Roof Rack Design and Fabrication Weekend 5-6 Progress ;)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by upTOPoverland, Feb 3, 2019.
  1. Feb 21, 2019 at 7:40 PM
    #201
    upTOPoverland
    upTOPoverland [OP] Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    A threaded foot with a rubber bumper under the center of the load bars is a possibility. About the heaviest thing I plan to throw on mine is my offload jack unless I make a bracket to hold it in the bed. The thing is unwieldy at best and I don't look forward to lugging it six feet in the air to put it back after I needed it for something that already ruined my day. LOL
    We've got a finite amount of space between the load bars and the roof of the cab. Given the bow of the roof of the truck at dead center at the highest point we clear the roof by .625" MAX. This could be offset by increasing the spacer between the point where the mounting bracket contacts the luggage rack channel. If we did that, or offered them with extended spacers for guys that aren't concerned with getting the rig in the garage it MIGHT help. But the roofs on the 3rd Gen are thin. They are flimsy and it doesn't take much at all to push them in with your hand. (climb up in your bed and press on it and you'll see it). So this makes me question the ability of the roof to add the extra weight bearing that we would all probably love to have. The end all solution is heavy gauge steel load bars with rolled edges. There is just a machining nightmare and a completely different set of tooling required to do that.
    It's not out of the question....but I'm not 100% that the truck is structurally sound enough to give us any assistance to the capacity of the load bars.
    I bent one of the bad bars in testing almost on purpose. I climbed up on it and instead of putting my weight (185 pounds) out to the edges near the mount points I stood straight in the center of it. Then I kind of bounced on it because I would rather know before one of you guys calls me and says "dude.......big ass dent in my roof"...so what I know about extruded aluminum is that we could go to the 40x40 bars, increase the load capability in the center by about 30% (close to 110 pounds on any given bar at dead center instead of what we tested at 68 pounds on our current configuration.)
    The good news is that all of our design and production is in house. The rack that ships on 3.15 is solid and sound for what most people are going to throw up there. But if we've got a guy that is really going to push the limits.....anything is possible. PM me if you think you'll do more than an RTT or the standard gear and I'll do the homework on the back end for a beefed up version for hard core guys.
    upTOPOverland_Drew likes this.
  2. Feb 21, 2019 at 8:43 PM
    #202
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Do you have a plan for awning mounts off the side of these racks?
    Slashaar likes this.
  3. Feb 21, 2019 at 9:04 PM
    #203
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Trying to get it as low as possible is hard.. the middle of the roof has the highest peak thus if the limiting factor on height. I was in the same boat.
  4. Feb 21, 2019 at 9:15 PM
    #204
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    You could keep the weight down and increase the load capacity by orienting 2040 bars vertically instead of horizontally like most do. I'm not sure of this but I think the closer the bars get to the roof the higher the noise pitch could get. Noise seems to pick up substantially at 60-65 with either nothing or Thule bars up there. With nothing it seems to come through the rear window but the bars are even louder.
  5. Feb 22, 2019 at 5:57 AM
    #205
    Nettleberger
    Nettleberger Well-Known Member
    2017 Tacoma TRD Pro DCSB Super White
    @Relic_Micah - can you post head on and full side (perpendicular and showing the whole truck) views when you get a moment?
  6. Feb 22, 2019 at 7:05 AM
    #206
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    I've got a Roam awning ordered for mine. When it gets here I'll get into and get it mounted to mine. I am assuming the brackets for that will be pretty universal.
  7. Feb 22, 2019 at 7:09 AM
    #207
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
  8. Feb 22, 2019 at 9:19 AM
    #208
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Awesome! Those Roam awnings look the same as ARB/Smittybilt/insert any company name here.
    Also - will cut outs for 30" or 40" Baja Designs lights be available
  9. Feb 22, 2019 at 9:21 AM
    #209
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Yes. I run the s* lights because I have quite a few of them from other builds but there will be four different visors that you can select when you order. No Light, S8 10 pair, S830, S840. We can do other things for rigid guys, Heise, etc....realizing not everyone is as afraid of the dark as you and I are. Hahahaha.
  10. Feb 22, 2019 at 9:24 AM
    #210
    ChoyotaIII
    ChoyotaIII Someone took "Choyota"
    Echo
    Placentia, CA
    2012 Spruce Mica + 2018 MGM
    Very unique! I just followed you on IG the other day.
  11. Feb 22, 2019 at 9:34 AM
    #211
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    What if we get really scared of the dark and go with an Onx6 bar???
    OffroadAlliance.com likes this.
  12. Feb 22, 2019 at 9:51 AM
    #212
    NonTraditional
    NonTraditional Well-Known Member
    DMV
    2016 Tacoma TRD OR DCSB
    At this point you might want to start a new thread and get a list together of buyers.
    upTOPoverland[OP] likes this.
  13. Feb 22, 2019 at 9:53 AM
    #213
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Hahahahaha! YES!!!!
  14. Feb 22, 2019 at 11:16 AM
    #214
    Nettleberger
    Random question - why have a bracket for the MaxTrax and not just mounting pin sets as they come?
  15. Feb 22, 2019 at 1:43 PM
    #215
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    So... I'm just gonna nudge my way in here... OP, I understand you may not have a direct answer for this, but any idea what may need to be changed or modified to make one of these absolutely sexy racks fit and function on my 06 Access cab? I see a few other 2nd gen owners in this thread, but I haven't seen any talk of cross-(contamination?)generation fitment...
    Thanks in advance!!!
  16. Feb 22, 2019 at 2:15 PM
    #216
    nald
    nald Active Member
    19 TRD OR
    Very Nice!!!
  17. Feb 22, 2019 at 4:56 PM
    #217
    808inDa503
    808inDa503 From HNL living in PDX.
    Sam
    Portland, OR
    '09 Silver DCSB 4x4
    Icon stage 6 kit w/ billet UCAs, Dakar leaf pack, Icon air bump stop, Bullet Proof Fab grill, Magna-flow exhaust, ARE bed cover, Redline Tuning quick lift, 17" gunmetal SCS Ray 10, BFG KO2 285/70/17, Wet Okole and Ellis Precision shift knob
  18. Feb 22, 2019 at 5:08 PM
    #218
    bagleboy
    Scott
    Norcal, Santa Rosa
    You're gonna need some mounts for starters. AC's don't come predrilled with nuts for racks.
  19. Feb 22, 2019 at 6:22 PM
    #219
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Got any 'empty' pictures? That's how mine's gonna roll 90% of the time. @Relic_Micah
  20. Feb 24, 2019 at 8:40 AM
    #220
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
