Rollover rescue 05 tundra
Discussion in 'Other Builds' started by Empty_Lord, Feb 1, 2019.
  1. Apr 16, 2019 at 12:20 AM
    #41
    Empty_Lord
    Empty_Lord [OP] Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    there will be an update when i throw the new axle shaft in.. havnt done anything since the t-belt w/p and stuff.
    other than vintage toyota cap and the final oil change to make the switch to mobil 1 extended performance oil
    tcjacado and Slashaar like this.
  2. Apr 16, 2019 at 12:21 AM
    #42
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    But what about the OEM spark plug decal‽
  3. Apr 16, 2019 at 12:22 AM
    #43
    Empty_Lord
    Dan
    did i not post this picture? i did that before i finished the t belt
  4. Apr 16, 2019 at 12:23 AM
    #44
    Empty_Lord
    Dan
    OK update since @BartMaster1234 master demands it
    Got a brand new OEM rack since the current one has a bad inner tie rod and is leaking... (will be installing it once i get new control arms and what not)
    and i have all the parts to replace the bent left rear axle shaft.
    Area51Runner and BartMaster1234 like this.
  5. Apr 16, 2019 at 7:53 PM
    #45
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Good choice. :thumbsup:
  6. Apr 16, 2019 at 7:55 PM
    #46
    Empty_Lord
    Dan
    Tis the only oil I run in all my cars. Corollas going strong with roughly 750k on the odo and no issues to report (other than a head gasket leaking oil out the back of the head.)
  7. Apr 16, 2019 at 7:58 PM
    #47
    Slashaar
    Josh
    Kansas City, MO
    I'm running it on my taco now, 11k on the first change with an OEM filter, do another 10k with the mobil 1 filter and then probably go up to 13k on the third change. One of these days I want to send off a sample.
    Also put in my wifes 03 corolla last time I changed her oil.
  8. Apr 16, 2019 at 9:12 PM
    #48
    Empty_Lord
    Dan
    i do 20k OCI in the corolla.. well not so much anymore with the leak(topoff about 10k mark, usually a quart low). but most of its life it was 20k OCI. Blackstone said i could eek 25k out of the oil when i last did a sample about 2 years ago. its great oil for the price and combine with a great engine... well you just cant lose
    Slashaar[QUOTED] likes this.
  9. Apr 17, 2019 at 7:52 PM
    #49
    Slashaar
    Josh
    Kansas City, MO
    :rofl:
  10. Apr 17, 2019 at 7:53 PM
    #50
    Slashaar
    Josh
    Kansas City, MO
    Yeah plus if it fails due to oil with a 15k interval they warranty the engine so it's a win win.
  11. Apr 17, 2019 at 10:06 PM
    #51
    Empty_Lord
    Dan
    Got the new axle shaft all pressed together at work on my free time. Popped it in tonight and man what a difference... think once I get the control arms balls joints and rack done it’s getting my Tacoma’s old wheels, the current tires are noisy due to the fact they were forcibly dismounted.
    [​IMG] Old on the left new on the right.
  12. Apr 17, 2019 at 10:07 PM
    #52
    BartMaster1234
    Tyler
    Flux Capacitor
  13. May 17, 2019 at 10:38 PM
    #53
    Empty_Lord
    Dan
    Bed is officially off today. Got my secondary sun visors and overhead console in and wired up. hoping to get her to the body shop soon to get the frame checked out and make sure its 100% then its onto suspension then body work
  14. May 25, 2019 at 8:41 AM
    #54
    Empty_Lord
    Dan
    Well. Tundras at the body shop for the next few weeks. New bed is here (ended up paying $316.) old bed is scrapped. Saved the bed crossmembers that weren’t bent (cut them out, will drill the spot welds later).
    New bed has a few dings butultimately it’s clean. Might swap the crossmembers from the old bed since they’re not rusty.
    [​IMG][​IMG][​IMG]
    Slashaar and Tatts521 like this.
  15. May 25, 2019 at 8:42 AM
    #55
    Empty_Lord
    Dan
    And yes the photo of the old bed you can see my armada
    RedDemolisher and Kolter45 like this.
  16. May 25, 2019 at 8:54 AM
    #56
    Empty_Lord
    Dan
    Still undecided on color. It’s between army green from the fjs, the new green on the 86, or cement grey. Still got months before paint happens
  17. May 31, 2019 at 8:55 AM
    #57
    RobZ9132
    RobZ9132 Well-Known Member
    Somewhere in NC
    2004 Double Cab TRD
    This is a great thread, sub'd!! Good luck on the Tundra, looks like it's off to a great start!
  18. May 31, 2019 at 9:19 AM
    #58
    Empty_Lord
    Dan
    It’s goin. Going to be on hold for a month or so once the beds on. So it’ll be two tone for a bit
    RobZ9132[QUOTED] likes this.
  19. May 31, 2019 at 10:08 AM
    #59
    RobZ9132
    Somewhere in NC
    2004 Double Cab TRD
    Taking your time is all part of the fun!
  20. May 31, 2019 at 11:07 AM
    #60
    Taco One
    Taco One Well-Known Member
    Bone Stock 2011 TRD Sport
    Florida plates and snow look way out of place. Sub'd
