Roof Rack Design and Fabrication Weekend 5-6 Progress ;)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by upTOPoverland, Feb 3, 2019.
  1. Feb 14, 2019 at 6:25 PM
    #141
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I’ve thought about the attachment option too. Perhaps that’s the best route. Gobi says they’ll build me one with a longer backside, but I’m still debating. Those things are tanks, but a little bulky and did make a little bit of noise. I’m not real keen on putting the fairing right up against the paint, even with the rubber pad.
    I’m going to hang out for the final production version and final edits.
  2. Feb 14, 2019 at 6:41 PM
    #142
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    I noticed mention of a bed rack. Be sure you leave room for chassis flex between the two racks and the roof if you plan on running them close.
    Bigdaddy4760 and Slashaar like this.
  3. Feb 14, 2019 at 6:43 PM
    #143
    RushT
    North Texas
    Yep..... had that on my ‘todo’ list to comment on.
    RedBeard1[QUOTED] and Slashaar like this.
  4. Feb 14, 2019 at 6:44 PM
    #144
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    What's the fin even for, satellite radio? If so, maybe I should just have it deleted like my am/fm antenna...
  5. Feb 14, 2019 at 6:45 PM
    #145
    Slashaar
    Josh
    Kansas City, MO
    This. I actually had to explain chassis flex to someone who wanted to attach his rear bumper to his sliders for side protection...
  6. Feb 14, 2019 at 6:53 PM
    #146
    RedBeard1
    Red
    Box chassis you are fine but with these C- channel frames they will get all out of shape.
  7. Feb 15, 2019 at 9:01 AM
    #147
    NonTraditional
    NonTraditional Well-Known Member
    DMV
    2016 Tacoma TRD OR DCSB
    I chopped mine in half, filled with epoxy, sanded, and painted. Now my RTT is about 1.75" from the cab to keep it flush and reduce drag.
    Slashaar[QUOTED] likes this.
  8. Feb 15, 2019 at 12:05 PM
    #148
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I have a prinsu and dont notice a 1 mpg loss till i hit 70 mph. Just like adding all these mounts for attachments im supprised no one sells mpg boards - aluminum plate or HDPE boards to smooth the roof up and limit all the turbulence across the top. I've been planning to buy a 1/4" thk. aluminium plate and cut 3 panels across to adjust boxes or maxtrax placement.
    Slashaar likes this.
  9. Feb 15, 2019 at 2:06 PM
    #149
    Slashaar
    Josh
    Kansas City, MO
    I'm just wondering if it can be completely deleted. I don't have GPS in my truck, or use satellite radio. At most the weather thing works at home and no where else. Pretty useless IMO.
  10. Feb 15, 2019 at 2:17 PM
    #150
    NonTraditional
    DMV
    There is a tutorial online that someone uses another oem lower profile shark fin.
    It is a pain the ass to try and drop the head liner fyi.
    It would be nice have a 3D printed delete, maybe @mesojdm could make one....
  11. Feb 15, 2019 at 2:22 PM
    #151
    Slashaar
    Josh
    Kansas City, MO
    I have a 3d printer......:drevil:
  12. Feb 15, 2019 at 2:31 PM
    #152
    NonTraditional
    DMV
    And I do CAD... Send me a message.
  13. Feb 21, 2019 at 5:02 AM
    #153
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
  14. Feb 21, 2019 at 8:08 AM
    #154
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    The more I look at these pictures, the more I’m leaning towards this over the Prinsu. Hoping the price tag doesn’t provide sticker shock.
  15. Feb 21, 2019 at 9:08 AM
    #155
    upTOPoverland
    upTOPoverland [OP] Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    Production starts on March 1st. 20 in the first production run to see how it settles into the industry. As of now I expect them to ship out of our facility before Marsh 15th. The first production run will take longer than when we are in high gear because this is the part where we sort out packaging, large quantity with our powder coat guy, etc....All the tool paths are set and all the raw goods are here. You can PM me with any questions you have. :) Cheers!
    Slashaar and transworldmoto like this.
  16. Feb 21, 2019 at 9:09 AM
    #156
    NonTraditional
    DMV
    Official price???
  17. Feb 21, 2019 at 9:13 AM
    #157
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    The target to market is $999 with the armor sides in primer and ready for you to paint. If we paint them (still working out the logistics of this) it's going to add about $145.00 to the cost. I am more concerned with shipping painted pieces than I am anything else. Looking from the alternative perspective of you painting them yourself....no damage in shipping and the readily available Toyota OEM color code paint kits are available on Amazon for about $60.00. The only one that I have tested that I had an issue with was the Quicksand. The Inferno, the white, the Grey and the Silver have been spot on for color. I think the key is to offer both choices and let the guy buying it decide. Some people may live in an apartment, etc....where spraying their own parts just isn't something that can happen.
  18. Feb 21, 2019 at 9:16 AM
    #158
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    Just answered that one below but the short answer is $999 shipped to your door in CONUS/lower 48. with all the major parts powder coated and the exterior armor sides in primer ready for paint/wrap. An additional $145.00 for us to spray them. The catch on in house painting is this: Painting to Toyota code number is the only way I can offer it. We have seen slight variations in the OEM colors up close when painting other parts. End users final decision.
    shane100700 likes this.
  19. Feb 21, 2019 at 9:22 AM
    #159
    NonTraditional
    DMV
    Really solid product and design. I personally will have to pass with the price point. Good luck on this venture! It is always great to see the products come alive through TW.
  20. Feb 21, 2019 at 9:26 AM
    #160
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    And I probably should have clarified. That is with one MaxTRax mount plate (pins not included), one Rotopax Plate (turn lock not included) and one axe/shovel mounting bracket (quickfist 1.75-2.25 pair included). All the brackets and mounts are power coated black as well.
    The rack by itself, sides, side armor ready for paint, and bars, mounts and hardware is $799 shipped. Sorry dude I'm tired. Lol
