roof mount antenna center point
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco 422, May 2, 2023.
  1. May 2, 2023 at 6:04 PM
    Taco 422
    Taco 422 [OP] Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Does anyone know the center point of the access cab roof? I want to center an antenna. I've seen some body dimension diagrams floating around for the front and engine bay.
  2. May 4, 2023 at 6:26 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    When I installed my through the roof antenna for my HF rig I took some blue painters tape and made an X across the cab from front left to right rear corner and front right to left rear corner. Checked it with my eye all around and it looked perfect. Center punched, removed the head liner, used a step bit to drill, installed antenna and head liner. It looks Factory as far as most are concerned.
