Roof rack anchor points
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CoTacoTy, Jun 19, 2022.
  1. Jun 19, 2022 at 12:39 PM
    CoTacoTy
    CoTacoTy [OP] Well-Known Member
    White 2017 sr5
    Hey everyone, just looking for some options into loading stuff on to my rack. Currently I use ratchet straps to secure my cargo to the roof, and it works really well. What I would like is some anchor points on my rack tho. I have an uptop bravo rack and I know they've got track nuts for sale, so planning on using their hardware, should I get some m6 threaded eye nuts and put them on the rack? Or maybe some v or d-rings like this?
    Seven Sparta Tie Down Anchors for Truck, Trailer, Warehouse, Boat, 10 Pack of Heavy Duty Steel V Ring Bolts, Tie Down Rings(Black) https://www.amazon.com/dp/B07H9ZKRH6
    It takes me a bit of set up and trial and error to get stuff to stay secure on my rack, id like to simplify things a little bit and make the process quicker. I have to load and unload my cargo to pull into my garage. So its not much of an option to keep my cargo secured all the time. Any tips, pics or ideas would be awesome!
  2. Jun 19, 2022 at 12:54 PM
    seang
    seang Eternal Noob
    TX
    17 White Off Road
  3. Jun 19, 2022 at 1:08 PM
    FlickFrack
    FlickFrack Well-Known Member
    MA
    '18 Superwhite TRD Pro
    If theyre similar to Prinsu and use the same type crossbars... 1/4 carriage bolts fit perfectly, whatever desired length you'd like
  4. Jun 19, 2022 at 1:33 PM
    CoTacoTy
    White 2017 sr5
    Slide the head in the track and then secure however? Nuts of whatever kind?
  5. Jun 19, 2022 at 1:57 PM
    FlickFrack
    MA
    Yep, the other guy put in pretty much what prinsu includes.
    The carriage bolts fit perfectly inside the tracks and then use them to secure whatever youd like, you can use the eye hooks or nuts for whatever you're doing.
