Roof rack to support a RTT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BradsTaco, Mar 24, 2018.
  1. Mar 24, 2018 at 12:22 PM
    BradsTaco
    BradsTaco [OP] Well-Known Member
    Texas/Montana/Florida
    2014 TRD 4x4 DCLB
    I’m looking into getting a RTT and was looking for some advice. I have a snug top camper and it’s only rated to 200lbs. So I’m looking into getting a roof rack that will support the RTT. What rack would you guys recommend. I’m looking at trying to buy a used RTT and what to stay under 500 bucks for the roof rack.
  2. Mar 24, 2018 at 12:24 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    For 500 you'll probably have to get a used rack as well. Have you considered a set of bed bars? Could probably get a set of those for 250-300.
    The Kb Voodoo rack is around 600.
  3. Mar 24, 2018 at 12:35 PM
    Karate1993
    Karate1993 Well-Known Member
    coloRADo
    '14 TRD Off-road DCSB
    Just curious, is it rated at 200 lbs for static or dynamic weight?
    Because if that's dynamic weight, you might be fine.
  4. Mar 24, 2018 at 12:37 PM
    BradsTaco
    2014 TRD 4x4 DCLB
    I didn’t know there was 2 types of weight ratings. I’ll call them Monday and find out.
  5. Mar 26, 2018 at 7:08 AM
    samjpatt
    samjpatt Well-Known Member
    Raleigh, NC
    2018 Cement TRD Off Road
    RIP: 2015 Silver TRD Sport
    You said roof, so I’m assuming you’re keeping the shell and want something over the cab- if that’s right, look at Rhino Racks. It will top out your budget but they have some great solutions that are ditch mounted to the cab. They even have an option with a QR that you can detach the entire rack when you don’t need it. They also sell a version where you replace the weather strips with a rail system which gives the rack some adjustability.
    Should be more than enough for a RTT. Haven’t pulled the trigger myself, but did the research for this set up a while back.
    BradsTaco[OP] likes this.
