Roof Rack Lights Help Needed.
Discussion in 'Lighting' started by Blueberry, Mar 1, 2012.
  1. Mar 1, 2012 at 5:48 PM
    Blueberry
    Blueberry [OP] Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    So I'm welding up a custom roof rack this weekend and plan to install 4-7" lights up front and 5" bed lights on the back of the rack. My question is to those who have done this already. How did you route the wiring from the roof to the cab? Any advice on how to run wiring from the back of the roof for bed lights would be great too, or just point me to a thread where this has already been answered. Thanks in advance. :)
  2. Mar 1, 2012 at 10:51 PM
    Blueberry
    Nick
    Newton, KS
    Nobody?
  3. Mar 1, 2012 at 10:58 PM
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
    Try the search bar at the top of the page. I'm in my phone so I can't be of much help
  4. Mar 1, 2012 at 11:14 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    I've been wondering the same thing.
  5. Mar 2, 2012 at 12:08 AM
    Blueberry
    Nick
    Newton, KS
    So am I LOL
  6. Mar 2, 2012 at 5:29 PM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Good luck! Hopefully someone chimes in who is not on their phone. Still thinking about adding some lights to a Yakima basket on the shell.
  7. Mar 2, 2012 at 5:36 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i’ll see if i can find a thread for you. hang on
  8. Mar 2, 2012 at 5:40 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    ok since i’m a little confused on what exactly you what. i tryed searching and could not find much.. i would talk to colinb17 he is a member in FL and i think has a custom roof rack with like 6 lights on it.
  9. Mar 2, 2012 at 5:55 PM
    Blueberry
    Nick
    Newton, KS
    Will do man. Thanks.
  10. Mar 6, 2012 at 12:26 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    i would also like to know
  11. Mar 6, 2012 at 5:52 PM
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    If you're looking for an easy, non-permanent solution, I don't think you'll find one.
    Short of running the wire through a back window or shutting your door over them, you'll pretty much have to drill. You might be able to pry back the grommet on the 3rd brake light and run the wires through that hole.
    I just mounted five 7" HIDs on my roof and I will be drilling into the roof to route the wires. My plan is to run them down the inside of my A-pillar.
  12. Mar 6, 2012 at 5:54 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    do you have pics od the lights?^
  13. Mar 6, 2012 at 5:55 PM
    Bobber Bill
    Los Angeles, CA
  14. Mar 6, 2012 at 6:09 PM
    Baja Gringo
    Baja Gringo Well-Known Member
    Isaac
    Las Vegas, NV
    '11 TRD SPORT
    3" ProComp coilovers , Radar Renegades R7 M/T-295/70R17 , ProComp rims, N-Fab step bars, CB Radio, ICOM Race Radio, BajaRack roof cage and 32" light bar, LED MOD (Green) interior lights, Debadged, Lime Green Devil Horns Emblem, Tiregate, Roto Pax, custom rear led strobing light bar, custom rear bumper
    I have 4 lights on the front and 2 on the back of my rack. All I did was run my wires in black flux down my back window (off to 1 side), along the frame, and up in the gromet under the driver seat. Once in the cab it's up to you.
  15. Mar 6, 2012 at 6:19 PM
    joes06tacoma
    Joe
    Central Coast, CA
    My buddy has a 95 Grand Cherokee with roof mounted lights. On his Jeep, we managed to run two 10 AWG wires from the rack, down into the crack between the doors and the roof line, tucked the wires behind the weather stripping and ran them forward all the way to the bottom of the A pillar, then we tucked them behind the front fender and under the hood. We did this on both sides of his jeep. One side had positive and negative for one pair of 130W lights, the other side fed a second pair of 130W lights. I haven't investigated the Tacoma to see if it's possible, but it may be.
  16. Mar 6, 2012 at 6:37 PM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
  17. Mar 6, 2012 at 7:37 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I ran my wiring inside the tube and through the existing bolt hole on one side. Check gallery for pics...
  18. Mar 6, 2012 at 7:58 PM
    Blueberry
    Nick
    Newton, KS
    Wow this thread took off like a rocket! Thank you all for your input and keep 'em coming. Basically I'm just looking at different wiring options and routing locations.
  19. Mar 7, 2012 at 10:40 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    ill see if i have some pics of mine to put up
    edit: nvm sorry no pics... i drilled a hole into my cab and put a rubber bushing around the hole and the wires through it, works perfect
  20. Mar 9, 2012 at 3:08 PM
    ffdawson
    ffdawson Dirt Head
    Penngrove
    08 Tacoma Rugged Trail 6spd
    Kings, Armor, big taaaarrrs
    Sub'd. And Blueberry, I'm planning a similar build, and would love to see what you come up with as far as routing and mounting... (trying to avoid the "hole in the roof method...)
