Rollover rescue 05 tundra
Discussion in 'Other Builds' started by Empty_Lord, Feb 1, 2019.
  1. Oct 14, 2019 at 4:45 PM
    #141
    Empty_Lord
    Empty_Lord [OP] Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    The trd bedside decals would be the black and red ones. I think it would accent nicely with the trd look going on... I’d love to have trd 4runner Sema l wheels on this thing. The red valve covers have started this mess of trd shit.
  2. Oct 25, 2019 at 9:47 AM
    #142
    Empty_Lord
    Dan
    [​IMG] Well the trucks back home. Looks really good. Bottom of driver door they couldn’t get back into 100% fit without a lot of work. So I’m living with that.
    And the bed has some waves, but that was to be expected because that’s how they came from the factory.
    All in all I’m super happy with the work
  3. Oct 27, 2019 at 9:04 PM
    #143
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Looks awesome!
    Tacos4ever15 and Empty_Lord[OP] like this.
  4. Oct 27, 2019 at 9:17 PM
    #144
    Empty_Lord
    Dan
    Thanks!
  5. Oct 30, 2019 at 10:52 PM
    #145
    Empty_Lord
    Dan
    [​IMG] Cut the hole in the headliner for the overhead. Cuts ugly under there but it’s hidden. Need to cut the holes for the secondary sun visors next. But those will be precision or I’ll be staring at ugliness all the time I have them down. Another day..
    Then it’ll be going to get wrapped in fresh not gross smoker fabric
  6. Nov 24, 2019 at 3:41 PM
    #146
    Empty_Lord
    Dan
    Little update. Been focusing on other things as of late.
    Got the secondary visors in. Poked 3 holes with bolts ground to a point for 2 then use the clip on the visor to mark where the 3rd went.
    Headliners ready to go out for getting reupholstered
    Just gotta order new main visors and dynamat the roof then line with the foam I’ve got... should kill ALOT of wind noise.
    Said hole for visors [​IMG]
  7. Nov 26, 2019 at 6:43 PM
    #147
    Empty_Lord
    Dan
    Got factory harness adapters for going to a 2019 Toyota radio. Just waiting on the radio, tested everything on my 2015 camry radio I had laying around. Toyota mic works well on the gauge cluster, wheel controls function perfectly, Bluetooth plays music fine, HD radio works.. just need to adapt a rear camera and get the speed signal into the radio and reverse signal do everything works 100%.. also found out I can add blind spot cameras pretty easily if so desired. (No real point being I have no blind spots, but might be able to wire up front camera or the such)
    Slashaar and My Name is Rahl like this.
  8. Nov 30, 2019 at 5:49 PM
    #148
    Empty_Lord
    Dan
    [​IMG] 2019 Toyota 86 radio 80% working on the tundra with factory plug and play harnesses and a Toyota microphone. Total price? 200.
    Just waiting on the backup camera wiring and I have to wire up the reverse signal, parking brake signal and speed signal (can hijack the gauge cluster signal wires)
    specter208, landphil, la0d0g and 3 others like this.
  9. Dec 5, 2019 at 5:18 AM
    #149
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Very cool! Where'd you find a 2019 radio so cheap? Pullout at work, or just watching eBay? The aftermarket radio in the '06 4Runner our daughter drives is acting flaky, may need to replace it soon. I assume those same harness PN's would work if I found a good stock replacement.
  10. Dec 18, 2019 at 6:21 PM
    #150
    Empty_Lord
    Dan
    They’re cheap on ebay. I managed to get this one from a buddy that worked for lkq. Employee discount.
  11. Dec 18, 2019 at 6:22 PM
    #151
    Empty_Lord
    Dan
    No major updates. Was on vacation. Now back and working. Put the Tacoma’s trd trail team wheels on the tundra till I get some trd SEMA wheels for it
  12. Dec 18, 2019 at 6:30 PM
    #152
    My Name is Rahl
    Looking very cool, Dan!
  13. Dec 18, 2019 at 6:31 PM
    #153
    Empty_Lord
    Dan
    Just need the front end suspension done and some sliders to go play.
  14. Dec 18, 2019 at 10:54 PM
    #154
    Empty_Lord
    Dan
    [​IMG]Did some sound deadening the inner door skin on the driver door. Went heavy because my buddy got me a small crate of some OEM dynamat. Outer door skin I’m going to try and make removable panels held in with bolts and riv nuts. Also, still need to find need door panels
  15. Dec 28, 2019 at 8:04 PM
    #155
    Empty_Lord
    Dan
    Passenger side door deadened (inner skin). going to slowly work on dying the interior panels black and hopefully have it all done by spring. only thing im not touching is the seats for now, think im going to get some power sequoia seats because fuck it, why not more adjustable
    also have the front shocks and springs.. just waiting on one more part to get them assembled and then starts the front end rebuild
  16. Jan 1, 2020 at 8:53 PM
    #156
    Empty_Lord
    Dan
    Front shocks are in the truck. sitting 24" from center of wheel to fender. 23 in the back. if it doesnt settle out level i'll add a leaf from a 2nd gen taco recall spring.
    ARB 885 springs with billie 5100 shocks. springs are narrower than stock so control arm clearance is actually better than factory
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    also discovered the driver side shock was beyond broke. Cheap DIY long travel? shock magically gained about 1.5" of travel
    https://www.youtube.com/watch?v=E5I3R8gMTIs&feature=youtu.be
  17. Jan 1, 2020 at 9:04 PM
    #157
    Empty_Lord
    Dan
    Next project is getting new lower control arms, balljoints and then giving it back to the body shop to fix the tweak behind the cab.
  18. Jan 2, 2020 at 4:11 PM
    #158
    Empty_Lord
    Dan
    Even without aligning, no sway bar and shitty bent control arm, this thing drives and sits way nicer
  19. Jan 2, 2020 at 8:32 PM
    #159
    Empty_Lord
    Dan
    It’s just a larger taco.. so yes
  20. Jan 5, 2020 at 2:37 PM
    #160
    Empty_Lord
    Dan
    ball joints, camber bolt sleeves, and end links are in... should have the control arms by tuesday from napa... then the only Not new part on the truck is the upper arms (until i decide to inevitably put uniball uppers on, but i want to find a used set to throw ICON delta joints on, since its the exact same setup as the 1st gen spindle.. Hell im putting my New 01 taco upper ball joints on this tundra!)
    [​IMG] [​IMG] [​IMG]
