Roof Rack questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scooter58, Feb 16, 2011.
  1. Feb 16, 2011 at 4:51 PM
    scooter58
    scooter58 [OP] Active Member
    tacoma
    i purchased a used OEM roof rack.
    should i purchase anti seize or loctite to use on the bolts?
    did u guys also torque the bolts with a torque wrench?
  2. Feb 16, 2011 at 4:55 PM
    blacksky
    blacksky Active Member
    Atlanta
    08 TRD 4x4 Double Cab Rugged Trail Pkg
    2009 OEM LED tail lights, Bilstein 5100s, TSB AAL, LED map lights, WeatherTech liners, tinted front windows, OEM roof rack, N-fab step rails, 265/70R17 BFG TA KO2, ToyTec coilovers
    A good wrench with elbow grease was applied and have had no issues.
  3. Feb 16, 2011 at 4:58 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    x2
    theres plenty of bolts holding it down
  4. Feb 16, 2011 at 5:09 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    If you don't plan on removing it, loctite wouldn't hurt. If you want to remove it frequently, then use neversieze. If the instructions tell you to torque the bolts, don't use either of those products and use a torque wrench.
  5. Feb 16, 2011 at 5:14 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Do it right and follow the directions. Use the torque wrench.
  6. Feb 16, 2011 at 8:43 PM
    scooter58
    tacoma
    I'm just worried about moisture getting in there.
  7. Feb 16, 2011 at 8:45 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    some teflon tape maybe?
