Roof Rack Lights Help Needed.
Discussion in 'Lighting' started by Blueberry, Mar 1, 2012.
  1. Mar 9, 2012 at 4:57 PM
    Blueberry
    Blueberry [OP] Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    I'd like to avoid it too. But it's looking like I'm going to have to drill in the rack channel then string the wires underneath the A-pillar plastic. I guess that won't be to hard to do.
  2. Mar 9, 2012 at 9:50 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    If you have a double cab, you can run wires through existing rack bolt hole. If access cab, you gotta drill!
  3. Mar 12, 2012 at 8:27 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Hey OP, if you haven't already figured out how you want to route the wires, here's how i did it:
    underneath the rubber weather strip, drill however man hoes you need in whatever diamiter is apropriate. to run them to power/switches, the roof liner will pop right out of the rubber moulding vvvvvvv
    once you get all of the wires run inside the liner, it will pop right back into place. then remove the two caps on the "oh-shit" handle and remove the bolts under them. after that, i nice pull with remove the entire a-pillar cover. you can run all of your wires right down it and then pop/bolt the cover and handle right back into place vvvvvv
    with the wires run to the bottom of the a-pillar, itis easy to fish them through the dash to wherever they need to go (switch panel, through the fire wall, etc). easiest way to get to them fromt the a-pillar is either all of the way under the dash by going under where the pedals are, or pop out the coin holder that gives you access to the interior fuze panel vvv
    when all's said and done, jsut make sure you have nice connections where splices are needed, and keep them well insulated and waterproof. a little silicone should plug up any holes you have to drill in the roof channels.
    it's overall a pretty easy wiring job, and before you know it, your truck won't show up in night pictures anymore :p
  4. Mar 13, 2012 at 3:03 AM
    Blueberry
    Nick
    Newton, KS
    Thanks Colin! That helps a ton. Glad to see the headliner comes down that easily.
  5. Jul 13, 2012 at 12:20 PM
    devearll
    devearll Member
    2011 Tacoma TX Pro
    2011 Tacoma TX Pro
    i dig the white and lift you did...looks good!
  6. Jul 13, 2012 at 12:20 PM
    devearll
    devearll Member
    2011 Tacoma TX Pro
    2011 Tacoma TX Pro
  7. Jul 13, 2012 at 12:20 PM
    devearll
    devearll Member
    2011 Tacoma TX Pro
    2011 Tacoma TX Pro
  8. Jul 22, 2012 at 11:34 PM
    spartanhockey6
    spartanhockey6 My truck rattles, A LOT.
    Trevor
    Talent, OR
    2010 White Trd Sport
    Money Pit
    Yesss thank you colin, I'm mounting my yakima basket up on the roof and wanna mount some hella's or KC's up there. Had no idea where to run the wires but that sounds like a solid plan!
  9. Jul 24, 2012 at 1:17 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Since my rack wasn't mounted t the roof but just suspended over it I was just going to run wires throu the cab out the back of it through the small lower grometted hole already there then just up on the inside of the bars.
