Roof rack dilemma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trrn11500, Feb 4, 2017.
  1. Feb 4, 2017 at 4:40 PM
    trrn11500
    trrn11500 [OP] Well-Known Member
    it was 30 degrees in NJ today and I just wanted to mount the oem roof rack. I removed the weatherstrip. Great eaverything smooth. I remove the paint from over the bolt wholes. Great. I start to apply the bracket. Perfect passenger side is bolted with two screws just fine. I place the bracket over the drivers front side and the first bolt screws in great. The second one just slides into the hole. Here is the kicker there is no threading in this hole. That really sucks because I can't put on the roof rack and I have 5 open holes in the roof on each side open to the elements.
    I was thinking to rivet nut thread myself. How do you think the dealer would fix the problem from the outside with a rivet nut or remove all the liner and fix it from the inside? I kind of don't want them to take apart the inside of the cab.
    Any ideas? The truck is a 2017 double cab limited.
  2. Feb 4, 2017 at 5:00 PM
    Kentaco Wildat
    Kentaco Wildat Well-Known Member
    Dylan
    Louisville, KY
    Black 2017 TRD Off Road DCLB 4x4 [1992 ExtCab 3.0 V6 4x4]
    Pro Grill, TRD Pro Shift Knob, Debadged, Tonneau Cover, OEM bed mat, OEM all weather mats
    I would contact your dealership, they should fix that under warranty without issue, it was obviously a factory oversight.
  3. Feb 4, 2017 at 5:38 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    They'll probably just use a tap and die set and make a larger diameter threaded hole
    shakerhood likes this.
  4. Feb 4, 2017 at 7:40 PM
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    Toyota will say that's normal. Demand a new truck.
    :p:rofl::rofl:
  5. Feb 4, 2017 at 7:42 PM
    trrn11500
    i think i will do that.
  6. Feb 4, 2017 at 7:43 PM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    Lube the open holes and put the screws in until the tap the unthreatened hole.
  7. Feb 4, 2017 at 7:48 PM
    TacoFister
    Josh
    Like the way you typed, 'holes', very erotic. Op. Just get a 2 inch bolt, drill through the headliner and put a nut on the other side. Problem solved
  8. Feb 4, 2017 at 7:50 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    AANorthwest likes this.
  9. Feb 4, 2017 at 7:56 PM
    AANorthwest
    AANorthwest Well-Known Member
    Washington
    2012 DCLB 4x4 TRD sport
    I wonder if anybody else has ran into this problem.
  10. Feb 4, 2017 at 9:41 PM
    trrn11500
    Thanks AJMOGEN that is exactly what I needed. I knew there had to be a way without having to take the interior apart.
  11. Feb 5, 2017 at 6:03 AM
    Trailguy
    Trailguy 2017 Tacoma TRD PRO Cement
    2017 Tacoma TRD PRO
    All of my "wholes" were threaded:devil: If you have the experience, just tap the unthreaded rivet. If not, wiser to take it back to the dealer.
  12. Feb 5, 2017 at 6:26 AM
    TacoFister
    Josh
    Op. On a real note this time. I'd just take it to the dealer. Rivet Nut may be a good solution but I feel that if you go to 'set/expand' the rivet you may deform the metal around it. I would be scared to cause the metal to wrinkle or crease in some way...
  13. Feb 5, 2017 at 8:06 AM
    trrn11500
    thanks guys.
  14. Feb 5, 2017 at 8:38 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Plus that may cause a leak too.
    TacoFister[QUOTED] likes this.
  15. Feb 18, 2017 at 7:20 PM
    trrn11500
    Problem fixed by the dealer. I was able to install the one roof rack with a perfect fit.
  16. Feb 18, 2017 at 7:21 PM
    shakerhood
    Southern Ohio
    Glad to hear they got you all fixed up!
  17. Feb 18, 2017 at 7:28 PM
    NY Taco
    NY Taco Well-Known Member
    Rochester, New York
    2017 Inferno Sport DCLB
    Leer 180 Cap, Beat Sonic Navi By-Pass
    What did they have to do to fix it?
  18. Feb 18, 2017 at 7:31 PM
    shakerhood
    Southern Ohio
    They probably just ran a tap thru but I am curious as well too.
  19. Feb 18, 2017 at 7:33 PM
    trrn11500
    Weld the threaded sleeve on the inside of the cab roof.
    NY Taco and shakerhood like this.
  20. Feb 18, 2017 at 7:40 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
