Roof liner rattle driving me crazy!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Guerdonian, Feb 11, 2016.
  1. Mar 21, 2017 at 8:25 PM
    #41
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Now I gots the rattle too... and it's warming UP around here :angrygirl::annoyed:
  2. Mar 21, 2017 at 8:40 PM
    #42
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    My rattles gone.Been in the 50's and the warm spring sun. I think I'll leave it. only bugs me from late October through March. Fine rest of the year.
  3. Mar 22, 2017 at 7:20 AM
    #43
    blakewhisenant
    blakewhisenant Well-Known Member
    Blake
    Oklahoma
    1995 Toyota Tacoma 4x4 V6
    lots to come...
    My Dealer did some work... Said they could not find the rattle I described but they went ahead and added some felt to the roof area... I still hear some noise when its cold. I believe its the actual headliner making the sounds, that is not limited to the plastic trim and wires glued to the HL.
  4. Mar 22, 2017 at 7:35 AM
    #44
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    theres where mines coming from. havent taken it to the dealer yet. seems to go away after it gets above 35 degrees
  5. Sep 27, 2017 at 12:13 PM
    #45
    mulishan909
    mulishan909 Well-Known Member
    Mulishan909
    2017 Tacoma TRD Sport
    I didn't take pictures. But you can pull it from the front first and then the rear of the sunglass console. Then there a
    Is a plug. Just unplug it. I used some 1/8 or so foam from shipping and put between the plastic rim and the headliner so it would fill the gap. Then I press around to see if it would make a scratchy sound = none, install and test drive for a few days.
  6. Sep 27, 2017 at 4:39 PM
    #46
    NorthernWoodsman
    NorthernWoodsman Active Member
    No roof liner rattle, but I do have a rattle from both the speaker on the passenger side dashboard (near the windshield) and a new one behind the instrument cluster. Oh, and if the windows are cracked or partially down, those rattle too.
  7. Sep 28, 2017 at 4:29 PM
    #47
    Barcared
    Philadelphia, PA
    Yup, been some chilly mornings, so time for the rattles to come back. I had some silicone goop left over from packing the door seals to get rid of the whistling and sealed the plastic trim a little better. that seemed to take care of it. We'll see. heading out to the mountains this weekend and it's supposed to be 44 degrees at night. Guess we'll see how works up in the hills. It's the first real test since I sealed it. First try to fix it last year late spring (? I think?) didn't hold up on some cold mornings in the hills.
  8. Nov 10, 2017 at 6:43 AM
    #48
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Has anyone had luck with Toyota fixing the rattle from the plastic ring in the headliner? I'm going to bring it in next week and want to prepare myself for how hard to fight with them on this.
  9. Jun 21, 2018 at 3:10 PM
    #49
    Tacoma701
    Tacoma701 New Member
    2018 Tacoma TRD Pro
    I had a similar nose on my 2018 Tacoma TRD Pro and it seemed to be getting louder day by day. Finally, I pulled the roof console down and added some rubber padding between anything that had two surfaces that could touch each other on the passenger side from inside of the console opening. NOISE HAS STOPPED!!! IT TOOK 10 MINUTES. You can find videos online that shows how to remove the console. It's very easy.
  10. Jun 29, 2018 at 8:27 PM
    #50
    AZ INFERNO
    AZ INFERNO New Member
    Fred
    18 TRD OR DBL CAB INFERNO
    Got any pictures? I can't find any videos how to pull the console apart. I have 2018 TRD OR. Thanks
  11. Jun 29, 2018 at 8:30 PM
    #51
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    I've got intermittent rattles in both doors. I'll fix them when I replace the OEM speakers. I don't want the dealer making things worse.
  12. Jun 29, 2018 at 9:19 PM
    #52
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You just yank it off - really! Theres a better description here:
    https://www.tacomaworld.com/threads/overhead-cluster-12v-ignition-switched-power-pin-outs.512640/
    The wires up there are glued to the headliner. I used hot glue to hold them down.
  13. Jan 13, 2019 at 8:11 AM
    #53
    mindstar
    mindstar Well-Known Member
    BC Canada
    2017 TRD Off Road
    OMG THANK YOU! Seriously I am about to drive cross country in the coming months and the thought of my console rattling the whole way would drive me nuts.
    Also, long time reader first time poster. Lol
  14. Jan 13, 2019 at 8:18 AM
    #54
    vsekvsek
    vsekvsek Well-Known Member
    I had this too, I stuffed a folded up straw behind the sun visor and the rattle went away for good.
