Roof Rack Economy Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tactitcoma, Sep 25, 2016.
  1. Sep 25, 2016 at 8:13 PM
    tactitcoma
    tactitcoma [OP] New Member
    12 Tacoma build in progress
    Hello, I'm new here. I own a 2014 doublecab TRD off road. I was wondering if anyone had any intel on roof racks and other external accessories effecting performance/ handling/economy.
    Thanks
  2. Sep 26, 2016 at 5:47 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I have a "rack it" lumber/ladder rack for work and it definitely negatively effects gas mileage. I'd say by 1 or 2 mpg. Might not seem like much but it adds up.
    vbibi likes this.
  3. Sep 26, 2016 at 7:49 AM
    Pigpen
    Dan
    Northwest Montana
    I lose about 1.5 mpg when I have my Yakima rack on.
    vbibi likes this.
  4. Sep 26, 2016 at 7:50 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    unloaded??
    vbibi likes this.
  5. Sep 26, 2016 at 7:50 AM
    Pigpen
    Dan
    Northwest Montana
    Yes
    Just the bars and the faring
  6. Sep 26, 2016 at 7:51 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Yeah.
    I lost 3 MPG with Yakima bars on a previous car. Added the wind fairing which helped, but still lost 2.
  7. Sep 26, 2016 at 7:52 AM
    Pigpen
    Dan
    Northwest Montana
    On my last truck I had the same fuel economy with an unloaded rack and with the Rocket Box mounted to the rack - both with the faring on the rack. No faring = terrible noise and worse mpgs.
  8. Sep 26, 2016 at 7:53 AM
    T4RFTMFW
    Agreed on the noise.
    Alexely999 likes this.
  9. Sep 26, 2016 at 8:01 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    I design and sell roof racks and since the beginning have had one on my truck. I have monitored my mpgs pretty closely and have never really noticed much of an effect. That being said, I have a lot of other modifications to my truck that do affect MPGs.
    I think if you have a close to stock truck and are trying to maximize MPGs then a roof rack with have some effect. If you have oversized tires, heavy armor, a shell, weight in the bed, etc, then you have already lost most the the efficiency.
    My truck seems to hit a barrier at about 14 MPGs where the only thing I can do to get it to drop below that range is pull a trailer, or drive in 4 low for a really long time.
    In normal highway driving my Mpgs stay right between 15-16 regardless of whether I have the rack on, loaded, unloaded, off, or have 800 lbs in the bed.
  10. Sep 26, 2016 at 5:53 PM
    Flying_Taco
    Flying_Taco "In there"
    James
    Tacoma, WA
    2014 TRD OR
    Welcome! Maybe a loss of 1 with my Prinsu rack. Probably a negligible loss considering I lost around 4 mpg with bigger tires.
