Rollover rescue 05 tundra
Discussion in 'Other Builds' started by Empty_Lord, Feb 1, 2019.
  1. Mar 27, 2020 at 8:00 PM
    #201
    Running Board Man
    Running Board Man Well-Known Member
    They actually made a 3rd gen tundra? I always just thought it was a redesigned 2nd gen
  2. Mar 27, 2020 at 8:14 PM
    #202
    Empty_Lord
    Empty_Lord [OP] Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    it is... but its called a 3rd gen tundra.. dont ask me why.
    same goes for the 3rd gen taco. its still a 2nd gen skeleton just different front end and powertrain (you can swap 3rd gen taco body parts onto a 2nd gen, same for tundras)
  3. Mar 27, 2020 at 8:25 PM
    #203
    Running Board Man
    Didnt think about the 3rd gen like that but yeah
    Slashaar likes this.
  4. Mar 27, 2020 at 8:36 PM
    #204
    Empty_Lord
    Dan
    Going to try and do the AAL this weekend. I also need to do some measuring and get shorter gas struts so i can still reach the rear glass... once its lifted in the back i'll have to jump to close it as it sits...
    oh and i have 100W halogens to install with a harness and the main engine bay harness to also swap over so all the trailer shit works... then its onto the interior blackout project.
  5. Mar 28, 2020 at 9:17 PM
    #205
    Empty_Lord
    Dan
    Extended brake line and Rear AAL installed. i'll grab pics of it sitting when i put it back on the ground. ran out of steam and taking a break offically a 6 pack leaf with overload.. hopefully she has a slight rake and tows well like this.
    [​IMG][​IMG][​IMG][​IMG]
  6. Mar 29, 2020 at 1:13 PM
    #206
    Empty_Lord
    Dan
    working on the body harness today... half way out.
    NEW [​IMG]
    old coming out
    once this is all installed the trailer shit should 100% work. i have to straighten out the hitch where the 7 way goes. but thats easy.
  7. Mar 29, 2020 at 6:33 PM
    #207
    Empty_Lord
    Dan
    Old (top) new (bottom)
    [​IMG] And she went in without much fuss, replaced all the broken clips too. So far everything seems to work, so this truck has officially been retrofitted with the tow package (sans the factory hitch)
    And with the AAL in the rear + retaining the overload she sits perfect. Bit of rake means she should handle a trailer perfect
  8. Mar 29, 2020 at 11:25 PM
    #208
    Empty_Lord
    Dan
    man, i got quite a bit done today. Got the rear hopkins 7way/4way trailer plug hooked up too. minor modifying to make it fit the hitch, but looks good!
    [​IMG] [​IMG] 35 bucks vs toyotas 150 dollar one that is only a 7 way. Plug and play to boot!
  9. Mar 31, 2020 at 3:55 PM
    #209
    Empty_Lord
    Dan
    [​IMG] took it to work.. was slow so retorqued everything ive done recently... all good there. Did find out i need a ECGS diff bushing (figured that would be needed) and i may as well do the center bearing, its saging pretty good and well. it has 195k on it. so got all that ordered for later.
  10. Apr 4, 2020 at 5:07 PM
    #210
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Awesome resurrection. What a beaut! Just read all 11 pages in one sitting. Subb'd to see where this goes...
    Empty_Lord[OP] likes this.
  11. Apr 4, 2020 at 8:09 PM
    #211
    Empty_Lord
    Dan
    Thanks! I’m pretty happy with the truck. Just tidy up for now. I need to get some work done on the taco before I “mod” this truck. But eventually it’ll get the whole treatment
    DesertRatliff[QUOTED] likes this.
  12. Apr 4, 2020 at 8:13 PM
    #212
    Empty_Lord
    Dan
    New center bearing, and U joints in.
    [​IMG] [​IMG][​IMG]
  13. Apr 5, 2020 at 9:24 PM
    #213
    Empty_Lord
    Dan
    It’s going to be a long process. But I started blackout today with the 2 kick panels.
    Slashaar and My Name is Rahl like this.
  14. Apr 7, 2020 at 4:32 PM
    #214
    Empty_Lord
    Dan
    [​IMG] 4 pieces down.. time consuming to do these because of my setup.. slowly it’ll get done
  15. Apr 7, 2020 at 6:10 PM
    #215
    My Name is Rahl
    Looks good. Slow and steady gets better results!
  16. Apr 12, 2020 at 6:28 PM
    #216
    Empty_Lord
    Dan
    completed panels so far, And theyre all looking great.. headliner going to get done in black too dropping it off tomorrow.
    [​IMG] [​IMG]
  17. Apr 13, 2020 at 12:36 PM
    #217
    Empty_Lord
    Dan
    [​IMG] Got the front breathers up into the arb breather. I’ll worry about the rear eventually. Probably just t into the front breather line. And I have a 1/8” manifold for all the electric motor breathers to go to a 5/16 hose to the web breather as well. Probably get that done at work one day
  18. Apr 17, 2020 at 5:53 PM
    #218
    Empty_Lord
    Dan
    Preped the new black leather steering wheel. Swapped the control boards so I can have green back light instead of amber, installed a steering damper (I had it, it’s suppose to help, why not) and cleaned it all up.
    [​IMG][​IMG][​IMG][​IMG]Installed.. eventually it'll get new leather and painted the same as the rest of the interior... but for now its close enough
    Oh and i have to find a black airbag or airbag cover now..
    [​IMG][​IMG] got to get the other side controls too. but that'll require so soldering to match the LEDS. i may eventually decide to solder in some white LEDS. but as of now the clock is green and the mirror is green so this green doesnt bother me when compared to the white lights on the dash (cluster will get done soonish)
    Slashaar and DesertRatliff like this.
  19. Apr 24, 2020 at 9:31 PM
    #219
    Empty_Lord
    Dan
    Got one door panel setup for power windows.. paint the bare door panel black and I’ll have the fabric redone in leather... need to find shorter screws for a few spots, but it hold good and tight.. tighter than stock actually!
    [​IMG][​IMG]
  20. Apr 25, 2020 at 3:14 PM
    #220
    Empty_Lord
    Dan
    phone and voice controls in and working.. need to find green LEDs for the switches
