Roof rack hole leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mdcmn7, Mar 24, 2014.
  1. Mar 24, 2014 at 2:05 AM
    mdcmn7
    mdcmn7 [OP] Well-Known Member
    Chuck
    East Coast
    So I just took the roof rack off of my double cab and replaced the black weather stripping. Does anyone know if the mounting holes for the roof rack go All the way through the roof and need to be sealed?
    I would hate a leak in my new truck
  2. Mar 24, 2014 at 2:48 AM
    Tacoma Mike
    Southern Maine
    Yes
    If you look at the threads of the screws there should have been sealant on the threads.
  3. Mar 24, 2014 at 3:02 AM
    mdcmn7
    Chuck
    East Coast
    And now that my roof rack has been removed what is the right way to seal the now open holes?
    What type of tape did toyota use from the factory
  4. Mar 24, 2014 at 3:24 AM
    Tacoma Mike
    Southern Maine
    I would look at the bottom of the weatherstrip and see if a short screw would clear and have the strip lay flat. If it does a little silicone on the threads and install. If not fill the hole with silicone.
    Double sided tape.
  5. Mar 24, 2014 at 4:05 AM
    mdcmn7
    Chuck
    East Coast
    That's exactly what I was thinking. The holes are actually recessed a bit and I think a short screw would probably fit just fine, and if I do it that way it would be easier to remove if I change my mind later
    I was also considering some double sided tape at either end of the ditch moulding. Are there any types of tape that are more suited to keeping stuff like this in place? Toyota had some foam double sided tape at the back, but nothing at the front. Vs glue/silicone
    Unfortunatelyy truck didn't come with a rack, so I installed a oem one on the truck and hated the look of it, so now it's back sitting in its box
    Since this is a 2014 I want to make sure I get everything put back together right
  6. Mar 24, 2014 at 5:26 AM
    Tacoma Mike
    Southern Maine
    yeup i know what you mean
    myself i use dabs of silicone every 6 inches and you can get non foam double tape at a jobber i would imagine. on the back you definately need the tape.
    i
  7. Mar 24, 2014 at 5:42 AM
    mdcmn7
    Chuck
    East Coast
    I have some 3m moulding tape already and figured that would do the trick
  8. Mar 24, 2014 at 7:11 AM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    I taped mine over with gorilla tape. Its duct tape on steroids. Held up fine for a year. Check annually whatever you decide to do.
