Roof Rack Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06TacomaTRD, Nov 23, 2014.
  1. Nov 23, 2014 at 6:30 AM
    06TacomaTRD
    06TacomaTRD [OP] Well-Known Member
    Brett
    South Carolina
    2011 MGM TRD OR PreRunner
    See Link --->
    I'm debating between getting an OEM or an aftermarket roof rack for my truck, mostly because I read somewhere that an aftermarket one (with the clamp) can damage the paint over time. I was wondering if this has happened to any of you running an aftermarket roof rack?
  2. Nov 23, 2014 at 6:47 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    nope but I did plastipped the paint where there is contact. The only advantage of the OEM rack is being able to easily store away the crossbars.
    I'm not a fan of the bulky OEM rack look and most aftermarket accessories are geared towards Yakima or Thule racks.
  3. Nov 23, 2014 at 6:55 AM
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    I have the Yakima towers that clamp on the truck, and yes they will possibly damage the paint. Mine over the past few years they have slowly rubbed the paint off where the metal clamp pulls up on the roof. Luckily its on the inside of the door jam where the rubber seal touches the roof, so you can not see it unless the door is open. Yakima gives you little stick on plastic pads that are supposed to stick on the metal clamp, they are useless.
    Also take note on what you want to carry! I put 2 full sized 2 person kayaks on my roof and drove 1 hour down the highway. Where the towers where sitting on my roof they actually creased the roof line. The kayaks where under the weight limit for my towers/bars, but way too much wind drag. One yak lying upside-down on the rack is fine.
    Overall I love the rack setup. Everything I have purchased is used, Yakima/Thule prices are out of control. I have Yakima towers, bars, basket, ski clamps, and kayak mounts.
  4. Nov 23, 2014 at 9:21 AM
    Pigpen
    Dan
    Northwest Montana
    my Yakima f-ed mine up
  5. Nov 23, 2014 at 9:28 AM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    Yeah the bulkiness of the OEM is why I'm hoping to find an aftermarket one. I'm also worried about tbe damage it may cause. Plasti dip may be a good solution.
  6. Nov 23, 2014 at 9:34 AM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    That sucks to hear, but glad it's not noticable unless you have the door open. I'm wondering if you could buy the foam strips kinda like the ones you put under toolboxes and put them on the metal/plasti clamps.
    What about the rubber part, does it bother the paint in any way?
  7. Nov 23, 2014 at 9:41 AM
    Ianp05
    Ianp05 Well-Known Member
    IAN
    DETROIT
    2006 Double Cab 4x4 TRD Sport
    Yeah the after market ones def. damage the paint. This is not only inside the door where the clamp meets the car, but also on top of the car if you let the rubber pads wear out too long. Left my last clamp set on for 4 or 5 years and the rubber pads rotted out into the paint. I've been told there s a spray on plastic coating that can help with this.
    That being said, the functionality and warranty on the aftermarket brands far exceed that of the factory brand. Not to mention that they're transferable from truck to truck. I have now mounted my set on 3 cars without having to repurchase.
  8. Nov 23, 2014 at 10:23 AM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    I have no doubt the functionality of an aftermarket rack is better than the OEM. I'd like to see how bad the damage may be and if there may be a solution to prevent this. I wonder if you could buy the foam strips (soft on one side sticky on the other) and stick it on the rack with the foam touching the paint instrad of the actual rubber or plastic/metal clamp. Does this sound doable?
  9. Nov 23, 2014 at 2:55 PM
    StickShifty
    New Jersey
    2012 AC 4WD 6SPD
    No the rubber part does not. After having them on for awhile a quick wash and wax of the area and your good to go.
  10. Nov 23, 2014 at 3:07 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    Bajarack.com or a guy on here (Prinsu studio?)make a pretty nice rack for our trucks. I wasn't impressed with the OEM one. I've used "clear bra" material before on other cars where the yakima/Thule make contact, neve tried plastidip but I'd guess it works the same.
  11. Nov 23, 2014 at 3:13 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Derp would get rubbed off and scratch just like the paint job will. Short term help, sure.. But its just adding a minimal layer of extra protection. It isn't as durable as regular paint, and adding some foam tape to the Yakima hooks would probably be a better option IMO.
  12. Nov 23, 2014 at 3:16 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    If you get the right after market one, it won't damage your paint :thumbsup:
  13. Nov 23, 2014 at 3:22 PM
    T4RFTMFW
    What he said.
  14. Nov 23, 2014 at 5:53 PM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    That's good to know.
  15. Nov 23, 2014 at 5:57 PM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    S,.
    Yeah I looked at the Baja racks. They look awesome, but way overpriced for what I am wanting to use it for.
  16. Nov 23, 2014 at 6:00 PM
    geekhouse23
    PrInSu.
    I started looking at the Baja racks but they are close in price to Zach's racks and Zach's look way better IMHO.
  17. Nov 23, 2014 at 8:00 PM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    Now you have mentioned the brand name, I can see it. I've seen his stuff before--they are pretty badass looking.
