Roof rack options?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BlackTacosMatter92, Mar 31, 2017.
  1. Apr 14, 2017 at 10:21 AM
    mmrocek
    mmrocek Name is Bill Burke, and this was an exercise.
    William
    2016 Taco Offroad TuRD
    icons, 4.88’s, winch, sliders, skids and some dinky little 285’s
  2. Apr 14, 2017 at 12:13 PM
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    OP, if you are going for look, Prinsu is the way to go and def worth the investment.
    If you are deadset on just using the basket your buddy is selling you, go for the OEM rack which runs about $300.
    http://www.ebay.com/itm/like/332181791104?lpid=82&chn=ps&ul_noapp=true
    EDIT: Found an off brand even cheaper for $210
    http://www.ebay.com/itm/05-15-Toyota-Tacoma-Double-Cab-Roof-Rack-Side-Rails-Luggage-Carrier-Bar-OE-Style/182342158456?_trksid=p2385738.c100677.m4598&_trkparms=aid=222007&algo=SIC.MBE&ao=1&asc=20160908110712&meid=63f6b61ba90e4ba88f4e675a0d7db375&pid=100677&rk=7&rkt=22&sd=332181791104
  3. Apr 14, 2017 at 1:43 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Is the front runner rack and 2 load bars right around that price too? Not the slimline loaded one. Just the one with the 2 bars. Those look nice from a utility perspective.
  4. Apr 14, 2017 at 1:49 PM
    Jack0928
    Jack0928 Kind of a Well-Known Member
    Jack
    Huntington Beach, CA
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    Just get the stock rack, and get some rack bars off Amazon. Prolly $200
  5. May 29, 2017 at 10:38 AM
    Yota Del Taco
    Yota Del Taco Active Member
    Naples Fl
    2017 TRD Pro
    Happy Memorial Day. Thank you for your service. Because of you, I have the freedom to geek out here on TW. I've got one in my shoping cart at Prinsu $659. Lots of options to choose from. Their lead time on the website is now 7-8 weeks. Have both the 32" and 40" cut out in the in the cart, but having seen your rig... I'm sold on the 40" Did they do your lighting or did you have it done somewhere else. Anybody ever see a roof rack in red?
    Also looking for a thread on secure Tonneau Cover that also easily allows for spontaneous wife to buy furniture.
  6. May 29, 2017 at 12:49 PM
    m603holden
    Marteeen
    New England
    I think you got the wrong quote bub
  7. May 29, 2017 at 1:02 PM
    Yota Del Taco
    Naples Fl
    2017 TRD Pro
    Sorry new here, thought I used multi quote on #17 and both you and AddicTioN would get quoted.
  8. May 29, 2017 at 2:26 PM
    m603holden
    Marteeen
    New England
    Not a problem. Just wasn't sure if you were aware.
  9. May 29, 2017 at 4:47 PM
    Wdwrkr
    Wdwrkr Well-Known Member
    Pete
    Nantucket MA
    2016 TRD Off-road DCSB
    None :-((. Yet :-))
    I've got the Gobi stealth rack on mine, and could not be happier. My first choice was the Baja rack because of the price point, but after 10 weeks of waiting they told me it would be another 4-6 weeks and my shipping costs were underestimated. All of which was unacceptable to me, so I called Gobi, which I always felt was the best looking, I explained what I had been through, and could not be happier with both their product as well as their customer service
  10. May 29, 2017 at 9:14 PM
    batong_23
    batong_23 vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    Hi, i see alot of this saying its only for 2005 to 2015 models. Will they fit the 2017 double cabs?
  11. May 29, 2017 at 9:17 PM
    Wallbright
    Wallbright Well-Known Member
    2017 MGM DCSB SR5
    I ordered a Warrior roof rack for around $550 shipped. The air dam was another $90 though. It should come in this week and I can report on the build quality and ease of install. Here's a picture of what it looks like (ignore the horribly wrapped truck). I went with it over Prinsu because of the wait times. Prinsu was 8+ weeks, Warrior was 1 1/2.
  12. May 29, 2017 at 9:18 PM
    Wallbright
    2017 MGM DCSB SR5
    There are two versions, the new one has a higher weight rating. But both will work with the third gen double cabs.
  13. May 29, 2017 at 9:28 PM
    batong_23
    SoCal
    Oh ok. So its safe to buy the old gen for my 2017? Thanks!
    Wallbright[QUOTED] likes this.
  14. May 29, 2017 at 9:59 PM
    Wallbright
    2017 MGM DCSB SR5
    Yes but I would search here before you pull the trigger just to be safe. Just type in the model number or part code in the search bar and select the third gen subforum only.
    batong_23[QUOTED] likes this.
  15. May 30, 2017 at 10:24 AM
    #35
    Skyking90
    Skyking90 Well-Known Member
    Steven
    Anchorage, Alaska
    2016 Tacoma TRD Sport
    Icon Stage 4, STT Pro 285/75/16, SCS Stealth6, Bakflip MX4
    How easy is the install of the prinsu cabrac? Also is this something you could install and reinstall depending on if you are using it for a tent up top? Not sure if I would like it on 100% of the time driving around... Does look pretty good though!
  16. May 30, 2017 at 12:12 PM
    #36
    DRJ1014
    CA
    Install I would say is a 5 on the difficulty scale of 1-10. Its not something that is easily taken off once installed. The bolts are under the cross bars and require you to take the cross bars off to gain access. Also, you are cutting/punching the roof stripping so there will be 5 holes on each side of the roof stripping. You are sealing the holes with silicone before you put the bolts in (the holes go all the way through the roof and not sealed correctly may cause water to leak)
    Prinsu is meant to be installed and left on.
  17. May 30, 2017 at 12:15 PM
    #37
    Skyking90
    Steven
    Anchorage, Alaska
    Makes sense, just watched a video on the install and saw that same deal with sealing the roof strips.
  18. May 30, 2017 at 12:18 PM
    #38
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Ordered mine middle of april and just installed this past weekend, lead times are only bad after a groupbuy.
    Wallbright likes this.
  19. May 30, 2017 at 12:22 PM
    #39
    Skyking90
    Steven
    Anchorage, Alaska
    As for the Prinsu Cabrac, I'm assuming throwing a Tepui or CVT tent up there along with a 200 pound person is totally fine weight wise?
  20. May 30, 2017 at 12:23 PM
    #40
    Broccoli
    Airdrie Alberta
    There is a member who color matched his prinsu, its in the prinsu bs thread ill try and find for you, it looked really good.
