Rollover rescue 05 tundra
Discussion in 'Other Builds' started by Empty_Lord, Feb 1, 2019.
  1. Dec 20, 2021 at 9:06 PM
    #361
    Empty_Lord
    Empty_Lord [OP] Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Had my buddy test the stock injectors from my truck. Happy to report my injectors had wonderful spray patterns for 4 holes, and they flowed 250cc on average. The 1zz injectors were ~255 on average. So they’re a perfect fit. Again no noticeable power gains, but on average, 1mpg gain for me
    Coma 13 likes this.
  2. Dec 20, 2021 at 9:57 PM
    #362
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Mind explaining the cause for mpg increase? B/c corolla is more miserly? And Tundra wastes fuel?
  3. Dec 20, 2021 at 9:58 PM
    #363
    Empty_Lord
    Dan
    Finer fuel atomisation is my only guess
    daveeasa[QUOTED] likes this.
  4. Dec 21, 2021 at 9:09 PM
    #364
    Empty_Lord
    Dan
    well well well.. they're here
    Coma 13, Breakfast Taco and 45acp like this.
  5. Jan 20, 2022 at 10:35 PM
    #365
    Empty_Lord
    Dan
    Long tubes are finally happening. Slowly. I’m working on it an hour or 2 every day after work. Might be wrapped up by the weekend. As of now this is the progress. P/s lines tomorrow and maybe header install on the pass side + mount
    [​IMG][​IMG][​IMG]Passenger side manifold is off, block off installed(not really needed). Tomorrow I’ll do my powersteering lines since they’re stupid easy to reachright now. Then Maybe put this side together. Ididn’t get out of work till 9:30. Ugh.
    I have to pull all the studs too for the stage 8bolts.
    Breakfast Taco and xtremewlr like this.
  6. Jan 20, 2022 at 10:36 PM
    #366
    Empty_Lord
    Dan
    I’m also working on re wiring the radio harness and some other tidying up going on while it’s down
    harness rewire will also be adding a Rockford fosgate amp for the door speakers I got for free from a used car. Actually got paid to remove it lol
    Breakfast Taco and daveeasa like this.
  7. Jan 26, 2022 at 10:04 PM
    #367
    Empty_Lord
    Dan
    Just cats. Rest of the exhaust on hold since the reducers I bought failed to mention they’re measured OD… not ID like everything else!
    https://youtu.be/vzO8K9sS7Do
  8. Jan 26, 2022 at 10:14 PM
    #368
    Empty_Lord
    Dan
    SO as of now. new headers installed. New solid off road motor mounts installed, new power steering lines installed (all of them). welded the catalytics to the header flanges and attached the vbands to the truck for now. still to do in the next week or 2. finish the rest of the exhaust... hopefully.
    finish the rewiring of the radio (pins finally showed up!) and install the new blower motor. since i found out they're only 70 bucks my cost new from toyota..
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  9. Jan 28, 2022 at 10:37 PM
    #369
    Empty_Lord
    Dan
    wiring the radio as much as my patients will allow. it appears im getting much better at crimping these things.. im happy with all the little ones.. the bigger crimps at the bottom are fine and pass the pull test.. but theyre uglier.. my tool needs wider dies. but it works.
    [​IMG] (yes i know theres a bit of copper past the crimp on the red wire and i'll attempt to address that if i can. if not if it inserts, im happy. its good solid copper to pin contact at the actual crimp.. i just left it a wee bit too long)
    still need to add the ignition 12v to the 28 pin and make the speaker outputs a T for the aftermarket amp going in... @daveeasa any suggestions on a 090ii unsealed 4 pin connector i can use for the speakers around the console area.. i'll be running a jumper harness for abit till i get the amp location sorted
    also, being a reg cab, rear speaker wires are removed. so the smaller plug is one wire... for the dimmer.
    xtremewlr likes this.
  10. Jan 29, 2022 at 3:42 AM
    #370
    daveeasa
    David
    PNW
    I have some 4 position if you want. At least I think I do. Sumitomo. I have some 5’s too but not many and was thinking I’d use them for the heated mirrors, though I could go 6’s there to make life easy.
  11. Jan 29, 2022 at 8:01 PM
    #371
    Empty_Lord
    Dan
    pics?
  12. Jan 29, 2022 at 8:03 PM
    #372
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    So was this a vehicle that the previous owner didn't have full coverage on and still had a clear title as a result, or is it a salvage/rebuilt title?
  13. Jan 29, 2022 at 8:03 PM
    #373
    Empty_Lord
    Dan
    liability insurance bought it off him with a clean title for the cost of the tow
  14. Jan 29, 2022 at 8:04 PM
    #374
    PennSilverTaco
    Charlie
    So you've got a clean title?
  15. Jan 29, 2022 at 8:05 PM
    #375
    Empty_Lord
    Dan
    yup
  16. Jan 29, 2022 at 8:07 PM
    #376
    PennSilverTaco
    Charlie
    Was there any structural damage to the frame? This is one of those situations where side curtain airbags would have been more of a nuisance than a help!
  17. Jan 29, 2022 at 8:10 PM
    #377
    Empty_Lord
    Dan
    frame got tweaked downward just a hair on the passenger side. but 15 minutes at the frame shop and it was straight again. driver front lower control arm got bent, the low cam adjustments were bent.. i bent the cam adjustments back and welded in some reinforcement. drives pretty damn good.
    now i might be getting a frame for it for free... thats to be determined yet. but a brand new V6 reg cab frame has appeared and my guy is TRYING to get it for me.. it was a screw up by toyota that he's now stuck with. if that happens i'll be moving motor mounts and putting that frame under this truck... mostly just because.
    but as it stands this frames straight, alignment is still a little off but nothing major.. mostly just because of the lift. and the driver rear cab corner is bent inward just a little bit. nothing major. this truck likely will be with me for a long time at this point
    hood is also slightly bent, but its not from the rollover. it was like that well before i got it.
  18. Jan 29, 2022 at 8:14 PM
    #378
    PennSilverTaco
    Charlie
    Also, why do people see the need to lie about vehicles being in accidents? I'd certainly buy this truck, and the rest of TW seems to embraced it's history as well!
  19. Jan 29, 2022 at 8:16 PM
    #379
    Empty_Lord
    Dan
    means more money. but this trucks special. i wear the fact its been rolled over as a badge of honor!
    the newest 95 taco is ALSO a clean title. it'll get fixed up too. but its mileage is more of a badge of honor on it to me!
    [​IMG] [​IMG]
  20. Jan 29, 2022 at 8:16 PM
    #380
    Empty_Lord
    Dan
    the tundras been in 2 minor collisions and stolen twice too. so its got some stories to tell
