Roof Rack Design and Fabrication Weekend 5-6 Progress ;)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by upTOPoverland, Feb 3, 2019.
  1. Feb 14, 2019 at 8:53 AM
    #101
    upTOPoverland
    upTOPoverland [OP] Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    "Price is what you pay, value is what you get." -Warren Buffett
    Said at least twice a day here.
  2. Feb 14, 2019 at 8:54 AM
    #102
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Hahahaha. Do you have any idea how hard it was/is not to use that shit in marketing? The struggle is real.
  3. Feb 14, 2019 at 9:00 AM
    #103
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    This looks amazing. This is a list of things I would like to know, some have been answered, and some, as you stated, will be answered later:
    Wind noise: not noticable
    Load rating: TBD
    Price: TBD
    Clearance from roof: 0.3125"
    Possible additional bracket for light bars larger than rack width?
    Possible additional mount point to roof? (Using OEM holes?) Or is this going to be strong enough as is?
    Sorry for all the questions, but hopefully these are questions others had as well
    Thank You,
    Brandon
    3_TACOS_NEVER_ENOUGH likes this.
  4. Feb 14, 2019 at 9:01 AM
    #104
    oneup714
    oneup714 Well-Known Member
    All show no go Super White Tacoma TRD Mall Crawler
    I bet lol
    transworldmoto likes this.
  5. Feb 14, 2019 at 9:05 AM
    #105
    bodean
    bodean Well-Known Member
    Shawn
    Crowsnest Pass, AB
    02 Taco RCSB, 16 Taco AC6MT, 07 FJC, 22 Bronco
    Nicely done!
  6. Feb 14, 2019 at 9:14 AM
    #106
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    How about some reg cab love then?
    You would be the first to design a reg cab-rack :thumbsup: :D
    Nimble9 likes this.
  7. Feb 14, 2019 at 9:17 AM
    #107
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Load Rating: Toyota lists the load of the roof at like 75-100 pounds depending on which google result you get. That's pretty crappy IMO. So let's look at it like this. Tensile strength of 316 stainless steel is about 80,000 PSI. For the rack itself that would be the "weak link" in the chain as that is what secures to the roof, but the factory installed thread septs are not 316 stainless. Not even close. So I feel like that becomes the weak link. Options: drill them out and upgrade to something with m8x100, stainless. This would be a chore. You'd effectively need to drop the headliner, make the alterations, add plating to the inside of the roof skin, etc....seems like a whole weekend/more than a six pack project. What I do know is that if the truck is in neutral...we can pull it across the parking lot with another truck from the rack. I don't think this actually proves anything and I don't know in what scenario we'd actually find that practical or safe but..... dares are dares and we like to accommodate. Roof top tents ( I have Tepui Kuk.3 weighs 125 pounds/net) no problem. Loaded tent distributes weight under use between the truck and the ground, added people etc..let's say 650 pounds. Basically that divided by two (half the weight is on the stilts on the ground) is 325 pounds and it holds that. The footprint of the tent distributes weight across all the load bars so it's negligible how much weight is on each bar. The biggest thing I think we'd see is how much weight becomes a problem to the point that it bends the bars and up to this point all I can confirm is that I haven't bent any bars. Having said that se do have the bars here without the powder coat on them and maybe its a good ides to see what we can stack on one bar, in the middle across a span and see when it gives if it gives at all? I wouldn't put an elephant up there, but most of the stuff any of us are taking out into the wild blue yonder.....it's coming back with you.
    Roof clearance: Max is set at .3125" by adjusting the mount bolts up into the top of the slip and torquing it down. the rood rack mounts on 1" spacers. Any taller spacer would just increase that by the additional height of the spacer. Pretty flexible here.
    Additional brackets: The bank loves it when we make things that sell. Lol. We are designer/fabricators. I think an assortment of brackets over time will materialize. I personally use BD lights so my default is to that but I understand there are other companies that make awesome stuff that don't cost a years tuition to make it easier to see in the dark so I guess the short answer would be...small company, easily adaptable...we will make you anything like that you want.
    Additional mount point: We didn't utilize the center mount for the OEM roof rack. We used the two forward's most and at the rear, two attachment bolts through each bracket. If someone was really gonna bog one of these down with something I wouldn't hesitate to make the middle brackets for the additional load bearing capacity but under normal conditions I don't think it's something people will search for. But.....we tear up a lot of shit so who knows. Hahahah
    Hope this answers everything for you. :)
    mtip, ready6delta, HankP and 2 others like this.
  8. Feb 14, 2019 at 9:18 AM
    #108
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    I have a '97 Reg and I have had that thing FOREVER. Market order is: 3rd Gen DC (also fits back to 2005), next is same for Access Cab, followed by a coupe of others. Not against a Reg. Rack at all. Have to make some measurements to see what we'd be into it for.
  9. Feb 14, 2019 at 9:25 AM
    #109
    MY50cal
    Mojo
    Camden County, NC
    Yep.
    Nice!
    Hey, as long as we're on the list... last place is still a place :fistbump:
  10. Feb 14, 2019 at 9:26 AM
    #110
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Yes sir. Forward is forward. Hahahaha
  11. Feb 14, 2019 at 9:54 AM
    #111
    CttAznRanger
    Brandon
    Boston, MA
    These are the most detailed answers ever. This does answer everything I asked. Now, once everything is solidified, I will probably be asking for brackets to fit a 52" straight light bar.
    As ridiculous as this sounds, my plan is to put a 52" straight on the front, a 42" curved facing rear, and some side lights for other random things. Only reason is because I have them, and I want to use them... They were cheap Amazon lights, and I bought them because I'm crazy like that...
  12. Feb 14, 2019 at 9:59 AM
    #112
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Brother I have found that out in the boonies....two candles is better than one candle. The rack is 51.125" Wide side to side out the outermost part in the front. Your light bar is going to look fine up there. You have exactly 48.00" inside bar clearance at the rear so the curved one will fit the back no problem.
    "When you need it and don't have it you sing a different tune." Burt Gummer. Tremors.
  13. Feb 14, 2019 at 10:02 AM
    #113
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    That rack looks AWESOME! Great job with the design.
    Atl_taco_ likes this.
  14. Feb 14, 2019 at 10:03 AM
    #114
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Thank you sir. I will finally get some sleep tonight I think. So much math. Hahaha
  15. Feb 14, 2019 at 10:07 AM
    #115
    NonTraditional
    NonTraditional Well-Known Member
    DMV
    2016 Tacoma TRD OR DCSB
    I was looking at the pictures when I realized all the edges have chamfer.
    Did you CNC mill these parts or waterjet multi axis? That is the kind of detail I'm interested in, nice work!
  16. Feb 14, 2019 at 10:18 AM
    #116
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    We have a CNC router in house so this one was all CNC. If we make the leap to water jet in the future the finish edge chamfers would be done by hand on inverted routers post production. It was a big part of the thought about wind noise having all the edges chamfered. Additionally it should lessen abrasion on bungees, ratchet straps, etc....I'm glad you noticed that. The first one of these has that inset tail section.....that is for my bed rack rig so it nests when you use the pair together. We will offer this design and another one that has a softer, rounded end near the rear of the cab for guys that won't run an additional rack in the rear. There is a bed rack coming as well that is designed so that the very top of a stowed roof top tent sits dead level with a Pelican 1720 on the roof rack. Thought is that you can use level load platform to strap kayaks, etc....to the top of all your gear to get where you're going and then unload to commence camp fires, beer drinking and story telling.
  17. Feb 14, 2019 at 10:21 AM
    #117
    NonTraditional
    DMV
    These look solid, the bed rack I fabricated sits super low and had to trim the shark fin. Excited to see the development continue.
    upTOPoverland[OP] likes this.
  18. Feb 14, 2019 at 10:33 AM
    #118
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    Nice job. Can’t wait to see the price point on these. A roof rack is in my near future.
  19. Feb 14, 2019 at 10:35 AM
    #119
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    8020 has a deflection calculator that allows you to input weight and bar length to find the amount of deflection for a static load(doesn't account for hitting bumps at speed) and it looks like you'd be ok on clearance with 200lbs at 42" just sitting there using 1020 stock. In the diy rack thread someone posted using tread step rubber on the top and I'm thinking it might be cheap insurance to protect the roof to put that or something like it on the bottom of the bars with the least clearance.
  20. Feb 14, 2019 at 10:38 AM
    #120
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    That is good information. You rock!I like the rubber buffer. That's a good idea just incase.
