Roof Rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dorsey24, Jan 9, 2020.
  1. Mar 26, 2020 at 11:13 AM
    DTaco22
    DTaco22 Well-Known Member
    Darian
    17' Taco. TRD OR
    3" Eibach lift, JBA high caster upper control arms, 2" ToyTec add-a-leaf
    I have a factory rack for sale, you just would need to find the two yellow clips that are for the front of it
    But....I bought a OEM rack, and before installing it i changed my mind to the Hookeroad rack on Amazon.
    It had a couple of little hiccups but for $280.00 it csnt be beat and is really solid.
  2. Mar 26, 2020 at 11:13 AM
    DTaco22
    Darian
    17' Taco. TRD OR
    I have one for sale, it's just missing the two yellow plastic clips for the front. You would have to find that
  3. Mar 26, 2020 at 11:37 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    How much?
    DTaco22[QUOTED] likes this.
  4. Mar 26, 2020 at 11:58 AM
    Angel Rivera
    Angel Rivera Well-Known Member
    Angel
    Southern California
    2017 Toyota Tacoma TRD Off-Road Double Cab
    Ditch lights, front LED light bar, leather seat covers, bed tonneau cover.
    I would go OEM, I purchased a knock off for my second gen and had so many problems with it that I ended it literally throwing it away and spending the extra cash on oem. I did the same for the 3rd Gen. The OEM fits in so much better and easier and believe me when I say you will notice a difference in quality. Either that or go with a prinsu or something like that.
    Hawkeye1864 likes this.
  5. Mar 29, 2020 at 4:52 AM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    I purchased a knock off and after a year, the HW was rusted out completely. I'm lucky it came off.
    That being said, the OEM costs are prohibitive vs. the return. Aftermarket is a better spend when you see the limitations of the OEM.
  6. Mar 29, 2020 at 6:52 AM
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    I was originally going to install the OEM rack from Toyota but purchased an aluminum Prinsu copy instead (Martin Cab Rack). It’s much sturdier than the plastic OEM rack and less expensive than a Prinsu. Great rack and highly recommended.
  7. May 7, 2020 at 1:10 PM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    Question, would the OEM Roof Rack support a Spare Tire (265/75r16 E Load approx 70lbs) and a set of Max Traxs (approx 16lbs)?
  8. May 7, 2020 at 1:20 PM
    Angel Rivera
    Angel
    Southern California
    I should of done the same thing I had two kayaks that were well within the 100 lbs limit, going down the freeway and the OEM roof rack snapped. Luckily Noone was behind me and no damage to anyone. Very disappointed in Toyota quality as it is a oem part that I paid a lot of money for. Should of gone prinsu.
  9. May 7, 2020 at 2:13 PM
    Oahu96819
    Oahu96819 Well-Known Member
    Robert
    Honolulu, HI
    2019OR 4WD
    some FYI - I just installed Thule set on the roof of my '19 Tacoma . I carry a Ocean Kayak Prowler 15 with no problems at all. If you are considering carrying a Kayak, this is a solid solution. I did have the Toyota's swing blades OEM on a 2016. I prefer the roof clearance and weight load of the Thule
  10. May 7, 2020 at 5:11 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Yikes! Which part snapped on what types of kayaks, and how did you load and secure them?
  11. May 7, 2020 at 5:53 PM
    Angel Rivera
    Angel
    Southern California
    The driver part of the roof rack in the rear, where it pivots. They are 6 foot kayaks, held down with straps. The pivot point was cut in half. They were facing front to front of truck, everything held, it was just that part that snapped like a twig, Kayaks weigh about 45 lbs each.
  12. May 7, 2020 at 6:38 PM
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Man, I'd go back to Toyota for a replacement rack and get some help with any damage that the failure inflicted. They shouldn't fail like that if they're installed properly and aren't damaged.
  13. May 8, 2020 at 8:25 AM
    The_Devil
    E
    No. Not in any way.
    The OEM is trash for aesthetics. Whatever it is rated for be it 75 or 100 lbs is still not safe.
  14. May 8, 2020 at 9:06 AM
    Interbeing
    Austin, TX
    Ok, thanks, I suspected that, but saw one for a good price, I think I’m going to go with the Martin Foundation Rack.
