Roof rack DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr. Emmett Brown, Mar 22, 2020.
  1. Mar 22, 2020 at 3:16 PM
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    Covid-19 quarantine means DIY projects. So here we go.
    I'm making a knock off roof rack following every company out there's design.
    A band saw is making quick work of the rough cuts. Happy this is working out so far.
    FINAL PRODUCT
  2. Mar 22, 2020 at 3:22 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Well at least you're honest. Interested to see your take on it. Or just sticking to a simple crossbar scheme?
    stun gun likes this.
  3. Mar 22, 2020 at 3:46 PM
    Dr. Emmett Brown
    Rough cut almost finished
    Two Tons likes this.
  4. Mar 22, 2020 at 4:05 PM
    hamchoi
    hamchoi Well-Known Member
    2019 Tacoma TRD pro
    Have you thought of using extruded aluminum bars for the cross'?
  5. Mar 22, 2020 at 4:10 PM
    Dr. Emmett Brown
    At most 40 pounds but it depends how many cross bars I decide to use. I'm thinking it's gunna be less than that weight
    shane100700 and Boghog1[QUOTED] like this.
  6. Mar 22, 2020 at 4:12 PM
    Dr. Emmett Brown
    Shipping to Hawaii plus cost of the bars is roughly $250 for like 4 or 5 of them I think. At that price point and for having no real use, I didn't think it was worth it. Also I'm set on using steel for the side rails and I don't really want a mix of metals at certain points so I'm going full steel. A 20' long 1/8" thick 1"x2" c-channel is $40. Can't go wrong. If down the line I feel the need for extrusion I will look into options. This rack is almost exclusively to mount cargo containers for camping gear and a mounted road shower so I don't need the flexibility of mounting points at the moment.
    bagleboy and AKGSD like this.
  7. Mar 22, 2020 at 4:13 PM
    Dr. Emmett Brown
    Adjusting bottom line to contour to the roofline. I didn't like how the flat bottom line looked right next to the roof
    AKGSD, tacoma16 and Boghog1 like this.
  8. Mar 22, 2020 at 5:33 PM
    Dr. Emmett Brown
    Side rails cut to shape. Going to rough cut some cross bars and the wind fairing and call it a day. Not bad for the first day.
    Malvolio, AKGSD, medic2230 and 2 others like this.
  9. Mar 22, 2020 at 5:39 PM
    Volund
    Volund Member
    Justin
    2020 Tacoma Off-Road - SSM
    Looks fantastic- what thickness are you using for your side panels and fairing?
  10. Mar 22, 2020 at 5:44 PM
    Dr. Emmett Brown
    I decided to go with 1/8". The only issue I'm noticing is the flimsiness of the side rails. However I just need to get my cross bar measurements very precise to hold the side rails perfectly straight and it will be all right. 1/8" is plenty strong enough to carry a good amount of weight. The most I see myself putting on these racks is 100 pounds. Rtt will go on the DIY bed rack. Haha
    shakerhood and AKGSD like this.
  11. Mar 22, 2020 at 5:49 PM
    Volund
    Volund Member
    Justin
    Awesome, You've got me thinking this is going to be a spring project. As much as I want to support vendors on the platform I really can't see paying $600+ for a rack...
    Are you looking at mounting up lighting or anything?
    AKGSD likes this.
  12. Mar 22, 2020 at 6:11 PM
    Dr. Emmett Brown
    I haven't decided on lighting yet. I am rattle canning the entire thing in the hopes that I can drill new holes or weld new mounts on in the future and touch up fairly easily.
    But yes, as a person who does everything myself I just couldn't see myself letting someone else do something for me that I could do so easily myself.
  13. Mar 23, 2020 at 6:03 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    1) I think if a person has the equipment and time, it might be a great opportunity to innovate instead of outright copy. 2) coatings. I imagine in Hawaii it’s important to consider what your finish is going to be.
    shakerhood and My Name is Rahl like this.
  14. Mar 23, 2020 at 6:12 PM
    My Name is Rahl
    Cold galvanizing compound under whatever color he picks should do it.
    stun gun[QUOTED] likes this.
  15. Mar 23, 2020 at 7:05 PM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    How many gigawatts does that saw take?
    Tacman19 likes this.
  16. Mar 23, 2020 at 7:23 PM
    Dr. Emmett Brown
    Are the factory holes in the roof M6?
  17. Mar 23, 2020 at 7:29 PM
    KILLINTIME
    KILLINTIME Like a Villain
    I like this! Good work op!
    Dr. Emmett Brown[OP] likes this.
  18. Mar 24, 2020 at 7:12 AM
    Georgeee28
    Georgeee28 Well-Known Member
    George
    Central Coast Cal
    I’m in to see the finished product!
  19. Mar 24, 2020 at 7:16 AM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Hopefully it turns out good!
  20. Mar 27, 2020 at 2:35 PM
    Dr. Emmett Brown
    Update. Making mounting brackets. I now see why prinsu makes the adjustability for the side rails left to right and part of the rails of themselves. The water roof trim contours slightly outward in the front. This is how they are able to set the rack up perfectly straight front to back. I have however decided to let my side rails contour to the roof trim. I think it'll look unique.
    The roof factory mounting holes are also slightly contoured as well so I had to hammer my mounting brackets to the correct pitch so they remain verticle 90 degrees
    House Forsaken and medic2230 like this.
