roof rack - worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Apr 28, 2022.
  1. Aug 16, 2023 at 7:00 PM
    RMAC
    RMAC Active Member
    TX
    2018 Tacoma DC LB TRD Sport 4x4 Cement
    Anyone familiar with the Grand Teton and the Crow's Nest from Sherpa? I am looking to replace my useless Yakima rack with an over the cab and camper shell system for general purpose/small amounts of lumber/ladders. Looks like the Sherpa stuff is a little wider (48 1/2") that will work better for 4' x 8' plywood, and better tie down slots for ratchet straps.
  2. Aug 16, 2023 at 9:07 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    I found a used Grand Teton.
    I also see one in LA on FB.
    What about it?
    Sherpa makes the best racks.
    bulalo likes this.
  3. Aug 17, 2023 at 4:35 PM
    RMAC
    RMAC Active Member
    TX
    Just looking for someone who is familiar with them as far as quality, and could they be useful for light to medium duty lumber/ladder use? How are the tie down locations? The Sherpa stuff looks top notch.
  4. Aug 18, 2023 at 1:00 AM
    TacoTuesday1
    FL
    they have strong double cross bars. The highest advertised load rating to my knowledge
    first time I saw one was exactly that. Guy who got it to haul wood.
    side plates are 1/4” instead of 3/16”
    And is considered their beefier heavy duty rack compared to Prinsu or the thinner Sport they just came out with.
    far as I can tell the tie downs are the stock handle holes, maybe more. They also sell accessory add on brackets for additional tie downs.
    if you find the one in LA on FB, maybe the guy is open to break it down box it up and ship at extra cost that will still be much cheaper than new.
    every pretender and their mom got Prinsu because that’s what they saw on Instagram without asking if it’s actually the best and is the only rack they know of.
    Which uses sealant that can crack instead of rubber pads like Sherpa
    I’ve seen other decent looking racks. Whatever Tacomaholic has looks beefy maybe 1/4” as well but not as long.
    I looked at SDHQ rack and don’t really like the look of it personally. And that’s part of the equation on something like this: if it looks good.
    as opposed to say, Hooke Road, which is very thin and ugly.
    Been there done that tried it sold it.
    RMAC[QUOTED] likes this.
  5. Aug 18, 2023 at 1:47 PM
    EL DUDE
    EL DUDE Well-Known Member
    I had one before a 3K mile trip years ago, I took it off at a gas station and posted it on Facebook at the time on the Tacoma group “free if you want it”, threw it all in the trash at the pump
    couldn’t stand the wind noise from the front cap, or when the bars were extended
    (Oem)
  6. Aug 18, 2023 at 2:08 PM
    AlHago
    AlHago Well-Known Member
    Alan
    Huntsville, AL
    12 DCLB MGM
    Stock as all get out.
    coming from a victory 4x4 rack to a sherpa, the sherpa rack is the beefiest no question about it.
    RMAC likes this.
  7. Aug 18, 2023 at 6:47 PM
    RMAC
    RMAC Active Member
    TX
    Great info. Def sold on the Sherpa, I need a better rack than the wimpy Yakima bars I got. Those things are worthless. Total waste of money.
  8. Aug 19, 2023 at 12:59 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Yes buy a roof rack they come in handy.
  9. Aug 19, 2023 at 9:15 PM
    RMAC
    RMAC Active Member
    TX
    Since you put it that way, nothing can stop me from purchasing one now!
  10. Aug 19, 2023 at 9:24 PM
    EvoRescueVehicle
    EvoRescueVehicle Active Member
    Eric
    Vegas, NV
    2020 Cement Tacoma TRD Off Road 4x4 M/T
    I opted for the AL Offroad rack with the lightbar cutout. I didn't have a lightbar for a while and didn't notice any crazy wind noise or MPG losses. As soon as I installed the Baja Designs 7 XL Linkable bar, that's when the wind noise was introduced at highway speeds (but no noticeable MPG losses) but I fully expected noise before installing.
  11. Aug 20, 2023 at 1:51 PM
    Argann
    Argann Well-Known Member
    Rich
    4Runner, Tacoma, Defender 90
    I use mine on my topper a lot. Haven’t used my cab one yet. Both prinsu. Found them used on here.
  12. Aug 20, 2023 at 8:26 PM
    Andrewkcrow84
    Andrewkcrow84 Well-Known Member
    Andrew
    Yosemite National Park
    07 TRD
    I had a rack for a long time and found that I never used it.
    goforbroke123 likes this.
  13. Aug 21, 2023 at 2:29 AM
    TacoTuesday1
    FL
    a setup like this would be cool.
    Sherpa Grand Teton
    -center: 2 or 4 maxtrax on mount, pins, locked
    -outsides, Harbor Freight apache 9800 tan (less hot than black) if they go on sale
    including drill holes, adjust cross bars, insert rod to measure how long bolt should be for t-slot nut. And use rubber-lined washer for bolt, for moveability vs silicone cracking
    -left side, some sort of awning
    -right side, a dual shovel and axe holder. Doesn't seem to be any that bolt on. Would rather drlll a mount than a rack; may need to. 2 bolts mount to crossbar and hope the door can open, no floppy/rattles, etc.
    may require longer bolts, spacers, or bracket to relocate slightly higher
  14. Aug 21, 2023 at 9:36 PM
    TikiBird
    TikiBird Well-Known Member
    06' Tacoma ACLB TRD Pre-runner, Leer 122 shell.
    Hey guys first post.
    I have the Thule Squarebar on my leer 122, and am thinking about getting the Hooke-road rack for the cab.
    it looks like 100w renogy solar panels will fit perfectly on the hook road rack.
  15. Aug 21, 2023 at 11:55 PM
    #35
    TacoTuesday1
    FL
    I've got a 100w renogy on my shell and it's not enough watts. Should be at least 200w. And companies make one for hood.
    solar panel gives a bit more modularity than a stickon bendy one.
    You can run the Hooke if you want. But be advised they're not very good and you may end up later wanting to take it back off.
    idk what your whole plan is for cab vs. shell
    but if you do get a 100w panel, judging by that pic: you could simply mount a flexible one to the roof itself. There's DIY's on it
  16. Aug 22, 2023 at 12:06 AM
    #36
    TikiBird
  17. Aug 22, 2023 at 12:19 AM
    #37
    TacoTuesday1
    FL
    ^I mean honestly 2 100w can likely fit on any rack. Maybe even crossbars or crappy OEM rack.
    200w may fit on flat surfaces using flexible panel(s)
    Hooke Road is what, $340?
    Seen various used high quality racks sell in the range of $300-$700
    Totally your call.
    Flexible is cheaper. If it's $130 and wears out after 3yr, big deal. Again, your call.
    My flexible has an airgap by common mod of putting corrugated board sandwiched in between with air passageways. And that requires moving when the truck is not always driving.
    I don't see why you need a solar panel and second battery for interior LED's.
    I have added lights. They run off the truck.
    Last time I used solar and aux battery was living in my truck powering various things like running a fridge 24/7, charging devices, etc. which is typically what that is for.
  18. Aug 22, 2023 at 7:11 AM
    #38
    TikiBird
    renogy 100w panels are down to $75 now.
    I'll probably get a small fridge down the road
  19. Aug 22, 2023 at 9:17 AM
    #39
    tjv504
    tjv504 Taco n00b
    Tom
    NOLA
    2023 Tacoma TRD Sport Lunar Rock
    Pro Grille, TRD skid, Spidertrax 1.25" spacers, Cali Raised cat shields, Seat Jackers, 67Designs Taco Rail, WeatherTech floor mats + bug deflector + side window vent shields, demon (nipple) rings, Hitchhiker's Guide to the Galaxy reference on the tailgate, Tyger tri-fold tonneau cover
    Been eyeing the Hooke Road rack. Looks like exactly what I want. Anyone have experience with those? A rattling rack would def. sour my Taco experience.
  20. Aug 22, 2023 at 11:43 AM
    #40
    MBangs
    MBangs Member
    Mark
    2022 Lunar Rock Tacoma TRD Sport
    Exterior Blackout Emblems, Bed Molle Panels, Tonneau Cover
    I just put the upTOP Overland Bravo Rack on mine a month ago.
    Currently, it has the normal wind fairing and nothing mounted on the rack.
    I haven't notice any wind noise up to 80mpg on the freeway.
    I will be installing the fairing with the 40" light cutout soon and putting a hard case (with recovery gear), 100w Renogy Solar panel, and my 2 traction boards on there.
    The reason I got the rack, I plan to take my bed rack off next spring and summer for outdoor sports and activities and I need my bed space to transport.
    Time will tell if I get wind noise when I put the light and cut out fairing on with the lightbar.
    Hawapino likes this.
