Roof Racks on Aluminum Camper????
Discussion in 'Armor' started by Zacoma77, Feb 18, 2015.
  1. Feb 18, 2015 at 12:27 PM
    Zacoma77
    Zacoma77 [OP] Well-Known Member
    Zach
    San Jose
    Black OR DCSB
    Camper shell, Sliders...much more to come
    I got a aluminum camper top for free from a friend and I was wondering how sturdy it is, because I was wanting to put a Thule rack on top or other rack system.
    It just doesn't seem like the most sturdy camper in the world. Just curious if anyone has had any experience?
    Thanks
  2. Feb 18, 2015 at 12:38 PM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    get on top of it. if you are comfortable with yourself up there, then you know it can handle at least your weight.
  3. Feb 18, 2015 at 1:14 PM
    Zacoma77
    Zach
    San Jose
    Black OR DCSB
    Cool, Thanks
  4. Feb 18, 2015 at 1:16 PM
    Taco Dan
    Dan
    Tuscaloosa, AL
    what are some things you are gonna haul up top?
  5. Feb 18, 2015 at 1:20 PM
    Zacoma77
    Zach
    San Jose
    Black OR DCSB
    I'd ultimately like to put a thule rack like I said and then maybe my kayak and or bikes, nothing too over the top on weight.
  6. Feb 18, 2015 at 5:12 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Aluminum shell should be able to hold up a kayak or a couple bikes no problem. I wouldn't trust it to haul a stack of lumber, though.
  7. Feb 18, 2015 at 5:40 PM
    Zacoma77
    Zach
    San Jose
    Black OR DCSB
    Thanks for the the responses. I am just a little weary as there are only two cross beams below the aluminum outer covering so if I were to attach a rack it may have to attach to both of the cross beams or to the forward most beam and the cab?
  8. Feb 18, 2015 at 5:59 PM
    bmgreene
    Brian
    L.A. Westside
    If you don't mind a bit of a "whiskey-tango" aesthetic, for carrying a kayak you could probably just attach a couple of 2x4 cross-pieces wrapped in astro-turf or some other outdoor carpet to the top of the shell and attach those with some 1-1/4 " teks or construction screws (4-6 screws per board, with a ring of caulking around each hole between the roof and the board). you could even put some eyebolts through the whole works at the ends of the board (use gaskets under the washers on the underside of the roof to help seal those back up) to have points for hooking up straps to hold down the kayak.
    that'd save you enough money to get a hitch-mounted bike rack, which would be a lot easier to load/unload than trying to strap bikes down on top of the shell.
  9. Feb 18, 2015 at 6:01 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    The racks I've seen on aluminum shells usually have a leg that attaches to the sides running all the way down to the bed cap and then the crossbars run across from them
    Similar to this
  10. Feb 24, 2015 at 4:54 PM
    Spintly
    Spintly Well-Known Member
    Greg
    Home of the Groundhog
    85 Single Cab Pickup & 2000 911
    I just picked one up tonight. It has the same rack system as OZ posted. Will take some pics tomorrow.
  11. Feb 24, 2015 at 5:26 PM
    Zacoma77
    Zach
    San Jose
    Black OR DCSB
    I have seen those too, but my camper top doesn't have the exterior square metal racks, unfortunately.
  12. Feb 25, 2015 at 10:10 AM
    Spintly
    Greg
    Here are the pics of mine. The rack looks like it came with the cap from the same manufacturer. I believe the cap is from the Century line by Leer. Hope this helps.
