Roof rack holes are all filled with silicone, any recommendations on removing it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yota_Max, Aug 25, 2022.
  1. Aug 25, 2022 at 1:53 PM
    Yota_Max
    Yota_Max [OP] Active Member
    2020 TRD Offroad Quicksand
    like the title states, all of my roof rack holes are filled with silicone to prevent leaking from when i removed my last rack. I decided i want to put another rack on my truck. Does anyone have any strategies to removing the silicone from the bolt holes so i can throw a rack back onto the roof?
  2. Aug 25, 2022 at 2:03 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I'd loosen/pick out what I could with a small pick then run a tap or rethreader thru to clear the remainder.
    nhpoke, soundman98, Drainbung and 2 others like this.
  3. Aug 25, 2022 at 2:57 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    ^^ This. You might consider using a drill bit small enough to clear the threads first. Best if you use a bottoming tap to clean the threads.
  4. Aug 25, 2022 at 3:11 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Get the first few threads clear and then run the bolt in.
  5. Aug 25, 2022 at 4:35 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Just run the bolt through slowly. When it binds up back it out and clean it out then retry
    musicisevil and ORtoCOTaco like this.
  6. Aug 25, 2022 at 4:39 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    This
    musicisevil likes this.
  7. Aug 25, 2022 at 4:40 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
  8. Aug 25, 2022 at 5:16 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    all good solutions. I have a ice pick that has a small hook at the end. I'd imagine I'd use that. Small drill bit is good too.
  9. Aug 25, 2022 at 5:18 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    mabepossibly[QUOTED] likes this.
  10. Aug 25, 2022 at 5:22 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Suggest in future: use a little Teflon tape and put the original bolts back in the hole.
  11. Aug 25, 2022 at 5:25 PM
    forana
    Kaneohe, Hawaii
    I don't trust only tape. I know it's stupid but I don't. I used butyl sealant and then for good measure I put a layer of butyl tape over the holes before putting in bolts.
    vicali likes this.
  12. Aug 25, 2022 at 6:10 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Toyota uses stickers.
