Roof rack parts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thundjet, Dec 20, 2011.
  1. Dec 20, 2011 at 8:03 PM
    Thundjet
    Thundjet [OP] Well-Known Member
    2012, V6, Sport TRD, Auto, 4 wd
    Where can you buy the bars that go across the factory roof rack? Would like to be able to carry a canoe on the rack this coming summer.
  2. Dec 21, 2011 at 10:12 AM
    Thundjet
    Maybe I am VERY confused about how these roof racks work. Can you remove part of it and set it up so you have a bar going across it?
  3. Dec 21, 2011 at 10:22 AM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    Take a good look at the rack, each lateral bar is connected to one side rail on a pivot, the other end of the lateral has a latch that locks it into the opposite side rail when positioned accross the roof. When you no longer need the laterals, they unlatch and swing back across the roof and latch back into thier side rail.
    I added this as an aftermarket option only because you can detach and swing the laterals out of the way and make it easy for snow removal.
    Hope this helps.
