Roof Rack - does it come off ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phoneguy44, Mar 15, 2010.
  1. Mar 15, 2010 at 8:07 AM
    phoneguy44
    phoneguy44 [OP] Well-Known Member
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    guys, I've had my Tacoma for a week. Didnt know anything about them before I bought it other than "I had to have one !!"
    I bought it from a private owner and it came with the roof rack. Does the roof rack come off ?? If so, is it tough to remove ?
    Thanks
  2. Mar 15, 2010 at 8:27 AM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    You can remove the cross bars not the side rails
    I mean unless you want to stare at mounting bolts
  3. Mar 15, 2010 at 8:29 AM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Yes it does come off.
    No its not hard,
    BUT, you will need some extra parts to replace the rack once its off.
  4. Mar 15, 2010 at 8:36 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. You will need the rubber molding strips where the roof rack sits now. I'm surprised he didnt give them to you. I saved mine just in case I took it off.:cool:
  5. Mar 15, 2010 at 8:37 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    You can take off the rack, s'melt (smell and melt) it down do a liquid and then poor it into the grooves to seal them up and keep out any pesky gnomes
  6. Mar 15, 2010 at 8:40 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    You can also take it off and sell it to me for $100. I would even send you my rails, to cover yours up.
  7. Mar 15, 2010 at 8:43 AM
    hendooman
    Jeff
    KC
    Agreed, make me a deal!!!
  8. Mar 15, 2010 at 8:46 AM
    dog tired
    NE Ohio
    Are you guys saying that the rack is not attached with those nutless ( work one side only ) bolts - I forget the name of them ?
  9. Mar 15, 2010 at 8:53 AM
    phoneguy44
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    I'm not ready to part with it yet, truck is still new to me and I'm loving all if it right now............. but will keep you in mind.
    Thanks guys.
    P.S. Sorry I didnt do a search on this earlier, didnt think about it. I did one and saw there was a post on this already. My bad.
  10. Mar 15, 2010 at 10:13 AM
    JKD
    JKD Well-Known Member
    Nice looking truck, by the way. Dark is hard to keep clean--but it sure looks pretty when it is!
    (My last car was black...)
  11. Mar 15, 2010 at 10:17 AM
    phoneguy44
    Dennis
    Oxford, Alabama
    06 4x4 Double Cab
    Thanks man.
    Just did the Mothers Clay on it and 2 coats of wax. That stuff works like a champ !!
  12. Mar 15, 2010 at 10:23 AM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    I bid $150...when you're ready!
  13. Mar 15, 2010 at 10:28 AM
    ENIGMA206
    ENIGMA206 Well-Known Member
    Palm Bay, FL
    07 4X4 Off-Road DC
    Tunes Tonneau On-board Air Firestone Air Bags
    I just removed mine last week. Nothing to it. Just need to work a trade with someone on TW for their ditch strips. You'll need 10 each 6MM socket set screws (about 3/8" long) and some some type of caulk to plug the bolt holes. You will also need to get two strip clips from the dealer for about $2 each. These hold down the leading edge of the strip under the windshield molding. I can send you the part number if you need it. These clips will need to be attached with some two-part epoxy. Last but not least, you'll need some 3M double-sided body molding tape from the local auto parts store. It was real easy to do. Worst part was cleaning off the old soap and debris that was under the rails. Also needed to do a little polishing because the rubber bases rub into the clear-coat a little. Not bad, but enough to bother me.
