Roller rockers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bandit, Aug 23, 2009.
  1. Aug 23, 2009 at 3:02 PM
    Bandit
    Bandit [OP] Well-Known Member
    North Charleston, SC
    2007 Tundra CrewMax 4x4
    Leveling kit, 295/75r18 nittos, banks exhaust
    Redacted
  2. Aug 23, 2009 at 8:06 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You won't get "more power" results from going to roller rockers, if they even make them for the 1GR
  3. Aug 23, 2009 at 8:21 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    not sure if you have a 2nd gen or 1st gen.the 2nd gen is a dohc wich does not use rocker arms they are mostly used on pushrod engines.the only time you see rocker arms on ohc engines is when its a single ohc engine.and i'm pretty sure the 1st gen engines are dohc engines also.
  4. Aug 23, 2009 at 8:34 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    rockers on v8s are a sorta lever, cam pushes a pushrod then the rocker, rocker opens the valve. most dont have rollers, so they mak some hp by having less friction. also they usually increas the ratio so the valves open up more.
    I really dont know if we have em , i think were overhead cams... no rockers.
  5. Aug 23, 2009 at 8:46 PM
    jfr02
    did alittle looking around on the web and as i thought both tacoma v6 engine are dohc.they have four cams total 2 for each cylinder bank.wich means one cam opperates your intake vales and one takes care of the exhaust valves.they cam lobes on these engines directly open your valves.so your v6 does not use roller rockers.
  6. Aug 23, 2009 at 9:00 PM
    Tacoyota
    08 4wd
    if you say roller rockers, throttle body, and rv cam in a sentence here the moderators might ban you:D
    OOPS
  7. Aug 29, 2009 at 8:11 AM
    Bandit
    good to know!! my buddy has a 69 camaro pacecar edition and was trying to teach me some stuff... thanks for the info.
  8. Aug 29, 2009 at 8:38 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Toyota seems to like the OHC design in the trucks. I don't know it the 5.7 is a OHC design or not though.
