Roof Rack Poll
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LBPtaco, Mar 25, 2010.
Which Roof Rack is the BEST?
  1. OEM
    42.8%
  2. THULE
    18.7%
  3. YAKIMA
    19.2%
  4. CUSTOM
    8.0%
  5. OTHER
    11.3%
  1. Apr 13, 2012 at 10:50 AM
    #221
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    My only complaint about my baja rack is being overbuilt for the application. Don't get me wrong, I love that the rack is solid but it was designed to mount onto the Tacoma OEM roof rack with a limit of 100 pounds. The tacoma version of the baja rack should be a bit less robust so you can carry more cargo. The basket weighs 38 pounds so it doesn't leave much capacity for cargo.
    I always wished they designed their basket to bolt straight onto the roof. I'm not sure when this happened but they DID design a 2nd generation that bolts directly onto the roof!! :D http://www.bajarack.com/toyota-tacoma
    I need this new one. Anyone local want to buy my first generation baja rack? I need to post pictures but I have serious concerns about the arms on my OEM roof rack. They are not solid enough and I came back to this thread because I want to swap out my OEM roof rack with something else. Now I want to swap out the whole setup with the new bajarack bolt-on. BR-TYTCM-1-0 http://www.bajarack.com/toyota-tacoma-gallery
  2. Apr 17, 2012 at 8:17 PM
    #222
    tommyg29
    tommyg29 Well-Known Member
    South Miami, FL
    12 DCLB PreRunner Sport
    thinking of adding an oem to my 2012, but admittedly havent read this entire thread. Does the oem rack interfere with the xm radio shark fin? Cant imagine toyo would design it such that it would, but...just askin
  3. Apr 17, 2012 at 8:30 PM
    #223
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    I'm runnng a custom one right now. built for strength. @ 185 lbs, i can jump as high as i can on it without issues.
    this one is for a member up north who has my old Thule. it bolts directly to the crossbars on the thule like the old style baja racks to the OEM.
    and here's the one i'm currently working on for an fellow florida member. this one is all out with a tight floor grid and front cage to protect the 20'' rigid industries light going on it. I am also cutting fairings for the front out of 1/4'' clear acrylic fors lightly better aerodynamics and some extra protection for the light.
  4. Apr 18, 2012 at 1:55 PM
    #224
    Costa09
    Costa09 Well-Known Member
    GA
    08 PreRunner
    Nice work man! From the looks of your new one you made it to mount into the stock holes in the roof, correct?
  5. Apr 18, 2012 at 2:09 PM
    #225
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you got it. both mine and the one i'm working on now mount to the factory holes.
  6. Apr 22, 2012 at 9:20 PM
    #226
    weazel
    weazel Well-Known Member
    185 LBS :eek:
  7. Apr 22, 2012 at 9:22 PM
    #227
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  8. Apr 23, 2012 at 12:28 AM
    #228
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    :jellydance::jellydance::jellydance:
    I want one :drool:
  9. Apr 23, 2012 at 1:15 AM
    #229
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    holy shit that's heavy!!!
    I thought mine was heavy @ 70Lbs
  10. Apr 23, 2012 at 5:16 AM
    #230
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    oh, no haha.....i was saying i weigh 185 lbs. the rack is only about 60-65 lbs.
  11. Apr 23, 2012 at 7:22 PM
    #231
    Freeskier11
    Freeskier11 Member
    Brett
    Wyoming
    TRD Taco
    I will need to post some pics of the stealth/ranger by Gobi.....they look sweet!
  12. Apr 23, 2012 at 7:35 PM
    #232
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i love you roof rack colin! (i almost said that i love your rack but i thought that may sound wired. so i made sure to say roof rack.)
    what would it coast to make something like that? i kinda want one but i want to go custom not OEM.
  13. Apr 24, 2012 at 5:04 AM
    #233
    bikinit
    bikinit EXTREME...poser
    Mass.
    '12 TX Pro DC SB V6
    Thinking about getting a OEM rack for my skis (SB), will it support a 20' extension ladder?
    Thanks.
  14. Apr 24, 2012 at 5:12 AM
    #234
    xmadcowx
    xmadcowx Old man club. Sold out to Ford.
    Connecticut
    19 Raptor/21 Bronco. 12 OR sold. 05 xrunner sold.
    Functional
    Going to steal Colins thunder here and post updates to the rack hes working on right now. The little legs in front will be removed before it's finished, so ignore them.
  15. Apr 24, 2012 at 9:06 AM
    #235
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    looks good! you should put some 4” rigid LED bars on. 1 on each side and 2 on back. no matter where someone is around you they will get out of your way. lol.
  16. Apr 24, 2012 at 9:35 AM
    #236
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    He's already putting a 20'' RI up front, so he probably won't even need the rears.....the beam will just bounce off the ozone layer untill is goes full circle and catches up behind him
    Zach, shoot me a PM and we can discuss some rack options and pricing for you.
  17. Apr 24, 2012 at 10:00 AM
    #237
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    holy overbuilt basket that thing will survive a Sasquatch attack
  18. Apr 24, 2012 at 10:01 AM
    #238
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    :spy:
  19. Apr 24, 2012 at 11:40 AM
    #239
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    true. lol.
    so OZ and or larry can attack it and it wont hurt it? :D:p:cool:
  20. Apr 24, 2012 at 11:44 AM
    #240
    xmadcowx
    Connecticut
    Functional
    I think what happened (or so Colin claims, lol) was a slight over estimate for the steel order, so instead of a 10x10 floor, it ended up being something like 6x7 squares. I'm 100% fine with it, it looks so angry; plus now I won't be so worried about firewood slipping through and damaging the roof. I guess the acrylic fairing is pretty intense as well, haven't seen it yet but Colin said it looks damn near bulletproof.
