Role of O2 sensor 1996 2.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by irhunter, Dec 14, 2021.
  1. Dec 14, 2021 at 1:18 PM
    irhunter
    irhunter [OP] Well-Known Member
    Maine
    '96 2WD 5-sp 2.4 Tacoma and '03 4WD AT 4.7 Tundra
    My O2 sensor studs recently rusted away and the whole unit is just hanging in the air by the wires. It is, of course, kind of loud right now...but, otherwise the truck seems to run just like it always did. Not even a CEL.
    Now, I guess I thought the O2 sensor provided one of data streams for the engine management. But, now, I wonder what it's actually doing.
    Roy
  2. Dec 14, 2021 at 2:59 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your check engine light bulb lights up with the ignition switch in the on position??
    Yes indeed it should trip a code
    It might be a two trip code to cause the light to light.
    Don`t leave it hang you will be fixing wires as well
  3. Dec 14, 2021 at 3:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    Is there just one post cat sensor on a 96?
  4. Dec 14, 2021 at 3:35 PM
    irhunter
    Maine
    This is a nice description of the O2 sensor function:
    http://www.autotap.com/techlibrary/understanding_oxygen_sensors.asp
    Copy...not letting it hang any more.
    It fell out while driving, I went another couple miles, was out of the truck all day, drove it home...6 miles.
    This is the one bolted into the downpipe...before the cat.
    I will check for a CEL-at-start tomorrow.
    I suspect no one will be able to say what the impact on MPG would be without the sensor installed.
    Thanks for the responses.
  5. Dec 15, 2021 at 8:49 AM
    irhunter
    Maine
    Yup...as predicted, the CEL has come on.
    Bivouac likes this.
  6. Dec 15, 2021 at 3:50 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Which sensor was it? Before or after the catalytic converter? If it's the post cat sensor then it's only job is to monitor catalyst efficiency. It has no impact on fuel trims\maps. That's all done by the front O2 sensor, before the cat.
    Edit: nvm, but the info is still relevant.
  7. Dec 15, 2021 at 4:03 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    My 96 3RZ had pre and post sensors
  8. Dec 15, 2021 at 4:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    That thing will be "reading" a bunch of fresh air hanging out like that. Expect fuel mileage to suffer
  9. Dec 15, 2021 at 4:29 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    See post 4
  10. Dec 15, 2021 at 4:31 PM
    Murd3rd
    Ah shit, guess I skipped over that statement. My bad.
  11. Dec 15, 2021 at 4:32 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I feel bad for these salt belt guys.. sensors falling out?!? Wtf
    Murd3rd likes this.
  12. Dec 15, 2021 at 4:59 PM
    Clearwater Bill
    Billy
    Largo Florida
    Makes sense.
    96 was a transition year to OBDII for most marques.
    The post cat sensor was pretty much just to indicate if the cat had failed.
  13. Dec 15, 2021 at 6:13 PM
    Bivouac
    You have no idea my new steel on the rack inside rusts just from the damp climate
  14. Dec 15, 2021 at 7:09 PM
    irhunter
    Maine
    I went ahead and reinstalled the sensor. Turns out, both nuts rusted off and one of the studs is considerably shorter than it once was.
    It was the front one...on an OBDII, 2.4, litre I4.
    Maine is terrible for rust. There are guys replacing brake lines on three year old trucks!
  15. Dec 19, 2021 at 7:17 AM
    irhunter
    Maine
