Rolled Engine
Discussion in 'Technical Chat' started by natgaseng, Jan 23, 2015.
  1. Jan 23, 2015 at 1:27 PM
    natgaseng
    natgaseng [OP] New Member
    D
    CO
    Tacoma
    lift kit
    I have a 1999 3.4 L engine out of a rolled 4runner (98K) miles. What should be done before installing it in another 4runner?
  2. Jan 23, 2015 at 1:29 PM
    Large
    Large Red
    Remove plugs and crank it over for a few seconds to see if anything shoots out. Dunno about anything else.
  3. Jan 23, 2015 at 1:57 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    This. It may depend on how long it ran upside down. It could have bearing damage, or coolant or oil in the combustion chamber. It depends on what kind of hit the actual engine took. It may be fine; it may be damaged internally.
  4. Jan 23, 2015 at 2:06 PM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    I'd treat it like a flooded engine honestly.
    Pull the plugs, drain the fluids, ensure all possible moisture (coolant, oil) is out of the engine.
