Roof rack for access cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AYates, Oct 28, 2016.
  1. Oct 28, 2016 at 8:49 AM
    AYates
    AYates [OP] Well-Known Member
    Adam
    Santa Barbara
    long travel sleeper
    boxed frame, DMZ rear with dual Fox shocks, Total chaos and Icon front. Brute Force Fab high clearance Bumpers, Dirt King LCA's , Dirt Designs shock tower brace, AFE cai, Doug Thorly Long tube headers, UDR mid pipes, Scan Gauge 2, UDR cat sim, Smity Built wench, Fox secondary shocks, Total Chaos spindles {Glorified Welder}, Lund cover, custom headache rack, Total Chaos cam gussets, DeNunzio Racing tube connectors,
    Hi, does any know of a product or method to put rails on a 2008 access cab? The end result would be putting a Baja type rack on top to carry a spare tire. Any help would be appreciated.
    Thanks Adam
  2. Oct 28, 2016 at 9:31 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    I have seen threads on people cutting a factory double cab rack in half and using that. access cabs so have the first set of holes already there
  3. Oct 28, 2016 at 10:35 AM
    AYates
    Adam
    Santa Barbara
    long travel sleeper
    I was reading another thread on here and supposedly there art no attachment points under the plastic strip on access cabs and that people were sust screwing to the sheet metal. I was hoping that wasn't true and didn't want to remove mine until I knew more. That is a good idea with the double cab rack if something is there though. I also found that Smitybuilt does make a cage that would work dimension wise.
  4. Oct 30, 2016 at 1:59 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    Rivnuts or nutserts are your friend, there are no mounting holes towards the back of the cab. Yakima or Thule are another option and totally easier if you're not comfortable drilling in to the roof of your truck.
