Roof Rack with Full-Size Spare?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by daleclough, Dec 26, 2018.
  1. Dec 26, 2018 at 9:02 PM
    daleclough
    daleclough [OP] Well-Known Member
    Portland, OR
    18 TRD Off Road Double-Cab Short Bed
    None... yet
    I have a 295-70R17 on a 17x9 wheel that needs a place to reside as my spare.
    I have zero interest in using the bed space or above it.
    Anyone here put a rack on the cab and successfully (important criteria) mount a full-size spare?
    I realize some garages will be no-go... don’t care....
    Thank in advance for your helpful posts!
  2. Dec 26, 2018 at 9:07 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Why not just put it back underneath? Should fit with a little hammer work on the tire guides.
  3. Dec 26, 2018 at 9:11 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    @dwaltdtx did it for a while, gas mileage will suffer and I don't envy you when you actually need the spare and have to pull 100lbs off the roof.
  4. Dec 26, 2018 at 9:12 PM
    stlntaco
    stlntaco Well-Known Member
    Jake
    California
    ̿̿ ̿'̿'\̵͇̿̿\з= ( ▀ ͜͞ʖ▀) =ε/̵͇̿̿/’̿’̿ ̿ ̿̿
    I used my factory spare tire hoist and bolted it to a cross tube. 35x12.50s fit with plenty of clearance. Only problem is you cant see shit out of the back.
    daleclough[OP] likes this.
  5. Dec 26, 2018 at 9:13 PM
    daleclough
    Portland, OR
    None... yet
    That good info... thank you. The spare is quite heavy vs OEM.
    You provide any thought on @crazysccrmd post?
  6. Dec 26, 2018 at 9:15 PM
    hoarder23
    Shay
    NJ
    Scratches
    If you bend the guides the tire will fit but you risk the rear diff contacting the tire when the axle gets stuffed
  7. Dec 26, 2018 at 9:15 PM
    daleclough
    Portland, OR
    None... yet
    I was thinking something similar on the OEM tri-fold but the visibility went to zero
  8. Dec 26, 2018 at 9:16 PM
    daleclough
    Portland, OR
    None... yet
    I’m concerned about getting it high enough... it’s a wide piece of rubber...
  9. Dec 26, 2018 at 9:17 PM
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    11 inches wide or so....not that big. Should fit fine
  10. Dec 26, 2018 at 9:19 PM
    daleclough
    Portland, OR
    None... yet
    Looks like a January project!
    Thanks folks!
  11. Dec 26, 2018 at 9:21 PM
    hoarder23
    Shay
    NJ
    Scratches
    If you don't want the tire in your bed or above your bed the best option is a swingout bump or a Wilco hitchgate.
    Think about how often you actually use your bed, my tire lays flat 95% of the time, gets stood up 4% of the time and thrown on top of what gets put in the bed the rest.
  12. Dec 26, 2018 at 9:24 PM
    daleclough
    Portland, OR
    None... yet
    Bed gets used weekly for Costco runs, race car parts and mountain bike bar...
