17, 2022 at 8:01 AM
    #312
    daveeasa
    David
    PNW
    I wonder if a TSB might ever come from this? Like the 3rd brake light TSB? I guess noise isn’t enough of a concern to justify corrective action.
  13. Oct 17, 2022 at 8:13 AM
    #313
    tonered
    tony
    Lynnwood, WA
    Great to hear.
    Interesting problem though, as the sleeve rides on the bottom of the washer. Alignment shouldn't create noise, but that is just me spitballing.
    Right on. My guess is that there is too much adjustability in the rear four mounts. I was surprised how well everything lined up with these new mounts that have almost no play for adjustment. Prior to this, I was half wondering if the cab to frame locations were somehow tooled incorrectly. Just the shitty OE mounts. All six, IMHO.
    I doubt it. This has been an issue since at least 2005. I don't have much info on the 1st Gens.
    daveeasa[QUOTED] likes this.
  14. Oct 17, 2022 at 8:24 AM
    #314
    jayrome
    That would be logical right? Somehow though, there was wear on out the OUTSIDE of the edge of the sleeve. My guess is that I just didn't seat it correctly, or that combined with the misaligned washer. Not sure I'll ever know, but it's done now!
    tonered[QUOTED][OP] likes this.
  15. Oct 17, 2022 at 8:31 AM
    #315
    tonered
    tony
    Lynnwood, WA
    That is crazy, but I'm glad that it is sorted. Hopefully for the life of the Taco.
  16. Oct 17, 2022 at 8:40 AM
    #316
    jayrome
    I'm pretty confident that it was install related. The bushings are super solid and I'm super confident that this issue is probably done for the life of the Taco! Highly recommend doing this upgrade
  17. Oct 20, 2022 at 12:44 PM
    #317
    tonered
    tony
    Lynnwood, WA
    Bumpin' to get this 2nd Round closed out.
    Thanks!
  18. Oct 21, 2022 at 7:47 AM
    #318
    Lateralus01
    Lateralus01 Well-Known Member
    2018 Cement Tacoma TRD OR DCSB 4x4
    Getting so close! 3 spots left to hit the goal.
  19. Oct 24, 2022 at 9:49 AM
    #319
    tonered
    tony
    Lynnwood, WA
    I'm kinda bummed that you guys are stuck waiting. I might suggest that folks on the list reach out to folks that you know to get this puppy moving?
    On my side, the more that I drive my Taco with these poly bushings, the more I love them. No more squeaking like when the stock PoSs got wet. They solved issues that I guessed that I had. Haha!
    Thanks!
  20. Oct 24, 2022 at 9:56 AM
    #320
    Lateralus01
    Too bad we can't take credit for those above and beyond the original 15 needed.
