Roof Rack Threads Messed up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FastPace, Apr 12, 2020.
  1. Apr 12, 2020 at 4:53 PM
    FastPace
    FastPace [OP] Well-Known Member
    Pete
    Mississippi
    Do you guys know how to fix the threads on top for the roof rack? I have about four or so that won't screw straight in. There is about half an inch sticking out when I tried to install my prinsu. The rest went in just fine. I think there might've been a wrong thread from the factory. I called Toyota and they don't have a service to fix it.
  2. Apr 12, 2020 at 5:24 PM
    FirsandFire
    FirsandFire Well-Known Member
    New York
    No more Taco. A 2500HD and a Bronco sport
    They probably got cross threaded on the install. Take out the bolts and run an m6 tap through the holes.
  3. Apr 12, 2020 at 5:27 PM
    FastPace
    Pete
    Mississippi
    M6 tap? Sorry not too knowledgeable. Something like a helicoil kit?
    I'd just drill out the hole and run a helicoil through it right?
  4. Apr 12, 2020 at 5:28 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    ^. This
    if the threads are really buggered up, the easiest fix is to drill them out and retap to the next size.
  5. Apr 12, 2020 at 5:30 PM
    GHOST SHIP
    GHOST
    Not a helicoil. You’d run an tap (as in tap and die) to recut the threads. The threads that are there now are m6 so as long as you don’t drill anything out And there’s enough material still there, then running a tap through would correct the existing threads.
    I’m honestly surprised you know what a helicoil is but not a tap... Since you’d need a tap to properly install a helicoil.
    bajatacoguy and FirsandFire like this.
  6. Apr 12, 2020 at 5:45 PM
    FastPace
    Pete
    Mississippi
    So going a step up, using a tap and die go to an M7?
    Thanks for your help :)
  7. Apr 12, 2020 at 5:48 PM
    FirsandFire
    New York
    First just try chasing the threads out with an m6 tap. Going up to m7 if you aren’t careful, risks snapping the tap off in the hole and then you’re completely screwed. Take the simple route first.
    Alexely999 and 20tacoma17 like this.
  8. Apr 12, 2020 at 5:49 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Happened to me. I just used a drill and pressed hard on the bolts and drove them in. Not the best idea, but it worked.
    EatSleepTacos and crashngiggles like this.
  9. Apr 12, 2020 at 5:59 PM
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    Going to be a lot of leaky roof owners in this thread :D
  10. Apr 12, 2020 at 6:00 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Remove one of the bolts and go to the hardware store with it. Tell the clerk you need a tap and tap handle to chase threads in a nut for this size bolt and hand him/her the bolt. When you get back home, hand start the tap as many turns as you can by hand and then put the handle on and turn it. I found turning about 1/2 turn forward (clockwise) followed by 1/8 to 1/4 turn back (counterclockwise), then repeat to be best. Continue with that motion until you fully tap the nut. Hand check the bolt fits and then remove. You’ll probably have removed the thread sealer off of the bolt by now so smear a thin coat of silicone sealant on the threads and reinstall.
    SR-71A likes this.
  11. Apr 12, 2020 at 6:07 PM
    Hawkeye1864
    Hawkeye1864 Active Member
    Blue Ridge VA
    2019 Tacoma SR5 V6 DCLB
    My father used to say “we’re all ignorant, just on different subjects.”
    I managed to bugger the threads on that cheeseball bracket that holds down the front of an OEM roof rack. Had to go buy a M6 tap to straighten that out. When I snapped the rack back down, the none-too-captive threaded insert that the swing arm bolts into popped out, which I didn’t discover until after everything was torqued down. Cursing followed. Went to remove the rack for the second time and discovered I’d managed to strip the head on one of the M6x15.7 wafer head screws. Try finding those on google. More cursing. Not enough clearance between the Torx head and plastic bracket to cut a slot with a Dremel, so I will have to drill and try an easy-out. Wife now complains about cursing, adding insult to injury by suggesting taking it to dealer, with insinuations about manhood, or lack thereof.
    What is a helicoil , anyway?
  12. Apr 13, 2020 at 4:39 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Imo, the best chance of repairing the threads would be to remove the headliner and run the tap up. This way, you're starting with good threads rather than trying to start on the stripped side.
    Always always always start a bolt by unscrewing it and feeling for the threads to drop before you start tightening.
    Try it with a nut and bolt in hand and you'll see what I mean.
    SR-71A and gasgasman like this.
  13. Apr 13, 2020 at 4:47 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Nah, that's where silicone comes in.
  14. Apr 13, 2020 at 4:50 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Sounds like a mess....so glad my rack install went off without a hitch.
  15. Apr 13, 2020 at 4:51 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Dude same. On an access cab there aren't any factory holes, so you have to drill your own and install rivnuts. Well about half didn't want to thread properly so I just ran them in with an impact. Been over two years and no problems.
    Though I would not recommend OP follow suit.
    diabetiktaco[QUOTED] likes this.
  16. Apr 13, 2020 at 6:05 AM
    FirsandFire
    New York
    That works fine until the day the rack needs to be removed. :help:
    EatSleepTacos[QUOTED] likes this.
  17. Apr 13, 2020 at 6:07 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Exactly. And I never plan on removing the rack so I'm all set. At least if I ever need to I can easily just drill out the rivnut and install a new one but I'll cross that bridge if I ever have to.
    FirsandFire[QUOTED] likes this.
  18. Apr 13, 2020 at 9:13 AM
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    That stuff is even worse. In five years of UV and exposure to the elements, it'll be a rock hard mess that dries up and retracts from the joints, allowing moisture in. Never use silicone. Butyl rubber is a dynamic seal that never cures. It's what OEMs use, from roof rack mounts to windshields to headlight seals. Silicone bad.
    4xdog, 1992SR5V6 and Hawkeye1864 like this.
  19. Apr 13, 2020 at 10:14 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    My truck is garage kept and I'll worry about it in 5 yrs.
    EatSleepTacos likes this.
  20. Apr 13, 2020 at 12:17 PM
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    It never goes outside? Wow, hang on to that thing. In thirty years it'll fetch a high price at auction. Zero miles and mint condition... Except for the dried goop smeared all over the roof.
