Rollover rescue 05 tundra
Discussion in 'Other Builds' started by Empty_Lord, Feb 1, 2019.
  1. Jan 11, 2020 at 9:45 PM
    #161
    Empty_Lord
    Empty_Lord [OP] Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    got the whole front end apart, debating ordering camburg upper control arms just to be done with it all for good. all i'll have to do after this, once i confirm the control arm was all that was bent, is the driver side wheel bearing. but that's easy enough to get everything apart for
    [​IMG][​IMG]
  2. Jan 12, 2020 at 8:09 AM
    #162
    My Name is Rahl
    Buy once, cry once.
    Slashaar likes this.
  3. Jan 12, 2020 at 9:22 AM
    #163
    Empty_Lord
    Dan
    Pretty much
  4. Jan 15, 2020 at 11:16 PM
    #164
    Empty_Lord
    Dan
    Persudeded the cam tabs kinda back to where they belong. I’ll try and get it better later if I can get a piece of steel to fit between the 2 to make it look prettier
    [​IMG][​IMG]
  5. Jan 15, 2020 at 11:17 PM
    #165
    Empty_Lord
    Dan
    Got some caddy horns too...
    still gotta figure out where im mounting them
    Slashaar and My Name is Rahl like this.
  6. Jan 30, 2020 at 4:02 PM
    #166
    Empty_Lord
    Dan
    Got the front frame rails all coated in 3 coats of steelit black, Saturday getting Eastwood internal frame paint then installing the plugs. Truck should hold up well after all this. Just have to address surface rust by the gas tank, will probably drop the tank in the summer to do that
    It’s slow progress, but I’ve been pretty busy lately
  7. Jan 30, 2020 at 10:04 PM
    #167
    Empty_Lord
    Dan
    [​IMG]Backup camera is in tundra tailgate handle. Does it need it? No.
    For 30 bucks is it worth it? Yes
    too bad the insert broke taking the bolt off for the handle so a new one is on the way from Amazon (I’ll do an oem one later, not dropping 120 on one now
  8. Feb 1, 2020 at 1:19 AM
    #168
    Empty_Lord
    Dan
    Radios pretty much done.. just a buttoning up and running the camera wire to the back left pretty much
    I have not added the speed signal because i see no reason to and the junction point to tap into it is buried in the kick panel. but i did wire the Radio side of the harness for it should i find a need later.
    I DID have to use some scrap wire harnesses to make it all factory-like
    Reverse signal you can easily grab. theres actually 2 open spots left for anything else that would need a reverse signal too.., It is right by the Airbag, green red wire is reverse the 3 slots below it are junctioned to the top green red
    i just ran a simple wire to the radio connector at the bottom of the center stack. I would of tied it up nicer, but kind of hard with the dash still in
    This is the radio harness. Pretty sure its the only Toyota the has the harness actually separate from the dash harness. Kinda nice
    The PAC backup camera harness had the video wire i needed. i stripped the rest of the wires off it to minimize clutter (no picture. i'll get one when i button it all up) I did splice into the main accessory power for the radio to have the backup camera on with ignition (you have to, triggered from reverse will not work, the radio looks for a camera on boot up, it then switches with its own reverse signal)
    Image quality is what you expect from an aftermarket backup camera. About on par with the 120 dollar ones ive messed with (no point in spending big bucks. The RCA can only handle standard definition. dont ever believe the 720p claims
    All in all about 300ISH into the whole project. for 300 you get HD radio, AM, USB, (you can add 3.5mm aux, but its ALOT of work), Bluetooth with handsfree calling, AHA radio (does some neat stuff) a backup camera, better sound (pioneer makes the headunit for toyota). and it'll read your texts to you. Not a bad deal for what you get
    But no CD player, if you REALLY wanted one you could make it work off the 3.5mm jack wires. but like i said, nightmare to deal with. wires have to be shielded for the 3.5mm or you'll get horrible sound interference
    radio controls work
    Not a bad dealio if your up for a little challenge.
    After all this the 2020 radio should be plug and play for me. Will report how that radio works out when i have my hands on one
    la0d0g and Slashaar like this.
  9. Feb 1, 2020 at 1:20 AM
    #169
    Empty_Lord
    Dan
    PT546-00142 is the harness kit, The USB adapter is useless to us. Amazon sells the one i used, but the other 2 harnesses work
    PT546-74120-MC Microphone, plugs into the adapter harness and works pretty good where i have it on the instrument panel., may try to relocate to mirror eventually. but likely wont.
    PAC CAMTY12 is the harness i used for the backup camera THE 6V OUT WILL NOT WORK UNLESS YOU BUY A 6V CAMERA. but the video connection is really all you need, the 12v can be taken from any source of ignition power
    https://www.amazon.com/NATIKA-Backu...tronics&sprefix=natika,electronics,159&sr=1-3 camera i used, needs 12v ignition power at the red wire by the video connector at the radio end. the ground and 2 other wires can be taped off. not used
    https://www.amazon.com/Goliton-Fema...+adapter&qid=1580548465&s=electronics&sr=1-20 USB adapter i used, no frills. just works. put a USB jack whereever you want.. this converts the toyota connector to a standard female USB connector (tape the connection you use so it doesnt come apart over time
    i dont think im missing anything.
    You can do this upgrade to any Toyota that will fit it FYI, well as long as its newer than the mid 80s and not a JBL system
  10. Feb 1, 2020 at 8:33 PM
    #170
    Empty_Lord
    Dan
    would ya look at that.. ive owned this thing for a full year.
    and ive gotten done more in 1 yea than i have on my tacoma in 4 :anonymous:
  11. Feb 2, 2020 at 6:26 AM
    #171
    My Name is Rahl
    Can you please give @NYCTaco52 some pointers on how to complete a project? :pray:
    Slashaar and NYCTaco52 like this.
  12. Feb 2, 2020 at 9:31 AM
    #172
    Empty_Lord
    Dan
    Have you met me? Seen my other build?
  13. Feb 2, 2020 at 10:54 AM
    #173
    My Name is Rahl
    No, and nope.
  14. Feb 2, 2020 at 10:58 AM
    #174
    Empty_Lord
    Dan
    my tacos going on 4 years with not a lot of progress.
  15. Feb 2, 2020 at 10:59 AM
    #175
    My Name is Rahl
    Mine is going on 2 years, and I've only done cosmetic mods. :notsure:
  16. Feb 2, 2020 at 11:20 AM
    #176
    Empty_Lord
    Dan
    Mines just a frame
  17. Feb 2, 2020 at 5:47 PM
    #177
    Empty_Lord
    Dan
    getting there... New uppers, New struts, New lowers, new lower ball joints, i'll have new end links this week and new tie rod ends. hell even the rack isnt a year old OEM, Truck should drive BETTER than new
    Driver side will get done soon, Have to make some plates to reinforce the previously bent cam tabs
  18. Feb 6, 2020 at 12:20 AM
    #178
    Empty_Lord
    Dan
    Took it to work and got it all aligned. Also drove it in the snow for the first time, shall see how she does friday driving about 140 miles.
    New driver wheel bearing, New camburg upper arms, new NAPA lower control arms, billie 5100s with arb 885 springs, new OEM lower ball joints, New end links (tried driving without the sway bar, but it needs it.) camber bolts antiseized so they shouldnt seize up. After the trip to pickup the cap i will throw it back on the alignment rack to make sure all is good. i set it to .1 degrees camber, 2.7 degrees castor and 0 toe
    [​IMG] [​IMG] [​IMG]
    DrTaco716, la0d0g, Slashaar and 2 others like this.
  19. Feb 8, 2020 at 12:04 AM
    #179
    Empty_Lord
    Dan
    We'll. Got me a cap today. $220 for the cap. 50 bucks for a fusebox and harness to get the towing shit working, 25 bucks for 2 sun visors, 25 bucks for a radio bezel with heater controls so my broken one can go bye bye.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    ontarioyota, la0d0g and Slashaar like this.
  20. Feb 8, 2020 at 12:06 AM
    #180
    Empty_Lord
    Dan
    oh, i nicked the damn bed just a little putting the cap on. Oh well. touch it up and live with it. the cap covers is
    Slashaar and Running Board Man like this.
