Roof mount light bar wiring thru roof need help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prodeer, Sep 4, 2014.
  1. Sep 4, 2014 at 2:04 PM
    prodeer
    prodeer [OP] Don't know what normal is anymore
    Boise Idaho
    08 AC Tacoma
    Intake, Lift,, Custom Arizona pinstriping piant job, icon 2.0 rears and sway away Adjustable coil overs, KMFB sliders, KMFB Frankinsprings, cb mount, and p.a. System
    I just bought a set of restlessness roof mount for my Access cab Tacoma and I need some help on how to wire them up thru the roof don't want to mess up and drill to many extra holes.:confused:
  2. Sep 4, 2014 at 2:28 PM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    You can run ithe wire under the driver's side front and back door seals, up and behide the plastic that is behind the rear seat, to the rear window. The sliding rear windows have a small notch at the bottom a few inches from the left edge. Drill a small hole. Make sure you don't drill through the outside weather stripping. Run the wire through the hole. The wire is now outside the truck. Run the wire under the weather stripping along the bottom, up the left side, across the top to the gutterr. You need some new 3-M two-sided tape. Pull the trim out a little from the gutter, run the wire along the gutter (under the rubber trim) to where you need it. It is a lot easier than it sounds. If you need I can take pictures tomorrow.
