Roof Rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lexie5720, Dec 18, 2023.
  1. Dec 18, 2023 at 8:03 AM
    Lexie5720
    Lexie5720 [OP] New Member
    2023 Luna Rock TRD Sport
    Hi, I just received my 2023 Tacoma that has been on order since May. I'm having a factory roof rack installed. If anyone has a factory roof rack on their Tacoma, could you please measure the height of it at the highest point? Not sure if the side rails or cross bars are higher. Much appreciated. Thanks
  2. Dec 18, 2023 at 11:14 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    welcome and careful here,,, I THINK the antenna was changed in the latter years, and that doesn't clear the OE roof rack,, and that is why it was disco'd.
  3. Dec 18, 2023 at 11:16 AM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    It was relocated on my early 2020 build (which still has the trans cooler) to where the stock rack would no longer work. i believe it was corrected and moved back to its original position during the 2020 mid-year refresh when they removed the trans cooler
    Chew[QUOTED] likes this.
  4. Dec 20, 2023 at 4:38 AM
    Lexie5720
    Anyone have measurements please?
  5. Dec 20, 2023 at 6:32 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Be more descriptive in what your wanting measured.
  6. Dec 20, 2023 at 6:41 AM
    Lexie5720
    Could you please measure the height of it at the highest point? Not sure if the side rails or cross bars are higher. Much appreciated. Thanks
  7. Dec 20, 2023 at 9:55 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Not sure if this is what you mean, but the high point of the bars is certainly taller than the side rails. The height above the ground will vary depending on tires, lift, model, etc.
  8. Dec 21, 2023 at 2:49 AM
    VaToy
    Parts Unknown
    I was going to measure it just like that, lol. I was not home yesterday, so I thank you.
    OP whats the purpose of measuring?
    Malvolio[QUOTED] likes this.
  9. Dec 21, 2023 at 4:57 AM
    rbdudeman
    rbdudeman Well-Known Member
    Factory roof rack...are there cross bars that can be added...To be more specific, cross bars that could be added without deploying the factory cross bars. The goal is to have a flat platform to attach to, not the factory camber that comes with the bars. Has anyone installed any and are they worth the money(if there is such a thing).
  10. Dec 21, 2023 at 7:17 AM
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    The Thule Foot Pack seems to work. See post#8 here:
    https://www.tacomaworld.com/threads/cross-bars-for-roof-rack.579672/
    That should get you started.
