Roof Rack Light Wiring Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JGJ, Mar 15, 2010.
  1. Mar 15, 2010 at 7:08 PM
    JGJ
    JGJ [OP] Well-Known Member
    I have the roof rack, just need to know the most common/best place to run the wires to the cab from outside on the roof.
    also.,... Will I need to pull apart my headliner?
    THANKS guys!
  2. Mar 16, 2010 at 8:22 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    What kind of rack and where are the lights located? Front vs. rear will make a difference.
    Pulling the headliner would certain make running wires a whole lot easier. You might want to consider it just for hiding wires.
    Got any pictures of what you're installing?
  3. Mar 16, 2010 at 9:05 AM
    JGJ
    Sorry guys, I just picked up a stock Double Cab Toyota Tacoma roof rack. I would like small lights in front and back. I would like to conceal the wires as much as possible.
    THANKS!
  4. Mar 16, 2010 at 9:20 AM
    mjp2
    NJ
    I was going to suggest routing the wires through the bolt holes that are there for the stock roof rack but that obviously won't work. :p
    Are you opposed to drilling through the sheet metal? If so, maybe run the wires to the rear of the rack and run them though the rear window insulation?
  5. Mar 16, 2010 at 9:43 AM
    JGJ
    Im not scared to drill a hole. Just need to know whats the best method of keeping the water out. I've heard of using a "Myers Hub", but wasn't sure if that was really ness.
  6. Mar 16, 2010 at 12:05 PM
    Sack17
    Sack17 Well-Known Member
    Andrew
    Sanibel, FL
    05 Tacoma DBL Cab TRD Sport 4x4
    Bed lights Blacked out sport wheels blacked out emblems BHLM Spidertraxx 1.5" wheel spacers factory roof rack custom yakima wind fairing w/ PIAA off road lights up top snowboard/ski rack surf board pads fog light mod custom interior cup holder l.e.d. lights Bestop topper custom L.E.D. rear facing lights Maglite mod (2 front seats) 3.25" in the front 2.5" in the rear 6 Hella 500ff's (w/ Silverstar's) Silverstar Ultra's in headlights Silverstar Ultra in fogs (retro-fitted 65w 9005's) Hi-Lift (mounted on side of bestop) Shovel (mounted on side of bestop) custom 1.5" body lift
    I didn't want to drill a hole in my roof so i ran the wires down the windshield seal on both sides for the front. I haven't put the rear ones on yet cause I'm getting a Bestop soft top and am gonna mount some rear facing ones on the rear support bar. Just check out my gallery, you can barely notice the wires.
