Roof Rack Threads Messed up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FastPace, Apr 12, 2020.
  1. Apr 13, 2020 at 12:18 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You have very strong feelings towards silicone. Might I recommend professional help.
    vssman likes this.
  2. Apr 13, 2020 at 12:19 PM
    mynameistory
    mynameistory My member is well known
    Tory
    Redondo Beach, CA
    4Runner
    Thank you, I'll take it under consideration.
  3. Apr 13, 2020 at 12:21 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    :welder:
  4. Apr 13, 2020 at 12:23 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    If you needed the hitch to install your rack, it probably wasnt installed right to begin with... :cookiemonster:
  5. Apr 13, 2020 at 12:25 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    The 3M Marine Grade silicone I used to seal the top of the transom (where wood meets aluminum) on a canoe is still good as new after 8 years. And it's outside 24/7/365.
    Used the same stuff for my Rhino Rack install, in addition to the included butyl pads. Silicone is not exposed.
    Plain Jane Taco likes this.
  6. Apr 13, 2020 at 12:27 PM
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    Ok. I still wouldn't use it as a roof rack sealant.
  7. Apr 13, 2020 at 12:39 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I'll sell it in California to make up for the loss I took from the dried goop all over the roof.
    mynameistory[QUOTED] likes this.
  8. Apr 13, 2020 at 1:02 PM
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    They do seem to hold their value out here.
  9. Apr 13, 2020 at 5:01 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Give me the name of the therapist you find @mynameistory -- I probably have the same issues to work through.
    My career in polymer science and technology for more than 40 years now, especially in coatings and adhesives, has given me a chance to work around all kinds of polymers. I'm not sure there's a class more broadly used in questionable applications than RTV silicones. People seem to think it's an adhesive, a filler, a mastic, a jack-of-all-trades where it's really not that good. Sorta like duct tape in a tube.
    I'd definitely go for a butyl rubber strip-caulk (or dum dum, if you like) over silicone for a penetration in a vehicle roof.
    Larzzzz and mynameistory[QUOTED] like this.
  10. Apr 13, 2020 at 6:34 PM
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    I think the aftermarket rack manufacturers are mostly to blame. They should really provide correct mounting sealants and instructions with their rack kits. Instead, most of them barely include a footnote about it. When they do, they tell you to slather on whatever you can find at Home Depot. Just a shame that so many trucks will see chronic rust damage and electrical gremlins because of it.
    4xdog[QUOTED] likes this.
  11. Apr 13, 2020 at 6:38 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    I had the same problem, part of the roof metal covered up the threads and I couldn’t get a bolt in there. I took a dremel and grinded down the metal and made the opening bigger. I did not touch the threads or tap anything, just grinded down the metal
  12. Apr 13, 2020 at 6:41 PM
    FirsandFire
    FirsandFire Well-Known Member
    New York
    No more Taco. A 2500HD and a Bronco sport
    I just tossed on an OEM rack a few days ago and you two are really making me plan on taking it off and re-mount it using some butyl rubber. Thanks for the heads up
  13. Apr 13, 2020 at 6:44 PM
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    If you installed an OEM rack and used the factory supplied mounting pads and hardware, you should be okay. The mounting pads should have had a tacky, pliable rubber substrate, and the bolts/washers have a rubber layer as well.
  14. Apr 13, 2020 at 6:49 PM
    FirsandFire
    New York
    Bought it used, no rubber washers. Got new hardware but used clear RTV :anonymous:
  15. Apr 13, 2020 at 6:49 PM
    #35
    Sig45
    Mark
    Maine
    For reference, here's what the butyl pads look like. My Rhino Rack included them for every hole.
    Larzzzz and mynameistory like this.
  16. Apr 13, 2020 at 7:44 PM
    #36
    mynameistory
    Tory
    Redondo Beach, CA
    4Runner
    Ah. Go carefully, that stuff can be a real bear to chisel off.
    FirsandFire[QUOTED] likes this.
  17. Apr 14, 2020 at 5:23 PM
    #37
    FastPace
    FastPace [OP] Well-Known Member
    Pete
    Mississippi
    Thanks everyone. Went out and bought an M6x1.00 tap and chased the threads. Everything working great!
